Choosing the right pump for your air/water intercooler
Front, Top, Air, Water.
So the 7 is the newer model....
K, you said you ordered this one for your new AWIC?
The 7 has about 60% more flow at the same pump head. This is assuming I'm reading the tech stuff correctly.
I'd almost like to get a little more flow.
-K-
Post by -K- »
Right. The old one was out of production and about half price, so it's the one I used on my 92.
I'm not too worried about the flow because I'm going to have a nice cooler. I would expect the newer model to be as quiet as the old one...
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
What cooler are you going to use? That's the other thing I need to try and find. I haven't been super successful in finding anything yet.
-K-
Post by -K- »
I'm looking at a 2nd gen RX7 oil cooler. I should have it measured up this weekend to see if it will fit well. I'm going to try to fit it like a FMIC. I'm also going to look at oil/tranny coolers.
If that doesn't look like it will fit or be big enough I'm going to cut out the bumper and fit a small radiator. VW maybe because there is one without a filler cap.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
Is the stock awic water pump worthwhile?
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
Laurel, it's ok. However if you have the money, you can get a higher flowing pump that will reject more heat.
