Seatbelt troubleshooting
beanis05
Re: Seatbelt troubleshooting
Post by beanis05 »
zoo mob im pretty sure your seatbelt is jammed. there are two ways on attacking this problem ghetto and right way
first the right way and only way
take off the trim and look to see why the mouse is not moving if the cable is running up and down by the motor than the motor is fine and you stated that the track wouldnt budge when you tried the allen wrench . so its either stuck jammed or fell of the track or the wire came off snapped off or broke off
the ghetto way is to wack it to see if it can come loose since it sounds like it is stuck
Mattheww044
if your belts didnt work and you swapped the computer and they worked for a while and now they dont work than i think you are just going to keep on burning up computers in my opinion you have a short somewhere so pull the codes look it up and we do have a thread dedicated just to the automatic belts
1990 Subaru Legacy L 89k auto to 5 speed winter daily driver
2004 Subaru WRX 80k
1988 Mazda Rx7 vert > Turbo 2 trans swap
1993 Honda Civic Vx Gutted
parker
Post by parker »
I think the mechanic moved my driver seat belt slider up the track by hand, now it won't go in either direction. Doesn't feel jammed, just kinda loose in the track, but won't slide. Chime doesn't work, belt motor doesn't hum. The seat belt indicator flashes quickly, there doesn't seem to be a pattern I can discern. Can there be something affecting the whole shebang?
1991 Legacy L AWD Wagon automatic
Mattheww044
Post by Mattheww044 »
Well i swapped computers and now my seatbelt works 100% but the passenger doesn't at all
parker wrote:I think the mechanic moved my driver seat belt slider up the track by hand, now it won't go in either direction. Doesn't feel jammed, just kinda loose in the track, but won't slide. Chime doesn't work, belt motor doesn't hum. The seat belt indicator flashes quickly, there doesn't seem to be a pattern I can discern. Can there be something affecting the whole shebang?
Welcome to the BBS.
There's a code stored in the seat belt computer. Here are instructions on how to pull the codes and determine what the problem is.
http://www.main.experiencetherave.com/s ... tdiag1.jpg
http://www.main.experiencetherave.com/s ... tdiag2.jpg
http://www.main.experiencetherave.com/s ... tdiag3.jpg
The wire you need to ground the pin on is tucked up under the dash. You'll need to probably hunt for it.
parker
Post by parker »
Thanks for the info. I've read it over and don't see anything about how to fix things after you determine the problem -- do you have that too? I'm trying to decide whether to hunt for a broken wire or blown fuse etc, or to just move the slider to a permanent place and attach the belt by hand every time I get in and out of the car. I've lived with a nice slider for 16 years but my previous cars had manual seat belts -- you get used to it!
_______________
Parker
1991 Legacy L AWD automatic
Have you checked the seat belt computer for stored codes? If so, what were they? That will help point you in the direction of what to replace/fix.
Here's the wiring diagrams for the auto seat belts
http://www.main.experiencetherave.com/s ... _diag1.jpg
http://www.main.experiencetherave.com/s ... _diag2.jpg
parker
Post by parker »
Those diagrams look good -- I'll start digging around. Thanks for your time.
Parker
93Leg-c
Post by 93Leg-c »
Is the mechanism in the automatic seatbelts interchangeable between '90-'94 Legacies?
'94 TW
Yes I believe they should be. We used the mechanism or at least pieces of what came out of my 90 in a 93.
