Installing JDM AWIC
Installing JDM AWIC
Does anyone know what parts (OEM or aftermarket) would be needed to install one of these in a turbo car? Could anyone from Australia dig around in parts books?
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon & Hardtop
1987 & '87.5 RX coupes
1987 RX Type-RA
2002 WRX sedan
2019 Outback 2.5i Limited
1987 RX Type-RA
2002 WRX sedan
Dont waste your time to install it in stock fashion. The only part I plan to use is the heat exchanger. Everything else will be custom made.
Off the top of my head:
Coolant lines
Turbo to heat exchanger tube
Heat exchanger to intake
Pump
Reservoir*
Radiator
*Im adding the extra water to increase the amount of buffer time I have. If sized correctly your intake temperature will stay level throughout your run.
Coolant lines
Pump
Reservoir*
Radiator
arrgg
I found an upgrade radiator for the AWIC on the MRT website (wish it was easier to tell what the part was). anyway, i had an oil cooler set aside and Im starting to think it will be waaaaaayyyy too small! what are you using?
1987 RX Type-RA
2002 WRX sedan
1987 RX Type-RA
2002 WRX sedan
Yeah I saw that. They have the origional sized one and an upgrade. I couldn't tell a difference between the two though.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
Re: Installing JDM AWIC
all you need is acarfreak85 wrote:Does anyone know what parts (OEM or aftermarket) would be needed to install one of these in a turbo car? Could anyone from Australia dig around in parts books?
*water pump (about 15ltrs/minute will do)
*a radiator (heat exchanger) approximately 600mmx300mmx15mm with 2 30mm hose outlets
*the intercooler itself
*and hoses to connect the intercooler to the radiator (heat exchanger)
*then contact AVO in japan or Australia and get a samco silicon intercooler pipe to get maximum airflow.
PM me with your email address and I'll send pics of the stuff you need.
pics please
please do send me some pics! my email is car_freak85@hotmail.com
1987 RX Type-RA
2002 WRX sedan
1987 RX Type-RA
2002 WRX sedan
because I have an Australian RS it needs no modification because it comes standard on our cars. will take some pics this afternoon, its not mounted in the car anymore however, I have a FMIC ![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Do we need a smaller bumper beam to fit the heat exchanger? Are you sure, have you measured it up?
2014 Volvo S60 T5
2014 Volvo S60 T5
PN
Can we get a part number for that bumper beam? Maybe SOA can still get them for us. Also PNs for the mounting brackets would help!
1987 RX Type-RA
2002 WRX sedan
1987 RX Type-RA
2002 WRX sedan
i'd have to take the front bar off to find out
maybe somebody on www.rslibertyclub.org/forums might be able to help. sorry.
![Embarassed :oops:](./images/smilies/gear_oh2.gif)
Get/make one that works like a water heater. Dont just allow the hot water to mix directly with the cold water. For example I plan to put a baffle horizontal in the middle and have the inlet on the top left and outlet on the top left. This keeps "hot" water flowing at the top and "cool wate flowing out the bottom.
Since space is limited think about battery location or using a smaller battery like a Hawker Genesis branded Dynabat (meant for boss hoss motorcycles and such). I havent decided but I will probably run two of these hiddin under the rear seats or in either side of the rear quarter panel.
Im 100% serious. Im tired of looking around, ive been doing that for months already... Im ready to get this thing on, now. I want to know EXACTLY what people are using, with specific part numbers for those items and web sites or stores that I can buy it at, so I can go out and get one rather than spending hours and hours trying to find the thing and end up with squat.
