TD04 + TMIC + custom pipes = complete kit!
Binford
Post by Binford »
wtdash wrote:So does the firewall need 'massaged'? Or does the modded TMIC take care of that too?
What's the good/bad of blocking off the PCV? Will it throw a CEL?
Firewall still needs some massaging. If you modified your throttlebody I'd bet there would be no massaging needed. Up to you.
It will not throw a CEL. The only reason I blocked that off is becuase I put breathers (like little air filters) on the valve covers to simplify things. No other benifit that I'm aware of. I actually re-did my hoses with a catch can and hooked it back up to the PCV after that pic.
Fatboy61717
Post by Fatboy61717 »
Is it still up for sale??
Binford
Post by Binford »
Fatboy61717 wrote:Is it still up for sale??
Yep.
Fatboy61717
What's the condition of the turbo. Does it have shaft play??
Binford
Post by Binford »
Fatboy61717 wrote:What's the condition of the turbo. Does it have shaft play??
Turbo is in excellent condition. Very, very little if any shaft play. I'm only selling it for some extra cash otherwise it would not be for sale.
dropdfocus
Post by dropdfocus »
C'mon guys, $300 is a good deal for everything you're getting here. Someone take him up on this offer already! 8)
Jason
greg donovan
Post by greg donovan »
dropdfocus wrote:C'mon guys, $300 is a good deal for everything you're getting here. Someone take him up on this offer already! 8)
i would have bought it the day he posted it if i had the money to spend on my car.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Fatboy61717
Where are you at will i have to come get it or would you ship it??
Binford
Post by Binford »
Fatboy61717 wrote:Where are you at will i have to come get it or would you ship it??
I'm in Detroit Lakes, Mn, zip code 56501. Tell me where you're at and I can give you a shipping quote if you'd like. 8)
Although I noticed in another post you are wanting to turbo a non-turbo EJ22. Since this kit is actually currently installed on a non-turbo car I can speak from experience that this is not going to be a quick job to undergo, especially if you have little to no experience with this stuff( I don't know how experienced you are). Here is a quick rundown of things:
First, you need turbo exhaust from the heads to the turbo. I used factory Legacy Turbo pieces becuase I had them. The water pumps are different between the cars so I had to grind away at the cast iron flange to clear the radiator hose/neck. The engine crossmembers are also different so I had to notch it out for the up-pipe to clear. This is about a 2"-3" notch in part of your main structure and most people are wary about doing something like this. I have absolutely beat the piss out my car, which includes all out rally, off-road, and jumping (repeatedly :lol: ) and have no signs of a weakened structure. My 0.02cents.
Second, you need oil and water to feed the turbo. Again, I used factory SS parts that I had and swapped heads. This gave me oil feed and return and also coolant return. I cheated and tapped into a heater hose for coolant feed, which is apearantly a no-no according to the majority on this board. Again, works for me. :?
Third, there is a sensor in the way of the turbo outlet (TPS?) that is different on the non-turbo cars. Once again this was no big deal as, you guessed it, I swapped it from a turbo manifold.
That is not the end of the list. That's just the main points. There are several small "issues" I'm sure you will come across that will need to be figured out along the way.
I am by no means trying to talk you out of buying from me, or from turbo-ing your car in general. I just think you should be informed of this stuff before you get in over your head. If you think you can handle it after all this, please, let me get you that shipping quote! :D
stef1825
Post by stef1825 »
Would yo sell everything else but the TD04 ?? (how much)
And most importantly would it work with a 16G ?? (the jdm sti one)
1992 Legacy Turbo AT
1994 Legacy turbo mt, 16G, TMIC, 10psi, TBE, BOV, 4.11 rear LSD .... and more :P
Binford
Post by Binford »
stef1825 wrote:Would yo sell everything else but the TD04 ?? (how much)
Yeah, I could. I'd say $200 would probably take the setup minus TD04. FCD also not included for that price but I'd throw it in for another $50.
Everything "should" be the same for the 16G, although if it has the 90 degree inlet cast into it you would need a straight connector instead of the rubber 90 I have. Someone correct me if I'm wrong. :-D
dropdfocus
No, you should be correct on that.
Jason
Binford
Post by Binford »
Update:
FCD sold!
Rubber 90 sold!
This current intake pipe and BPV adapter sold!
If anyone is interested in this as a complete setup as was originally posted I can make new ones to make it complete again. Otherwise turbo,y-pipe, TMIC is what's left.
Thank you!
RJ93SS
Post by RJ93SS »
can i see a pic of that y pipe, i'm stuck trying to do my 06 tmic install, or where can i get one fast and cheap?
