What type of intercooler?
I think his point was that you could move it if you wanted and replace the lines. The heat exhanger isn't required to be up front in all reality.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
teaguespeed
boostjunkie
rsstiboy: It doesnt matter if I have seen it or not. You dont understand that none of us plan to install the entire system as it was in Australia. We only plan to use the heat exhanger attached to the throttle body/turbo and all other items are custom. I could run the lines horizontal across the front and enter the engine bay through the fender well wiring hole.
There is no advantage and it would actually be harder to try to use the stock setup (pump and radiator). Everyone will create their own hose routing, resovoir and pump when installed.
boostjunkie: Exactly, I didnt intend to mean run it outside the vehicle but if you wanted all out cooling ability mounting it between the sunroof and windsheild would be a great place!
I actually plan to use two heat exhangers. One is a Legacy heater core, very good design and compact. It wont be mounted on the front of the vehicle. The other radiator will be mounted in front of the AC unit.
Were are you going to mount the heater core Ciper?
2014 Volvo S60 T5
2014 Volvo S60 T5
Yeah I do. I asked someone and they said so already.
Seriously though, which part of my statement did you not agree with? You plan to use the pump or radiator from the original system? The radiator is tiny, and how will you control the pump speed? How much is it going to cost you to get an OEM pump, which doesnt pump enough water and is more prone to fail compared to the aftermarket units?
No, you don't speak for everyone, sorry to burst your bubble. It doesn't matter what part i agree or disagree with, don't assume you are all knowing.ciper wrote:Yeah I do. I asked someone and they said so already.
MK
1992 BC672 AWD 5MT
JasonGrahn
