Need Confirmation Please - 04 WRX Shifter Assembly
Kimo, I looked into your journal last night and I realized a couple of things:
I don't have the proper punches, so I will have to use some 5mm and 8mm bolts like you did.
This may sound really dumb, but do I HAVE to take the tranny out to do this? If so, I don't really have the proper tools at my house to do this and I might have to take it to a garage.
BTW Kiko, your car looks great. I hope to start my own journal soon, but I wish I would have taken pics of the car when I first got it.
Also, I see that you got a new spring for the setup too...should I get one as well?
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
I don't think it needs to be out of the car to replace everything although it makes it much easier. I don't know if the hassle of removing the tranny is worth it though. I did mine while the tranny was on a table in the garage so it was easy. But from the looks of it, it's probably a MAJOR PITA to do under the car. Especially trying to hammer that stupid joint off the shaft.
You don't need punches, the bolts worked great for me. I also use a bolt to remove the pins in the axles and that works great too. You can also usually use a battery tie down rod to remove axle pins. Just a random tip lol.
You can get that spring if you'd like. I was told it wears out and causes your side to side movement of the shifter to become loose. I've also read that it breaks if tampered with if it's old and rusty so that's why I replaced mine. It's cheap so you might as well.
Thanks, I've fallen in love with it without even driving it. As crazy as that sounds. Although I've had 2 other legacy wagons before this one. As long as you plan to do several mods to your car you can ask DLC and he'll let you make your own build thread. I'd like to see your car and your progress. I love build threads, I get a lot of ideas from them for my car. I know I've learned a lot from SLODRIVE's thread.BTW Kiko, your car looks great. I hope to start my own journal soon, but I wish I would have taken pics of the car when I first got it.
Thank you, Kiko. I think that it will be hard as well to try and do this with the tranny still in the car. It will be very tight under the car to be able to do all of this. I guess I will try and see how it goes.kimokalihi wrote:I don't think it needs to be out of the car to replace everything although it makes it much easier. I don't know if the hassle of removing the tranny is worth it though. I did mine while the tranny was on a table in the garage so it was easy. But from the looks of it, it's probably a MAJOR PITA to do under the car. Especially trying to hammer that stupid joint off the shaft.
So, I have to remove the pins in the axles to do this too? I'm kind of confused on why I would have to do that. This is starting to sound like something I might not be able to do in my own garage.
I'm going to start taking pics of the car and my progress to start my own build journal.
No you don't need to remove the axles. Didn't mean to confuse you, I was just saying that you can also use a battery tie down rod to remove the pins in the axles if you ever have to remove them for anything.
Lunatech
I think you only would have to remove the pins for the axles if you're going to remove the trans to do the project.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
Part number for the spring is 33022GA081.
Thanks guys!! I'm going to order these parts then: the spring (33022GA081) and the linkage joint (35047AC030) from 1stsubaruparts.com.
Thank you very much again for all of the helpful info you guys have posted for me.
I will go find some 5mm and 8mm bolts and just wait for the spring and joint to get here!
Thanks!!
Thanks!!
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
I'd really recommend getting a set of punches. They will make the job easier.
Getting the roll pins back in can almost be more of a pain. I made a set of punches out of round bar that hold the roll pin so you can get it started.
http://www.main.experiencetherave.com/s ... intcustom/
Oh wow! Thank you very much. That will surely help me out a lot!!Legacy777 wrote:I'd really recommend getting a set of punches. They will make the job easier.
Ok, parts are ordered...
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
Something I was thinking of last night...would it be easier to take the rear trans brace off so that it will lower the back end of the trans so it will enable me to work on this easier?
Would it be worth it or just try it first with everything bolted up?
Also, a friend of mine is going to let me borrow his punches.
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
I don't think taking the rear trans brace off is going to do anything. You would also have to take the pitch mount brace off, and even then, I'm not sure how much additional clearance you'd be able to get. Plus you'd have exhaust/turbo that would need to be removed. I wouldn't bother with it.
Ok, thank you for the advice...I will definitely take it.Legacy777 wrote:I don't think taking the rear trans brace off is going to do anything. You would also have to take the pitch mount brace off, and even then, I'm not sure how much additional clearance you'd be able to get. Plus you'd have exhaust/turbo that would need to be removed. I wouldn't bother with it.
Parts are in...I'm going to try this tomorrow
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
Thank you everyone for all of your help! I installed the assembly yesterday! WOW, what a difference.
Check out my journal to see details and how I did it.
http://bbs.legacycentral.org/viewtopic. ... 666#314666
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
I just want to say thank you for posting up all this info! I hate the way my leggy shifts and I just so happen to have an extra wrx shifter linkage setup in my garage...
I'll be ordering those 2 parts and will be putting them in!
91 leggy SS, work in progress...
04 wrx w/ jdm twinscroll and lots more... 300whp :-)
Yeah RCKSTR, it is definitely worth it! Like Aerotech said, it is like getting a new car!
Check out my build thread for more info on the parts and how I did it if you want.
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
Mattheww044
its definitely worth it! best of luck on the install. let me know if you have any questions.
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
Re: Need Confirmation Please - 04 WRX Shifter Assembly
PITA but not impossible.
Ya, after reading this I went back out there and hammered the Sh!t out of the rod off the U-joint . Hammered it against the control arm and it finally came ! PITA but so worth it !!!
