Page 2 of 2
Posted: Fri May 20, 2005 6:55 pm
So the 7 is the newer model....
K, you said you ordered this one for your new AWIC?
The 7 has about 60% more flow at the same pump head. This is assuming I'm reading the tech stuff correctly.
I'd almost like to get a little more flow.
Posted: Sat May 21, 2005 1:03 am
by -K-
Right. The old one was out of production and about half price, so it's the one I used on my 92.
I'm not too worried about the flow because I'm going to have a nice cooler. I would expect the newer model to be as quiet as the old one...
Posted: Sat May 21, 2005 8:53 pm
What cooler are you going to use? That's the other thing I need to try and find. I haven't been super successful in finding anything yet.
Posted: Sat May 21, 2005 11:39 pm
by -K-
I'm looking at a 2nd gen RX7 oil cooler. I should have it measured up this weekend to see if it will fit well. I'm going to try to fit it like a FMIC. I'm also going to look at oil/tranny coolers.
If that doesn't look like it will fit or be big enough I'm going to cut out the bumper and fit a small radiator. VW maybe because there is one without a filler cap.
Posted: Sun May 22, 2005 8:44 am
by LaureltheQueen
Is the stock awic water pump worthwhile?
Posted: Sun May 22, 2005 3:59 pm
Laurel, it's ok. However if you have the money, you can get a higher flowing pump that will reject more heat.
