Nope, I wasn't comfortable doing that. I wanted lots of clamping force on the IC and TB. I trimmed the pitchmount, "massaged" the firewall, "massaged" the hood, rerouted some of the harness, and routed the windshield wash lines internally in the hood.Did you have to cut down your throttle body opening to take issue to room for the IC outlet? I know it had to be done on the stock 22T throttle body (helped do it on Phil's/BAC5.2 car).
BIG NEWS... the stock WRX BOV vented to atmosphere is fine, my greatest friend, all props to CHRIS RAZL of toronto, in the world created a circuit like this for me to try:
note the V1 wire can be found on the B48 connector, Pin #9, as decribed here:
http://www.surrealmirage.com/subaru/fil ... _page1.jpg
Turns out the 440's are too big for my setup. 1/4 turn on the pot resulted in a massive change in the amount of vac required at cruise speed. 75mph was nearly 4psi, now its 15in of merc. The richness was causing me to open the throttle to maintain cruise, which in turn caused the turbo to spool.
I'm bleeding off probabaly about 5% of my MAF voltage. I'm getting Better throttle response, better idle, better cruise, and best of all, better torque at all RPM. It pulls like a TRAIN to 110mph. I get to scared to go any faster. And I plan to go no faster thanks. This maf bleed wont work for most, but for my setup it seems like I'm looking at some engine management hardware in the near future.
