Posted: Tue Mar 13, 2007 1:23 am
Lee,
ET is the offset. The Speedlines have a 50mm offset. The OZ's have a 48mm offset. That is from centerline of the wheel to the centerline of the hub. 50mm offset on a 7" rim is pretty good. Stock WRX has a 53mm offset on a 6.5" rim. My Forester wheels have a 48 offset on a 6.5" rim.
The Speedlines do NOT clear Brembo's. I am not sure of the OZ's do or not. They DO clear ALCON's Gravel brakes though, which use a 13.4" rotor. But those brakes are hella money.
If I get the speedlines, I'll have to run a 5mm spacer in the rear, and MAYBE a 5mm spacer up front (which would change offset to 45mm).
