TD04 + TMIC + custom pipes = complete kit!
Binford
Post by Binford »
Check it out:
http://i39.photobucket.com/albums/e174/ ... 000151.jpg
Complete kit including:
TD04
WRX TMIC
MBC
custom steel intake pipe
rubber 90* boot
custom steel y-pipe
rubber throttle body hose
custom steel BOV flange
Note: TMIC not that shiny anymore.
Everything is in excellent working order and currently installed. I'm looking for $300 for the complete kit. Thanks.
Also have TurboXS FCD I'll throw in for another $50, or will sell seperate for $75. All prices plus shipping.
94SS_Canada
Post by 94SS_Canada »
good deal for someone with no time!
FastRust
Binford
Post by Binford »
Still available! :D
Dusty B
Post by Dusty B »
I'd probably snag this if I hadn't just picked up a ported/polished tdo4. It'd still be worth buying, but I'm kind of against the smashing of firewall/cutting of tb. Good luck with sale. nice to see a whole kit for someone!
Binford
Post by Binford »
Dusty B wrote:I'd probably snag this if I hadn't just picked up a ported/polished tdo4. It'd still be worth buying, but I'm kind of against the smashing of firewall/cutting of tb. Good luck with sale. nice to see a whole kit for someone!
Thanks for reminding me Dusty B! I have modified this TMIC so there is no cutting of the throttle body necessary! :wink:
greg donovan
Post by greg donovan »
man i wish i had some extra cash for this set up.
would there need to be changes made to the fuel system if the FCD was used and the boost cranked up the optimal setting for the tdo4?
OT, would you drive up to fargo for a rallycross in mid oct if it fit your schedule?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Binford
Post by Binford »
I ran 16-18 psi with this setup on my SS, which I'd say is on the "high" side of optimal :-D with the only "fuel system mod" being a Walbro. This setup is currently on my wagon running ~12 psi on N/A ECU, turbo injectors, and the Walbro.
Binford
Post by Binford »
greg donovan wrote:OT, would you drive up to fargo for a rallycross in mid oct if it fit your schedule?
As a spectator, hell yeah! As a competitor, I have nothing to drive like that. My wagon is undergoing an "offroad" transformation! :lol:
greg donovan
you going for the rockcrawler look now?
96 Impreza L sedan
00 Impreza RS sedan
Binford
Post by Binford »
More or less. :lol: Tubular sub-structures.......
And it's not for the looks, purely functional. :shock:
greg donovan
Binford wrote:More or less. :lol: Tubular sub-structures.......
function over form is the way to go.
i would love to be pusing 12 pounds of boost right now.
96 Impreza L sedan
00 Impreza RS sedan
n2x4
Post by n2x4 »
did you block off the PCV valve??
SUBARUEHS Racing
Binford
Post by Binford »
n2x4 wrote:did you block off the PCV valve??
Yes I did. :)
Spitfire999
Post by Spitfire999 »
Would you be willing to separate anything form this kit?
Ben
Binford
Post by Binford »
Spitfire999 wrote:Would you be willing to separate anything form this kit?
Ben
Depends on what it is, as this is tenitively pending......
Spitfire999
Looking for everything except the turbo and the intercooler.
Binford
Post by Binford »
I could probably make up some more of the custom piping........
Spitfire999
If you could make another 90 degree bend from the turbo and then that pipe that goes from that to the air box, I would be interested.
Ben
Binford
Post by Binford »
Spitfire999 wrote:If you could make another 90 degree bend from the turbo and then that pipe that goes from that to the air box, I would be interested.
Ben
The 90 degree piece is a rubber hose, but the "intake" pipe I could duplicate. You'd need to tell me what size nipples, how many, and where to put them. It's been a long time since I've seen a stock setup, and I know I deleted some of those hoses on mine. I could go so far as to get the rubber 90 for you if you chose. Let me know what you need and I could shoot you a price based on that. :D
Would anyone else be interested? :wink:
dkopp
Post by dkopp »
Ben
+1 for the custom steel turbo, I/C and block-off piping. And, if you're buying 90* elbows, i'd be in for that too.
Spitfire999
Yeah, I'll be doing some work on my car tonight (just shit coolant all over my driveway, I hope its just a hose gone bad :?), so ill let you know the nipple sizes/how many. But you should possibly start a separate thread, I would think there would be a big demand if you want to make a bunch.
Binford
Post by Binford »
Forgot to post it here, I did start a new thread:
http://bbs.legacycentral.org/viewtopic.php?t=36928
:-D
wtdash
Post by wtdash »
Sold?
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Binford
Post by Binford »
wtdash wrote:Sold?
Nope, still available.
wtdash
Post by wtdash »
So does the firewall need 'massaged'? Or does the modded TMIC take care of that too?
What's the good/bad of blocking off the PCV? Will it throw a CEL?
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
