Why I like the manual over the 4EAT
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
lol, when you took driver's ed, wheels were a novelty
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
I only use 3 o' clock with my left hand. KnowhatI'msayin'? W3rd.
THAWA
Post by THAWA »
That sounds incredibly uncomfortable. Unless that was some kind of sexual innuendo. In which case I ddin't get it.
LaureltheQueen
Spelling Nazi
Spelling Nazi
gangsta lean
Post by BAC5.2 »
LaureltheQueen wrote:gangsta lean
Gotta Keep it Gangsta.
The front diff in the 04 STi is a clutch type? Wtf? Why?
Who makes the front diff for the 05? Is it still a Tractech unit?
Also, what is the love for the clutch center diff all about? I don't think I fully understand. Is it just because the car can constantly transfer power from front to rear depending on traction availability?
The electronically controlled clutch center diffs react instantaneously once a speed difference is sensed. The viscous coupling does not.
Post by BAC5.2 »
But clutch type center diffs have a hard time putting down lots of power, don't they?
The greater the speed difference between the front and rear, the less resistance the clutches have. The less the speed difference, the more resistance the clutches have.
That's what Ciper said.
I'm not sure exactly what ciper said, or which setup he was referring to, but I know in the new VTD 4EAT, it has a center diff, which is essentially an open diff, that distributes power 45/55. It then uses an electronic clutch pack to lock the outer and inner gears together to give 50/50 split.
I'm not really sure how the STi setup works, but it's probably similar to the setup I mentioned above.
Post by BAC5.2 »
I think he was talking about the older clutch style setups, like the 4eat's in our cars.
Allwheeldrive
Post by Allwheeldrive »
I'm no expert but you don't find a lot of manual racing machines at the track. Of course, most high hp autos only have one or two gears. Auto LSD seems to me to be prefferable to 5mt shifting unless you're talking about serviceability.
Randy
scottzg
Post by scottzg »
Allwheeldrive wrote:I'm no expert but you don't find a lot of manual racing machines at the track. Of course, most high hp autos only have one or two gears. Auto LSD seems to me to be prefferable to 5mt shifting unless you're talking about serviceability.
You're just talking about drag, right?
scottzg
Post by scottzg »
auto lsd = poorly controlled and understeery imho.
Allwheeldrive
Yes, I am talking primarily about drag racing but also stock cars, monster trucks and street cars. Maybe the 4eat isn't the greatest but some auto trannies weigh less and have lower rotating mass. You think auto LSD is understeery, maybe so I guess?
Randy
Post by BAC5.2 »
You see more manual transmissions in motorsports than full automatics. I still consider a sequential box, a manual transmission, since there is no automatic override.
And, for once, I agree with Scott. Auto lsd = understeer monstAr. Nothing arcs like the 5MT Legacy. Balanced and predictable.
scottzg
Post by scottzg »
BAC5.2 wrote: Nothing arcs like the 5MT Legacy. Balanced and predictable.
And understeery. :lol:
Post by BAC5.2 »
I should clarify. Nothing arcs in the snow like the 5MT AWD Legacy.
My car is probably significantly different in the handling department than many other Legacy here (except Josh's). I can predictably rotate the car in any number of ways, with little trouble of understeer.
Yeah....if you setup the suspension correctly, and have a little bit of power behind things, rotating is not a problem.
scottzg
Post by scottzg »
Legacy777 wrote:Yeah....if you setup the suspension correctly, and have a little bit of power behind things, rotating is not a problem.
It's impossible with mt legacy awd.
dzx
Post by dzx »
I like the launch of the 5mt
///M
'93 Legacy SS - part out
Nomake Wan
Post by Nomake Wan »
But Josh has a M/T AWD Legacy, and he's the one who said that. o.o;
[url=http://www.cardomain.com/ride/762395]1990 Legacy L (Sold)[/url]
[url=http://www.cardomain.com/ride/2564067]1992 SVX LS-L[/url]
[quote="LaureltheQueen"]I like my automatic, it's fun to drink coffee and smoke civics at the same time[/quote]
Nothing's impossible.....and I have a mt legacy awd....
I'm not saying I can do a rear wheel burn out and slide sideways....but I've goosed it going around a sharp corner and had the rear end come loose. I really don't have enough power to play as much as some of you want.....so I can't really say I can do it all the time and on command.
I suppose if I made my rear agx's all the way hard, and the fronts all the way soft.......I might.....but I think that's stupid....
Post by BAC5.2 »
I have a mt legacy awd, and can get the back end to step out on-power, in the dry. I'm sure it will be even easier when my suspension is done, and when the LSD is in.
I can't do rear wheel burnouts, but I can bark them off the line when I get into it, and if I'm in the powerband, I can kick it out, pretty much at will.
Even "slow" Legacy's can do it. You, yourself, posted a thread about lift-throttle oversteer. Lift throttle mid-corner and the rear will come around.
scottzg
Post by scottzg »
I also happen to have a mt awd.
The only time you can get on-throttle oversteer is when the turn is tight enough that the front wheels are completely tipped on their sides. "Parking lot oversteer," Sub 15 mph. I'm pretty sure that big rims and lo-pro tires exacerbate this phenomenon.
with half the power routed to the front, there is no way the rear wheels will lose traction first, without intentionally handicapping the fronts. Since a LSD increases rear wheel traction it will increase on-throttle understeer.
You're new suspension is for a gc, right bac? That will lend itself to understeer as well.
legacy92ej22t
Post by legacy92ej22t »
The thing that can be scary is the way the rear end will sometimes "snap" out. If you load the suspension real hard in a long tight corner I've found that sometimes the rear end doesn't simply break loose but will actually snap out violently.
I've never really had that hard a time getting oversteer. If you really want it, you can get it. :)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Post by BAC5.2 »
Scott - It's all about weight transfer, power just helps.
Think about it. Blast towards a turn, on boost, WOT. Snap the throttle shut, weight dramatically transfers forward, turn in, and the rear will float out. Stay off, wait for the "float" feeling, then hammer the gas to pull out. That's lift-throttle oversteer.
Power-on oversteer is just a matter of good suspension and weight transfer.
My coilovers are for a GC, but the spring rates are matched front to rear. The GC strut length is the same as the facelift BC, with the same spring perch heights and everything. And just like the Legacy, the spring rates are matched. They will be fine.
I've actually done this, as have others, so I don't think your right, thinking that it's impossible.
