What do you feed your car? (oil and gas)
napphappy
Post by napphappy »
Royal Purple 10W-30
Chevron 92
Manarius
Post by Manarius »
Castrol 20w-50 (Keeps her from spewing her fluid)
Exxon 87 gas (She likes Exxon/Mobil the best..Sheetz and Giant gas goes through like water)
tris91ricer
Title Whore
Post by tris91ricer »
I used to go with some mid-grade stuff, when we were an NA 4eat; pennzoil or quacker state 10w40 or 30 --whatever I felt like-- dollar store rear diff 80w90, and dexron mercon3 at fluid. I topped off with 76 or ampm's 89.
Oh, those were the days. . .
Since the swap, I've been running mobil1 full synthetic 10w30, redline 75w90, and only twice have I used gasoline OTHER than Shell's V-Power. I think we're in good shape with this combo.
I am soon also switching to a better brake system, which would get ATE Super Blue.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Bheinen74
Post by Bheinen74 »
castrol GTX 10w-30, Genuine Subaru oil filters, every 3000 or less.
premium from Amoco, Conoco, or Citgo only.
I stay away from crap stations, which tend to have moisture/water in their gases, learn from others mistakes on that one.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
NuwanD
Post by NuwanD »
Oil: Castrol GTX 10W30
Gas: Used to run 94, but then realized that the time I drive the car the hardest is in an area with only 91 available... 91 it is! :)
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
2000 Impreza 2.5RSC (Supercharged)
1990 Rover Mini 1000
Busdriver
Post by Busdriver »
does anybody use Castrol GTX 10-30 High Mileage??
I put it in last time.
Is it better for engines with over 175k miles??
or just stick with regular GTX?
noticed most people are using Castrol GTX, I've used this oil exclusively on my vehicles...
blew two VW motors and I still use it....
Stock 1991 Legacy L+ AWD 5MT wagon 191k+ mi
0perose
Post by 0perose »
castrol, quaker state, pennzoil, whatever's on sale... 5w-30 for winter
87 octane unless I'm feeling rich baby!!
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
NICO
Post by NICO »
im going to say like douglas vincent
chepest oil, 10w30 every month becuse i all so like my motor.
for the tranny and diff only I MEAN ONLY 80w90 cheap stuff, i change it twice a year becuse i love my 5mt and diff
spark plugs i change 5 times a year, ngk copper works the best, no dout about it.
for gas 94 octane sunoco gold (canada has diffrent gas becuse you will FREEZE your nuts), air plane full some times 120octane, becuse i live next to a air port and like to see very high boost levels.
NICO I WRX U wrote:for gas 94 octane sunoco gold (canada has diffrent gas becuse you will FREEZE your nuts), air plane full some times 120octane, becuse i live next to a air port and like to see very high boost levels.
You are making sure the avgas you put in is leaded free aren't you?
The Scooby
Post by The Scooby »
rallitektech wrote:Kendall GT1 , I swear by the stuff
exactally, kendall GT-1 10W30, w/ dealer filter or napa gold filter
always premium fuel, 92 around here, and lucal fuel injector cleaner or sea foam every other oil change
1986 GL wagon
EJ'ed and Lifted
greg donovan
Post by greg donovan »
the SS gets:
mobil 1 5/30
91-92 octane.
the L gets:
mobil 5/30
87 octane.
both get subaru filters.
the SS has GM syncromesh in the trans
and the L has the new subaru ATF fluid in it.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
NICO
Post by NICO »
Legacy777 there is no lead in my gas, in canada they give us this extra stuff for our fuel lines so they dont freeze. its like octane booster shit same thing.
dzx
Post by dzx »
I think he's talking about the aviation fuel you said you put in sometimes.
///M
'93 Legacy SS - part out
NICO
Post by NICO »
o no its unlead, i got it now. no i mix it a little bit with my 94 gold.
Impregacy
Post by Impregacy »
oil: regular penzoil 10W30 for all seasons. i like the high flash point of penzoil, which tells me they use a high quality oil in their manufacturing process.
gas: Even though my car has the legacy ss engine i still use the cheapest 87 octane i can find. - the boost is set to wastegate and i never dip into the boost much anyway, because the clutch just slips when i do that.
Busdriver
Post by Busdriver »
What is the exact oil quantity needed, the Chiltons manual doesn't have amount #'s
Bheinen74
Post by Bheinen74 »
Busdriver wrote:What is the exact oil quantity needed, the Chiltons manual doesn't have amount #'s
about 4.5 qts, with filter change.-turbo model.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
92whitelegacy
Post by 92whitelegacy »
Oil: mobile 1 full synthetic(all the previous owner's used it) 10w30 is in it, To slow the leak onto my up pipe :( changed every 3-4000 miles. along with fram filter
Fuel: Wawa 93 octane or 94, what evers the highest. But come spring and maple grove opens, Or for the FD&SPD, its time for some 110 octane race gas for a track day whoa baby! :shock:
Plugs: denso iridium's (iridium is the WTG)
And i had some BG 44k through it when i bought it :P
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
Busdriver
Post by Busdriver »
Thanks Bheinen74, that's what I figured.
I don't have a level spot where I can do an oilchange. I put almost 5 in last time and it's a little too much...
EXP1787
Post by EXP1787 »
For my '95 L:
Mobil 5W-30 + Bosche filter
'87 Octane
'95 Legacy AWD Wagon
'90 Mazda Miata- STS2 Prepped
