Wrecked
While doing a NA swap is cheaper, I honestly don't have the time or interest to have to swap just about everything over to have a functional car. I'll try to hold out till a turbo legacy pops up around my area... then swap over my existing parts (if needed).
'11 WRX Limited
'94 TW | R.I.P.
i know this may or may not be inapropriate, but would you be willing to sell me your rear reflector off your hatch???
Wow man, that sucks. Sorry to see that happen.
I understand the time and interest issues, but if you were to swap everything you can into a GC/GF chassis, you would LOVE the handling characteristics.
You have everything needed right there for a, say, 1995 Impreza swap.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
Today I started to contemplate having a body shop replace the left inner/outters sills (I don't have the tools / knowledge for welding) and then I could replace the doors/panels/others myself. I got both left doors opening up and the floorboards / tub doesn't appear bent at all. Although on my test drive, I noticed the C pilar was closer to the floor seatbelt and pinching it some :-S. No shop will give me any firm estimate without seeing the car -- even for the sill work.
I slapped on my stock 15" wheels and took it for a very short drive. It turns a lot quicker and sharper now. Easy braking the ABS goes off on the FR wheel. At a standstill, while facing the front of the car, I can tell the tops of BOTH front wheels angle inwards now... sort of like / \ instead of | |. Otherwise, engine/tranny/turbo seem ok -- as they should be -- was just body damage).
Tomorrow I'm considering driving 5mi on backroads to a body shop and see what they say...
'11 WRX Limited
'94 TW | R.I.P.
Purchased a 94 SS today from another board member. Previous owner said the radiator cracked on the highway and overheated -- exhaust / smoke now comes out the top coolant tube -- but still runs
Anyways after getting it towed home on a car carrier, I set to work. First order of business was getting the damn key to turn in the ignition since the old one was really worn -- most times I couldn't even unlock the damn cylinder. A new key cut from code helps a lot, but it's still has some issues. Will need a new lock cylinder in the near future.
Spent the remainder of the evening removing wires, hoses, bolts etc from the engine. Tomorrow out comes the dead engine. Then I get to repeat with the engine removal process from my 94 TW. Hopefully by next week I'll have all my bits swapped over to the SS. Damn this is a lot of work...
'11 WRX Limited
'94 TW | R.I.P.
