Page 97 of 131
Posted: Sun Mar 02, 2014 7:42 pm
by Danny-G
Here's the result of my painting.
Posted: Tue Mar 04, 2014 4:02 am
by 92ColoradoTurbo
PREPARE FOR PHOTOS!
Discovered that my low fuel light works! I'm guessing it comes on when you have two gallons left because I drove to the gas station with it on for a bit and filled up 14.1gal and we have a 15.8gal tank I believe. Also took her on a road trip to Tarryall Reservoir, Colorado.
Sent from my XT1080 using Tapatalk
Posted: Tue Mar 04, 2014 4:22 am
by Scuba75
Replaced all four struts and mounts on my 93 wagon with KYB G2's, plus replaced a broken headlight and turn signal.
Posted: Tue Mar 04, 2014 5:14 am
by 208ss
Ordered whiteline front 22mm swaybar and heavy-duty endlinks
Posted: Tue Mar 04, 2014 7:11 am
by CAV3MAN227
-I've only seen my gas light come on once in over 5 years I've owned the car and that was only because I was low on fuel and on an incline on a driveway. Never seen it since.
-Joe
Posted: Tue Mar 04, 2014 8:22 am
by James614
Killed it, somehow. Died while idling, wouldn't start backup. Has two codes for MAP and IAC but I think those are stored. I really hope its the fuel pump.
Posted: Fri Mar 07, 2014 8:06 pm
by 208ss
Installed my whiteline swaybar and endlinks
Posted: Fri Mar 07, 2014 11:02 pm
by James614
Just had an Exedy LW flywheel and Stage 1 Clutch delivered. Now I can hopefully get to 15psi without slipping :)
Posted: Sun Mar 09, 2014 12:03 am
by James614
Installed my flywheel and clutch. I really wish I had just followed the FSM instead of winging it, then I may have realized you have to remove the clutch fork pivot shaft and take the fork out of the release bearing before the trans will come out
Edit: I really want to switch to the '06+ push style turbo trans now.
Posted: Tue Mar 11, 2014 3:33 am
by dankberries
Installed a new torque converter seal today and put the engine in. I was in such a rush to pull the engine I had completely forgotten about removing the torque converter and damaged the seal when pulling the engine, also made for one hell of a mess with stinky atf every where. BTW I absolutely hate auto trannys! I'm so pissed I'm putting this back together w/ the auto. 5speed soon!
Posted: Tue Mar 11, 2014 5:19 am
by killajamal
@Robertpaige your sedan looks f***ing rad my friend! Love it! So clean. What suspension you running?
Posted: Tue Mar 11, 2014 4:26 pm
by 208ss
Got one of my wrx seats installed
Posted: Wed Mar 12, 2014 8:45 am
by jamal
James614 wrote:Installed my flywheel and clutch. I really wish I had just followed the FSM instead of winging it, then I may have realized you have to remove the clutch fork pivot shaft and take the fork out of the release bearing before the trans will come out
No you don't. I had my clutch fork crack at the pivot last year which was not fun to replace. It's pretty common on the newer WRX.
Also you can detach the throwout bearing from the pressure plate with a long screwdriver instead of pulling the pin.
Posted: Thu Mar 13, 2014 2:28 am
by turbo970
got rid of the fart can muffler and got the obx muffler put on
Posted: Wed Mar 19, 2014 5:18 am
by Danny-G
New wipers all around, wagon has been treating me pretty well overall.
Posted: Thu Mar 20, 2014 3:59 am
by 208ss
found out that my transmission is going out the rear bearing is whineing like a mofo
Posted: Thu Mar 20, 2014 8:40 pm
by killajamal
Turbo front end conversion. Plastidipped my hood, painted the front bumper, license plate hard-delete, custom front grill(inspired by the newer forester grill look) and blacked my lights and corners.
Posted: Sat Mar 22, 2014 6:34 pm
by 208ss
Bought a ppg straight cut gear transmission because my stock went out.
Posted: Sun Mar 23, 2014 2:03 am
by CAV3MAN227
-Put some new tires on the car. Re-arranged some electronics in the cabin.
-Joe
Posted: Sun Mar 23, 2014 2:51 am
by 94EJ22
Got new rims put on, changed the oil and ran it through a car wash.
Posted: Sun Mar 23, 2014 12:36 pm
by James614
jamal wrote: Also you can detach the throwout bearing from the pressure plate with a long screwdriver instead of pulling the pin.
I tried this, there was no way a screw driver would fit in there at the angle we needed. But after the first try its cake undoing the fork in the future.
Posted: Sun Mar 23, 2014 5:17 pm
by mike-tracy
208ss wrote:Bought a ppg straight cut gear transmission because my stock went out.
Did you buy the 4.44 tranny that had been for sale forever on nasioc? Considering the parts and labor put into it, that was a steal!
Posted: Mon Mar 24, 2014 1:39 am
by CAV3MAN227
-Painted a manifold, ready to go on tomorrow.
-Joe
Posted: Mon Mar 24, 2014 4:37 pm
by dillonr92
Over the last month ive done all this.
I installed coil overs.
New catless TBE straight pipe.
Did a compression test.
Throttle body coolant bypass.
Installed a different maf.
Cleaned that maf.
Cleaned the iacv.
Installed td04/tmic..
Next up is water pump and timing belt and a few seals.
Then I have a five speed swap that needs to be done.
And the last thing I have on my to do list is pick up these headlight housings my buddy has. And clear the lenses, paint the housing black and then retro fit them.
Sent from my SCH-I545 using Tapatalk
Posted: Mon Mar 24, 2014 6:15 pm
Please remember to hit return after each picture so the pictures scroll veritically vs. horizontally out to the side.
I fixed these.
