Page 2 of 2
Posted: Thu Jun 03, 2004 5:53 am
by eastbaysubaru
Posted: Thu Jun 03, 2004 6:29 am
by evolutionmovement
You mean you want it flush with the outside of the trim, then. Because the trim on mine is flat and contacts perfectly with the piece I added. So either I was misunderstanding the gap you meant or they changed the trim a little.
Posted: Thu Jun 03, 2004 6:38 am
by BAC5.2
Mine is beveled in slightly to a straight drop off. There is a noticeable gap that you can see in the second 2 pictures I posted. A dead flat meet to that bezel just wouldn't look good IMO. My glassed panel won't look OEM, but it'll look like nothing was ever there.
Posted: Thu Jun 03, 2004 4:00 pm
by Kelly
evolutionmovement wrote: What about the drying time?
If you mix it hot, i.e. lots of hardner, and use a heat gun, the stuff will almost totally harden in about a half hour.
Im not quite understanding the reason to fiberglass this peice, I think Im gonna make mine outta stainless, but hey, its good practice right?
nice work mang.
Posted: Thu Jun 03, 2004 7:57 pm
by BAC5.2
Thanks man! Yea, the reason was mostly for practice.
Posted: Fri Jun 04, 2004 3:23 am
by BAC5.2
I don't have time to take pics right now (about to go to a movie), but I got the body filler done and everything is sanded. I'll probably prime it when I get home from the movie and paint it in the morning before I go to work.
Looks friggin awesome, if I do say so myself. It's smooth as a baby's ass, and looks like nothing was ever there. I don't know what I would have done if I didn't have a 3-D orbital sander though. That thing saved my arm.
Posted: Fri Jun 04, 2004 3:30 am
by IronMonkeyL255
If you don't want to use fleece, Wal-Mart also carries Bondo fiberglass mat and fiberglass cloth.
I have been looking around for fiberglass supplies, and so far Wal-Mart is the cheapest.
I'm planning on doing a larger hood scoop later this summer, since I will need it for the intercooler.
Posted: Fri Jun 04, 2004 5:13 am
by LaureltheQueen
oh man... i just had an epiphany.... I could mount gauges INSIDE my 1.5 din pocket.... That way they'd still be stealth, but easily accessible
Posted: Fri Jun 04, 2004 5:34 am
by eastbaysubaru
Sure could Laurel, but I'd try to flip the pocket upside down so the lid wouldn't be in the way when you wanted to look at 'em. That might interfere with the shifter, but since it's an auto, maybe not.
-Brian
Posted: Fri Jun 04, 2004 5:35 am
by LaureltheQueen
hmmm..... i'm going to put some serious thought into this....
Posted: Fri Jun 04, 2004 5:43 am
by Yukonart
Not only that, but having the lid open/down would block the head unit, if it's even moved to the lower DIN position.
Posted: Fri Jun 04, 2004 8:04 am
by BAC5.2
Meh, I like my method better
Pre-priming coat...
Posted: Fri Jun 04, 2004 3:25 pm
by Brat4by4
Ok, now I see what you are talking about. That is going to be a beast to drill a hole into to mount gauges.
Posted: Fri Jun 04, 2004 8:56 pm
by LaureltheQueen
okay! NOW i understand it a bit more.
Posted: Sat Jun 05, 2004 12:32 am
by BAC5.2
Have a little faith in a guy, lol. Layed the first coats of paint, and I can see a few divots that didn't get filled all the way. Back to the sanding block.
