Installing JDM AWIC
I'm not quite following, are you saying that you'd split the line going to the "radiator" parts, and then rejoin them on their way back?
How come I've not thought of doing that before?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
Ok, but the one I had before looks like its about 1/4th the flow of the pump/intercooler in terms of size http://community.webshots.com/photo/112 ... 1865JjMZQS So from what you are saying, I would need 4 of those... But it is a good idea, and I could probably do that and get by without a resevoir as with two radiators thats about 50% more capacity in the system.
- quasi-mod-o
Time to bump an old thread with new information.
I got a chance to hang out with Marc Rameriz (aka Xephyr) at the auto-x last weekend and take a really good look at hit EJ22T powered RS-T w/AWIC. His AWIC is a huge unit that was custom made by PDM. Obviously, most of us aren't going to use something like this, but I do know of two PDM units currently for sale for someone looking for some bling in their AWIC. But back to the tech. I talked to him for about an hour on this and he gave me part#'s an locations to get them.
For starters, his reservoir is a Lexan Nalgene bottle, of all things. It has a hole drilled in the side and is strapped to the firewall behind the exchanger. The rest of his set up is very similar to what Ciper suggests.
He is using a pair of tranny coolers. They are B&M units model#70266. You can find them at www.Jegs.com , a muscle car mail order house, for $59.99 each. They are rated at 28,000 GVW and are 11"x8"x1 1/2". I haven't taken the time to measure the fit on my Legacy yet, but he did not have to cut anything on his car. But he has also removed his AC. I have a hardcopy of the Jegs catalog and there are some thinner units that may be more appropriate for someone with AC.
For a pump he is using a marine unit that he got from http://www.autoperformanceengineering.com/ It is listed under syclone/typhoon intercooler pumps. He uses the cheap $55 Johnson one.
In his car it is mounted inside the driver side bumper right at the bottom corner. All his pipes run low along the frame and out of sight once they leave the exchanger.
I will be using his set up as the basis for my AWIC on the EJ20G using the stock exchanger. My pump will be mounted higher because I have the stock piping/brackets that are attached to the driver's side intake manifold. I am likely only using one of the tranny cooler's on this car as it will "only" be 240-250, as opposed to Marc's which is close to twice that.
But then he assures me his set up is safe up to 600hp, so I think I will do alright with half as much cooling. I will do a more complete right up along with pictures, in a new thread once I get all the parts, take measurements, etc. But I just wanted to put some info out there for folks who may be waiting for a bit more guidance before diving in with their own set ups...
![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Do you have pictures of the brackets for the AWIC?
Check this out - Grassroots Motorsports has an article this month on 'Waterless Cooling' for a Mustang. Its about a coolant substitute put out by Evans called NPG (non-aqueous propylene glycol). The boiling point is 369 deg (375 for a version called NPG+) and the surface tension is half that of water. The only issue in upgrading a cooling system seems to be a lower pressure cap and a larger expansion tank, although they also recommend a higher flow pump. For an AWIC I think the expansion tank and cap would not be a concern since it doesn't get hot enough.
www.evanscooling.com
- quasi-mod-o
I can take pictures of the brackets and post them some time over the weekend. They are basically two aluminum pipes that are about 14" long and 1" in diameter that are parallel to the ground running from the AWIC toward the radiator...
Suby Hai!
Suby Hai!
Forgot to mention, I saw a EJ22 air/water intercooled Impreza L at the I-club Buttonwillow track day, but it was using an oil cooler of all things in the trunk to cool the water. Took some pics ![Smile :)](./images/smilies/icon_smile.gif)
http://community.webshots.com/photo/128 ... 2581iBkDQB
http://community.webshots.com/photo/128 ... 7048awaDZx
http://community.webshots.com/photo/128 ... 7563NbTeHx
- quasi-mod-o
yep,
he's even got the brackets and piping on the driver's side manifold that I was talking about, which BTW, I totally misdescribed the sizing last night. They are more like 1/2" in diameter...
Suby Hai!
Suby Hai!
How about something like this:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=43972
I also found a pump at JCWhitney that'll pump 3.2gallons a minute. Which is about 12.3liters a minute. Would that be sufficient? Im thinking of getting this 2 radiator setup, and having them mounted inside the bumper, or under the bumper, kinda like a front mount IC.
-Brian
-Brian
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
1986 Toyota 4Runner
By the way, be careful with cheap pumps. I personally wouldn't get anything but a centrifugal type pump. The other kinds can howl so bad it'll drive you up a wall. The website floating around about one guys AWIC install says the first pump he used was louder than his entire car and was quite creepy.
- quasi-mod-o
Brain,
The flow of the pump you have found is the same as the one that Xephyr recommended to me, and it is pretty quiet from what I heard, but then he does have it buried in the bumper.
As for those Motorcycle coolers, I couldn't find any dimensions. I would worry that they were too small. I am also wary of buying something used for that particular piece just because I am superstitious like that. Many folks buy them used and have no problems. I just like to do it right once...
Suby Hai!
Suby Hai!
