What do you feed your car? (oil and gas)
dscoobydoo
Post by dscoobydoo »
Ok, being the car fanatic I am, I read up on the oils, and the RON ratings ( octane) and I like to be nice to my cars.
For a generic Motor oil, I have tended to use Castol GTX in 10/30. I used to go 10/40, but after some more reading, I will no longer do that.
If I had the money, I would go Amsoil or Mobil 1 10/30.
As for Gas, I always Use the 92/93 and I throw the octane crap in most often.
And fuel injector cleaner every other oil change.
I also change oil every 3000 (give or take 50 miles) with no exception.
So, does anyone go above and beyond?
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
morgie
Post by morgie »
Why don't you try the 10-40 oils ?
I personnaly use Motul 8100 5w40 winter (but should try the 0w50)
For gas, only 91 available here so.. no choice :|
morgie
'98 4Runner V6 Manual 4x4.
douglas vincent
Post by douglas vincent »
Cheapest 10w30, cause I tend to change it every thousand miles, like my engines.
As for gas, I use 92 octane with a gallon or two of tolulene, THAT is octane booster (114) , dont bother with that off the shelf crap.
Post by BAC5.2 »
Oil: Castrol GTX 10W30
Gas: 93/94 depending on what area I am in.
THAWA
Post by THAWA »
pennzoil regular
87 octane
morgie
Post by morgie »
douglas vincent wrote:Cheapest 10w30, cause I tend to change it every thousand miles, like my engines.
Why don't you try and build a stronger base ?
:? :D
morgie
Kelly
Post by Kelly »
Kendall GT1 , I swear by the stuff
Redline Synthetic in the gearbox, but I wish I had stuck with Dino.
I run the cheapest super I can find. My car runs so rich, pinging is rarely a problem.
Mobil 1 and no detectable internal wear after nearly 250k mi. However, I should have used something to clean the conbustion chambers out more as the carbon build up likely melted my valve.
Running 8:1 compression N/A I use the cheapest gas there is.
Post by BAC5.2 »
I've gone 83 miles on 1/2 tank so far :) 8:1 compression and no hooked up O2 sensor. I'm probably beating Steve!
If you are interested in gearbox too, I am using Redline 75W90NS synthetic. It's great.
IronMonkeyL255
Post by IronMonkeyL255 »
I use valvoline Max life and change it every 3000 miles.
As for gas, I usually use the cheapesy stuff I can find. I think I may be running rich, and I get crap gas milage. Every now and then, I'll run through some lucas oil fuel additive.
Rio Red '91 Legacy SS
boostjunkie
Post by boostjunkie »
Castrol GTX 5w30 every 3-4000 miles.
93 octane (damn compression!!)
ngk v coppers every 5000 miles
Full Sea Foam treatment every 10,000 miles
Brat4by4
Stratified
Post by Brat4by4 »
Castrol Syntec 10w-40 (Previous owner used it)
Highest octane available at pump. 92-93-94
The extra $0.60 per fillup is worth the peace of mind.
dscoobydoo
I also have redline 75/90 in the diffs.
Read this: http://www.micapeak.com/info/oiled.html
This is why you should not use 10/40
05 GD-STI
00- GF
legacy92ej22t
Post by legacy92ej22t »
Mobil 10-30
94 octane
I will be running Mobil 1 after I rebuild my blown motor. I'm going to replace every seal. :)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Post by BAC5.2 »
boostjunkie wrote:Castrol GTX 5w30 every 3-4000 miles.
You do your plugs every 5k and sea foam every 10k in the Celica? Good lord!
boostjunkie
The plugs I do in every car every 5000. SeaFoam would be every 10-15000, depending on my laziness.
skid542
Post by skid542 »
I change oil every 3000 (usually a hair over) and use Havoline Max Life 10W40. As for gas, I'm just using regular 87 unleaded. It works just fine for my NA. I also try to change the air filter every 6-7 too. Plugs...I'm lazy and don't get to very often.
Lee
scottzg
Post by scottzg »
Wait wait. We have to change the oil? Oops....
Post by entirelyturbo »
Valvoline dino oil 10W40 every 3000 miles in both cars.
89 octane in the Legacy, 93 octane in the XT, wherever it's cheapest.
The cheapest, junkiest dino gear oil I can possibly find in both my gearboxes. Redline 75W90 in my diffs.
*Formerly DerFahrer*
EJ22_SLO
Post by EJ22_SLO »
Shell Helix Plus 5W40 - every 10.000km; 95 octane gas (and 98 from time to time); EJ22, 1990, 255.000 km
J-MoNeY
Post by J-MoNeY »
I feed mine cookies and milk. Runs like shit.
98 LGT
illnastyimpreza
food for thought
Post by illnastyimpreza »
in my 98 RS, mobil one 10-30 , redline 75-90ns in the tranny and rear diff (the shit works AWSOME) and for now...87octane...till the ej22t goes in. Then its 94 all the time.
my 91 L wagon, mobil 10-30 and 87.....89 and some octane boost after I do my frankenstein swap.
It's all about the power to wait ratio
98 Impreza RS
91 Legacy L wagon
def09
Post by def09 »
Redline 5W30 engine oil, 75W90NS for the diffs and Redline injector cleaner or BG 44K injector cleaner for the majors. Mostly Costco 92 gas, but she likes Chevron the best.
Subtle
Post by Subtle »
Motul synthetics in front and rear diffs and in the recently re- built 4eat.
Pennzoil 10/30 in the engine every 3 months.
With over 170000 miles no need to add oil between the changes :-)
Post by 555BCTurbo »
+1 to that...
I use Mobil 1, and change it about every 5-6,000 miles. It usually comes out brown still, as my motor does not have a whole lot of blowby.
Tranny has GL4 + 1 qt of MT90
I use Chevron or 76 92 octane...never a ping
