Just to verify...
asc_up
Post by asc_up »
Ok thanks guys.
So what are your honest opinions? I'm not tracking the car at all, but I definitely wouldn't mind the car being stiff. I drove my friend's STi around for a day and LOVED it.
So do you think I'll "enjoy" having 20mm F/R swaybars? Or would it be worth the money and happiness to convert the rear linkage so I could run 22mm F/R swaybars?
asc_up
Post by asc_up »
And just to make sure, when Whiteline says that it's an adjustable 20mm bar, that means that is 20mm at its stiffest setting, correct?
You'll be happy with the 20mm bar.
If it's an adjustable rear bar, typically they will go 20-24 or something like that, depending on where you have it bolted to the bar.
