Tony's 91 SS 29Dec R.I.P.
Re: Tony's 91 SS David Carter
Get a kartboy short shifter. Happy middle ground. That one you have is way too short. Control arms look niice.
Re: Tony's 91 SS 27Apr updates
I gotta ask. How much were those speedlines?
Cool site though. 4thup.com No good wheels at the moment but I guess next week they've got a container coming in with tons of wheels. I'll keep an eye on them in the future for some nice wheels.
Post by SILINC3R »
kimokalihi wrote:I gotta ask. How much were those speedlines?
only $800 shipped. Free shipping on all there wheels. Can't beat it.
Yea I need to figure out which shifter I want to use
Nice. Gotta find some volks or speedlines.
Post by SILINC3R »
Anyone have any clue what the 2 white connectors are? I was hoping they were there so I could plug them into the clutch switches but that doesn't seem to be the case.
So if you look to the right of the one I am holding you will see the other one
Post by SILINC3R »
Alright so more wiring yea. I have figured out that most people have the MT harness on the tranny side and get the MT B15 plug for the chassis side do do this swap. Well, I didn't get that luxury so I am kaing my own with the AT harness.
And I have searched far and wide so I this should be correct.
AT B15 Connector is 12 pins
MT B15 Connector is 4 pins
Jumper 11+12 on AT B15 connector chassis side to bypass the starter interlock relay. This means the car will start even if it is in gear so becareful.
To make the reverse lights work connect pin 9 to pin 2 (AT -> MT) and pin 10 to pin 4 (AT -> MT)
For the neutral switch connect pin 1 to pin 1 (AT -> MT) and pin 4 to pin 3 (AT -> MT)
So what I am having to do.
MT without harness
AT with harness that plugs in AT B15 connector
So I cut this harness
Removed the back cover so I could depin
So now I can make the AT connector basicly a 4 pin connector. Just have to rearrange pins.
Then I cut the 2 connectors off the MT and cleaned them up and added about 1 ft extra wire to extend it.
the 2 colors are red/white and then black
Post by SILINC3R »
This is a good link for multiple links for doing the swap. Another 4EAT to 5sp WRX Swap is finished Surrealmirage
Ok now if you are someone like me and you need to understand and see pictures this will clear up everything for good.
Pin 20 on B48-ECU/Transimmsion ID-Black/White
Pin 18 on B36-Combination Meter/Neutral Light-Light Green/Yellow wire
Back-Up Lights
This diagram here in highlighter shows why 9-2 (AT-MT) are connected and 10-4 (AT-MT) on the B15 connector
This diagram shows mulitple things
1st: Bypassing the Starter Interlock Relay
why we jumper 11+12 on B15 creats the path that putting the selector in Park or Neutral would accomplish
2nd: Neutral Switch
why we connect 1-1 (AT-MT) and 4-3 (AT-MT) on the B15 connector. Now if you notice you will see where 4 actually goes on the chassis side. It goes to ground.
And here is what the wire colors and positions should be for MT B15 connector
1-Light Green/Yellow
2-Black/Yellow
3-Black/Red
4-Brown/Yellow
Tony,
Those white connectors you were trying to figure out...how many wires did they have going to them?
Post by SILINC3R »
Legacy777 wrote:Tony,
One has 4 which is attached to the TCU harness and the other one has 3.
Post by SILINC3R »
Teaser pics.
Still waiting on parts but the wiring is done.
Apexi Nation
Test fit
SILINC3R wrote:One has 4 which is attached to the TCU harness and the other one has 3.
Hmm....I'm not sure.
Post by SILINC3R »
Ok, so just got back from 6 days at the Tail of the Dragon and what a blast and epic trip. We had5 straight days to drive it and did 4 due to weather. One midnight run in the dark just to say we did I'll be posting videos. We also did the Cherhola Skyway were speeds reach over 100 MPH and various other fantastic drives. If you can ever make it over that way due it!
On another note, spent 24 hours straight before the trip trying to get the car up for the trip but ended up missing 2 bolts for the forward part of the tranny crossmember. So, I had to stop and get those ordered.
Post by SILINC3R »
Welllllllll
She's back on the road yea! Had a little issue with the new downpipe making the exhaust to long so I cut the rear cat of the exhaust and bolted it up to the downpipe. Creats a little back pressure and not so load.
The 1st big problem was I was throwing code 23 so I did some research and did test and couldn't figure it out. Everything worked before and even though I go overboard on my projects they usually work out. Well what I ended up finding out was my Apexi SAFC was at fault. The signals for the MAF sensor weren't making through the box so either I need to tune the box to get it to run or it's bad. So for now I just jump the wires back together to make the code go away yea!
Next I need to fine tune the clutch pedal, get an alignment, switch rims, and put the interior back together. But I am happy and it's weird shifting in it now haha.
Pics and videos to come.
Re: Tony's 91 SS 26May Back on the road!
WhoohoooooOOO!!!!!
Post by SILINC3R »
Is that gopro stuck on your sunroof?
Post by SILINC3R »
Yes sir, suction cup
Looks and sounds great!
I like your gauges light.
ride_child
Post by ride_child »
yea dood hearing your ss in that video makes me want mine bad!! hurry up mike!! haha
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
Post by SILINC3R »
Ok so time for some updates.
Finally got my Preo-R Speedlines on, got an alignment and for the most part running ok. Spent the majority of the day trying to fix my boost issue. Car didn't want to run in boost and was breaking up so I pulled the plugs and gapped them to about .028-.030. Went for a run and then my throttle body coupler was causing issues. Got all that fixed and went for a run where I could try and push it a little and see how it held boost. It did pretty good for the first couple pulls and then the last one I was doing a top run and got Check Engine Light. Did't feel any different but it's there
Codes 23, 33, 45 and 49
I have been driving the car for about a week without a speedo cable and haven't had any issues until now.
And just checked on the car and the codes are gone. Disconnected the battery and will check it in the morning and see what's up.
You need to get your speedo working so the ECU will be happy.
Post by SILINC3R »
Legacy777 wrote:You need to get your speedo working so the ECU will be happy.
what does it actually do for the ECU?
Vss code throws the ecu into a weird mode if it isnt functional
Sent from my SGH-T889 using Tapatalk
Post by SILINC3R »
Hmm, car has been driving fine. And it only throws the code over 85 and then it stays on till I turn the car off.
