Wrecked
BSOD2600
Wrecked
Post by BSOD2600 »
On my to-do list for the next set of upgrades was replacing the RE92's with newer rubber and stiffen up the suspension, especially the rear. Tonight, both bit me in the ass after I got off work.
Going too fast around a left-turn gradual corner. Felt the end start to swing around, so I compensated right, and then left again. Ended up rotating the back around to the front so I was 170* from the direction I was originally going. Slid sidways over the curb, into those small 'designer' trees, and then into some additional shrubbery right next to some condos :shock:
After a bit, cops came, took lots of pics of my car, property damage, breathalyzer test, etc. Gave me the case number, citation coming in the mail, set out flairs, I called a tow truck, and then waited for it to come. Luckily, I only walked away with airbag rash on my arms. Who knows the hit to the pocketbook yet.
Tomorrow, I'll take pics in the light of the damage. Basically the driver and passenger doors on the left side had a small tree slide into them -- windows didn't break though. Also the body below the door is creased in. The front left wheel is wrecked, not sure about the control arms, etc. Front bumper got touched, since the hood doesn't quite close, but it doesn't appear the front corner/area moved in a lot. This type of thing even worth repairing / repairable?
Tomorrow, after taking pics of the damage I'm going to try and get a few estimates from local body shops (anyone got a recommendation for one in northern Seattle?). Right now I'm considering a few things:
1) Repair the body damage
2) Buy another 91-94 turbo car and swap my upgraded components in. Sell the leftovers / part out.
3) Buy a newer Subaru... haven't really looked around yet, but would consider most things which are 'sporty'. Part out the old car.
'11 WRX Limited
'94 TW | R.I.P.
If you remember my wreck, I was quoted $7k for the repair. Basically, if any of the pillars have moved or any underlying structural sheetmetal has been eff'd with, it will be too costly to justify fixing that old of a car.
Damage to mine for reference http://bbs.legacycentral.org/viewtopic. ... highlight=
GodSquadMandrake
Post by GodSquadMandrake »
I'd say put some new doors and a bumper on and keep trucking. You might be able to pull the dents out of the rocker panel but it won't be perfect.
-Doug Wilson
BSOD2600
Post by BSOD2600 »
Time for pics, full list here: http://surrealmirage.com/bsod2600//subaru/wreck/
Otherwise the highlights. Think it's repairable?
'11 WRX Limited
'94 TW | R.I.P.
jake15
Post by jake15 »
that doesn't look like it's worth fixing. find a nice cheap N/A shell and swap it all over :-)
I can't quite tell, but it looks like the floor's bent in the last pick. If not, you could replace the doors and weld in a fabbed/junk yard sill, but is it worth it? I'd probably swap the stuff into a new shell.
GodSquadMandrake
Oh boy. It looks like the floor is bent and your outrigger mount is pushed in a little. I dunno if you can fix that without a frame straightening shop.
-Doug Wilson
SiCkSTi04
Post by SiCkSTi04 »
good thing your ok but those tires were over due for replacement.
91legacyawdturbo
Post by 91legacyawdturbo »
Find a new shell thats going to be alot if work to fix.
2002 wrx sport wagon
PhyrraM
Post by PhyrraM »
I hate to say it, but I concur. A reshell is in order.
Pick up an clean, but needs mechanical work, AWD wagon and start the swap. Everthing including the interior.
*I only say AWD because it looks like part of your rear is bent and you'll be needing a new "something" anyways.
gijonas
Post by gijonas »
toast.
ultrasonic
Post by ultrasonic »
That shell is done. Sucks, man.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
Yes, shell is much beyond totalled. Buy it back for $250 and swap your goodness over.
If you wait a little bit you can find a really nice shell like I did. My definition of nice is skewed due to me being in a salt state, though.
BSOD2600
Post by BSOD2600 »
Yea, I've come to the conclusion that it's beyond repair. Several body shops gave $7-8K estimates.
Now to find another 91-94 turbo and swap my stuff over. Or I suppose part it out and get a newer 'sporty' subaru...
Will update tonight with pics of the property damage and my arm.
'11 WRX Limited
'94 TW | R.I.P.
Airgne
Post by Airgne »
i have a 91 wagon that could could swap everything over into.
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
You don't HAVE to get a turbo Legacy to swap your stuff over.
Airgne
Post by Airgne »
just give me a call. number in sig.
Yeah you don't need a turbo. Pick up a n/a wagon or sedan in good shape and swap the running gear over.
If you want to get really good, you could swap the interior and body wiring harness so you don't have to add the turbo sensor wiring.
I'm reminded of an ex gf. She had an S2000. I mentioned to her that the rear tires were getting down there, and she should look at replacing them. Not too long after that it was raining real heavy one morning, she hydroplaned, the ass spun around and tagged a center concrete guard rail.
BSOD2600
Post by BSOD2600 »
Hmm for some reason I thought having the turbo body/bits was required unless I Was going to be swapping every single thing. Yes, I realize Josh has done a NA -> turbo swap but you're way out there :P.
For a NA -> turbo swap one needs to pull what exactly?
* engine
** turbo
** exhaust
** fuel pump
** maf
* ecu
* tranny/clutch
others?
'11 WRX Limited
'94 TW | R.I.P.
Skruyd
Post by Skruyd »
Legacy777 wrote: I'm reminded of an ex gf. She had an S2000. I mentioned to her that the rear tires were getting down there, and she should look at replacing them. Not too long after that it was raining real heavy one morning, she hydroplaned, the ass spun around and tagged a center concrete guard rail.
At least she didn't spin and went upside down in a ditch :-D
Any who, I thought the ECU was the same between the NA's and the Turbo vehicles? Also in your Sig it says you have a Revtronix Stage 2 so the MAF on the NA should be the right one. One other thing is you need the cross member that the motor mounts are bolted to from your vehicle instead of the NA cross member or the up pipe won't clear. I know I'm forgetting something else????
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
BSOD2600
Post by BSOD2600 »
Snapped pics of where I slid over the curb to my main site...
Notice the missing trees?
That flag pole curved around the side of the body...
'11 WRX Limited
'94 TW | R.I.P.
91legacyawdturbo
Pull the entire bulk head wiring harness. well all of your harness take your dash out will make it easier but I'm not sure if its required. When I had a leaking fuel pump sending unit the dealership told me that the sending unit is different than an n/a car, as stated above a crossmember. exhaust, radiator, brakes.
BSOD2600 wrote:Hmm for some reason I thought having the turbo body/bits was required unless I Was going to be swapping every single thing. Yes, I realize Josh has done a NA -> turbo swap but you're way out there :P.
* engine
** turbo
** exhaust
** fuel pump
** maf
* ecu
* tranny/clutch
others?
Airgne
Post by Airgne »
wagon is cheap.
jake15
Post by jake15 »
asc_up
Post by asc_up »
Damn. That's horrible! Glad you're doin' ok.
Devan also has a 93 L sedan down in Portland for $800.
http://bbs.legacycentral.org/viewtopic.php?t=40186
