Page 2 of 2
Posted: Thu May 15, 2008 9:19 pm
by Ej22TIM
after putting on the IAC I am now wondering where the line will run for the intake manifold? anyone know?
Posted: Thu May 15, 2008 10:55 pm
by dropdfocus
You're blocking off the IAC? I know you can block of EGR, but I wasn't aware you can eliminate the IAC... :?s
Very nice looking shop BTW. I am EXTREMELY jealous!!!
Posted: Thu May 15, 2008 11:07 pm
by Ej22TIM
I am not blocking off the IAC, that plate was on it from the previous owner, I put IAC BACK on lol.
thanks!
Posted: Sat Sep 13, 2008 11:18 pm
by Ej22TIM
Havnt updated the thread in a while, I got my pistons, and got my block bored and now I am just waiting for the block to get back (its getting assembled by a subaru tech)
I have the car painted flat black for now, and will be picking up a maf translator pro for management...
pics soon!
Posted: Mon Sep 15, 2008 5:08 am
by 93forestpearl
...and injectors...
Posted: Mon Sep 15, 2008 6:57 am
by wrxisthebest
so will 2003 wrx ej20 heads bolt right onto the ej22t without having to modify anything.. just plug spark plugs in and go?
Posted: Mon Sep 15, 2008 12:48 pm
by dropdfocus
Yup. You'll need EJ20 head gaskets to match though.
Posted: Mon Sep 15, 2008 5:33 pm
by BXSS
As I understand ANY Subaru EJ head will bolt up to ANY Subaru EJ block - but I'd think you'd have to use the H/G to match the block as the bores change with the displacement (I think WRX = 92mm pistons, while a 2.2 = 97mm pistons).
If you use the US WRX heads you'll need to do something for E/M as the trigger points on the cam gears are supposed to be different which will not allow it to start-up on the ej22t ecu.
To have a DOHC start on a ej22t ECU the heads have to be older versions like DOHC 2.5, EJ20G, EJ20H, EJ20K, EJ20R heads.
Posted: Mon Sep 15, 2008 5:58 pm
by 93forestpearl
Yes, you need a headgasket with the proper bore size. Also, paying attention to the thinkness is important on the 22T, sicne the pistons protrude past the deck by about .020".
You cannot just slap on WRX heads and go, as the triggeres are different between phase I and phase II motors.
Lastly, do some looking around the boards. Not just here, but places like nasioc are good resources. Anything you can think of has been covered many times over.
