IAT and the Next Level G-Box
-K-
Post by -K- »
Are they the self ported kind of piston?
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
Aaron's ej22t
Post by Aaron's ej22t »
engines whether turbo or not, like to run at a certain temp. if you change that too much, then the car can act weird. if you want it cooler, don't get a lower tstat, but rather a good flush, water wetter fluid and an oil cooler. a good intercooler would help too.
92 Legacy Turbo \ 5MT \ Silver
Post by entirelyturbo »
Legacy777 wrote:if you've ever replaced the t-stat with one that is not OEM......you'll know what I'm talking about.......They cause issues......the aftermarket ones are not as deep, do not offer the same resistance to temp change as the OEM one....the OEM one opens more.
I'm also going to theorize that the OEM ones are fail-safe, which means if they fail, they will at least stick open so the engine can get coolant. If it's not fail-safe, it might stick closed and your car will overheat :shock: .
My car warms up about twice as fast now as it did with the old one, so I'm wondering if my old one was stuck open...
*Formerly DerFahrer*
