my official ej22t---impreza swap wiring thread
Hmmm....sounds sounds really screwed up.
Remove the connector, and perform the resistance tests from the scans
http://www.main.experiencetherave.com:8 ... sting1.jpg
http://www.main.experiencetherave.com:8 ... sting2.jpg
See if they are around where they should be.
We need to try and narrow down the issue to the TPS or ECU/wiring.
Natoe
Post by Natoe »
k yeah i have done most of those tests on them, (i have 2 TPS's now) and they BOTH when doing the signal wire test go from 14ish volts down to around 1V through the sensors full motion instead of 4.7-1.6V. is that because i had the sensor not connected to the car?
either way, when i have either on the throttle body, and i test the voltage, it reads 5.1V and goes down to 5.02V...
i measured the wires resistances (supposed to be 1 M ohm minimum) and they were all fine but the ground wire which was less than one. ive checked continuity through the lines and know its all hooked up. in addition, the line is sheilded almost all the way to the sensor from the ECU.
ill do some more tests to see, but i have a feeling i installed it wrong or something, and that the original one was off as well because both sensors are acting exactly the same. i made sure pins 2 and 4 had continuity at .7mm and not at .9mm.
thanks AGAIN, im dieing here haha
Your wiring is wrong. I don't know what you have mixed up...or at what connector, but it's wrong.
From the tests, it sounds like you have the battery and reference voltage messed up.
Do this for me. With the key in the ON position, remove the connector from the TPS, measure the voltage at each pin on the TPS connector (ECU side...NOT the throttle sensor). Post the results.
Make certain you are orienting the pin correctly, so you know which is pin 1 and which is pin 4.
Here is another pic of the TPS sensor and which pins are which. The pin #'s are if you are looking directly at the TPS. So when you test the ECU connector, it will be a mirror image.
Natoe
Post by Natoe »
i will do that next time i get back into the garage (im at the dorms now but my home is 3 miles away)
while i was out there, i checked the resistance between all the pins on the connector and a body ground, and they were all greater than 1 M ohm, except for the power wire... thought id throw that out there, thats all ive got till i can get back home in a couple days. (i know it has 5V though)
thanks
Apparently I forgot to post this pic
http://www.main.experiencetherave.com:8 ... ns/TPS.jpg
Which pin are you talking about? Please use the associate TPS pin #. This is adding to the confusion.
According to this diagram
http://www.main.experiencetherave.com:8 ... g_diag.jpg
and the instructions on here
pins 2, 3, & 4 should be greater then 1 M ohm. Are you calling pin 1 the power wire?
See what I mean....way too much confusion
Natoe
Post by Natoe »
sorry i apologize i WAS reading them upside down and therefore confusing the hell out of the both of us..
i havent been home yet, but when i was the resistance on
pin 1 was >1 ohm,
pin 2 was >1 ohm,
pin 3 went down to 0.01 :!: :!: ,
and pin 4 went to 1.01 ohm
so im curious about pin 3, the power wire
I don't know.....
Natoe
Post by Natoe »
turns out the sensor ground wire wasnt grounded so great, but just enough to kinda work... :P so i grounded that and the TPS works now. my 02 sensor is gion crazy now, i think i wired it up right, (im using the 1.8L O2 because the other one doestn work) and i get anywhere from .2v to 1.4v and im nto sure if thats right. it changes very rapidly, (through the scantool)
now it "idles" rough but the rpms climb up to 3k unless i tap the gas it goes down and almost stalls, then starts climbing again... i get 40% IAC, but i think that it might still be the problem.
sorry for the length, the bbs has been down for me for almost a month :O and now i can finally post again.
Natoe
Post by Natoe »
also, is it regular for it to be at about 35deg timing advance, and when i touch the throttle just a tad it jumps to like 50deg?? that doesnt seem right either and i have no idea why it would do that
Natoe
Post by Natoe »
alright alright, so today i fixed a vaccum leak, and started to think that maybe only my idle is messed up. it still goes right around 2000 for a while and then bounces between 1500 and 2500. i hooked up my laptop and was watching timing advance and went for a drive... ~40-50deg when free revving (sounds way too high) but i drove it around the block and when i got into boost at all the timing dropped down to 19 deg which sounds correct.
it even pegged at 9psi pulled great and smooth, i can give it part throttle and it doesnt hesitate/buck! this means all the sensors are finally working right including the boost stuff (thanks again tyler!) except for my IAC that came with the engine might be giving these idling problems (or maybe from me taking off the TPS). there is a clicking flutter sound coming from the turbo when im in boost, but im hoping its just my header heatsheild or something rattling.
anyways im pretty happy that ill be able to start the AWD swap soon, i just hope that it IS actually running safely.
more diagnosis tomarrow
