About to do Clutch. What should i know/do.
Code: Select all
US Legacy L & Brighton MY00L:
code 1st 2nd 3rd 4th 5th rev. FD
TY754VCAAA 3.454 2.062 1.448 1.088 0.780 3.333 3.900
Viscous (4kgf)
You can drop the trans with the wheels attached and axles still bolted up.
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
With that amount of mileage, I would not worry too much, but the design is not as tough as the phase I. There are less dogs, and they changed the cone/mesh so that the gear slowed down more efficiently before a shift, at the expense of increased synchro wear. If you rev match anyway, it wont matter - and they do work better, but they just don't last quite as long.
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
BTW, those ratios are based on old North Ursula data, so I'm only 98% sure they are correct. My compiled tranny chart has not failed me yet, but I'm still not confident enough to publish it....
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
Ran into an issue, started new thread regarding problem in hopes that i get a fast answer since i'm on the clock here. see link please.
http://bbs.legacycentral.org/viewtopic. ... 573#323573
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
