SS and base model differences?
what huh
Post by what huh »
true true
thanks man
1998 Legacy GT-T ... sold
dropdfocus
Post by dropdfocus »
They are splined so they will only line up one way. Easiest thing to consider when putting them back on is if the hole on the shaft has a spline going through it or not.
Jason
jefferson
Post by jefferson »
I believe you will find that the hole in the stub and in the axle have a tapered entrance on one side. Both tapered ends go together.
Jeff
what huh
Post by what huh »
cool thanks for all the help guys
what huh
Post by what huh »
what about brakes?
rotor size?
SP-Boxer
Post by SP-Boxer »
smh0101 wrote:However, EDM tail lights do Not have any amber in them... So you have to put an amber bulb in.
Correction: ALL EDM taillights have amber inside them. In the 92, you can't see it from the outside, but it's inside!
94 is the same as your 93, with amber!
I'm 100% sure, my 92 EDM car has clear bulbs, no visible amber, and orange signal! :wink:
"I feel Legacy"
smh0101
Post by smh0101 »
Well, I had 92 EDM Tails and it had no amber, I had to mod them to accept the lights from my front corner lights.
legacy4ever
Post by legacy4ever »
SP-Boxer is right. smh0101, you've had the tails from me, and I removed the amber inserts long before and drove with amber bulbs in them.
So that's all, sorry for an off-topic "EDM taillights" :D
Ben
93MY EUDM Legacy EJ22
smh0101
Post by smh0101 »
Ahh, that explains it!
Mmkay, didnt know mine where modid... But they were in a very good way. You couldnt see amber at ALL!
what huh
Post by what huh »
what about the bushing that holds the back of the shift linkage up?
Is that different between the FWD and the AWD?
or did i put something on wrong?
what huh wrote:what about the bushing that holds the back of the shift linkage up?
That "should" be the same
what huh
Post by what huh »
actually they are not when i get my stock one that i just order in (stupid memorial day) i will post a picture. Because it is so much easier to show then tell
Yeah you're right. I was lazy before and didn't want to check the parts manual.
what huh
Post by what huh »
well i got real excited when it came in so i forgot to take a picture. The FWD one sits about 3/4" lower than the AWD which makes it touch the driveshaft.
And for the record also a FWD shift linkage doesn't work.
