Deride's 1991 Legacy Sport Sedan
Re: Deride's 1991 Legacy Sport Sedan
^^ probably cost more to ship than they are worth. The headliner is nasty vinyl, front door cards were broken by the speaker too.
So today I got the headliner swapped with the cloth one from the 94, carpet swapped for the black carpet. Put all the black interior trim in it and put all the seats but the drivers back in. All that's left is swapping the dashboard/steering wheel/column trim. Also was gonna swap the ebrake handles but the 91 uses a different sender switch and the switches mount differently.
2002 Impreza 2.0RS 6MT
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Both dashboards are pulled, pedal assemblies are pulled. I gave up after spending an hour under the 91 dash trying to get the clutch/brake assembly to fit with no luck. I'm getting stuck on a large wiring loom that goes down to the column it's so close but can't quite get it by myself. I think it's time for a few drinks as my back hates me right now.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Got the pedal assembly in along with the black dashboard and the 5mt gauge cluster. Just the center console left for interior stuff. Now for the easy part of putting the engine and transmission in.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Got the car in the garage and on jack stands. It is AMAZINGLY clean underneath for a 1991. Took the remainder of the exhaust off of it and threw it in the scrap pile. I started to do the wiring for the AT to MT swap, pulled the shift lock module etc. It's all coming together I'm just lacking the motivation to spend more than an hour or two at a time on it.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Pulled all of the wiring harness from the 94 and worked a bit more on the automatic to manual wiring on the 91.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Finished the auto to manual wiring and replaced the crank/cam seals and timing belt. Hopefully dropping the motor back in tomorrow.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Finally got the correct intake manifold wiring harness (engine harness) from Damon, so I can get back to business on this thing. I *should* have it running this weekend. The 94 just needs the gas tank pulled and maybe some rear suspension bits like sway bar and lateral links and its ready for the scrapper.
Poor 94, sorry for the cellphone pic.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
^^^ want to sell the door handles?
All I have is a set of 91 chrome door handles. I swapped the painted ones into the 91.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Finally drove it today, has some really really old gas in it (basically a full tank too) so it smokes a bit. Still need to swap the rear suspension, bleed the clutch some more, and figure out why my high beams don't work. If anyone is wondering, outback aspect ratio tires rub on a SS.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Fixed a coolant leak, swapped the rest of the suspension, swapped the headlight/blinker switch(didn't fix the problem), removed the crusty door actuator from the viper alarm, fixed the passenger side rear window button, bled the clutch the rest of the way, and started fixing an intercooler rattle. Tomorrow I'll finish fixing the rattle, find out why my high beams don't work and start looking into wheels/tires. Almost done!
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Saw the result of Kimo's 3M headlight job and remembered how much Piddster liked the 3M kit so I decided to try it myself. I work in an auto body shop so I could have easily done it at work with our industrial grade 3M stuff. I wanted to find out how good this kit was from the auto parts stores so I picked it up for $18 with my discount.
Left Side Before
Right Side After
Turn Signal Before
Turn Signal After
I was quite amazed with the kit. All of the sand paper was industrial grade auto body stuff and not the cheap parts store shit. The buffing pad was the same too, everything was just smaller. To put it in perspective, each sheet of sand paper we use at the shop costs us $1 or more, the 3000 grit trizact sheets cost $6 per sheet. The rubbing compound is more than $100 per gallon. So this $20 retail kit is well worth the money, and it actually makes the process quicker having a smaller buffing pad on the old ass 91 headlights with the nipples on them. It took me ~2 hours and 3 beers to do both headlights and the turn signals. I went through 2 charges on my non-lithium battery on my drill and 1 charge on a lithium battery to finish them. (charging time is included in the 2 hours)
I also covered the 2 chrome strips on the tail lights with electrical tape, still gotta do the bumper chrome but I like the tail lights a lot better now.
Left Side Before
Right Side After
Turn Signal Before
Turn Signal After
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
That kit is well worth the money. I did three sets of headlights with the supplied abrasives, and touched mine up again a couple times with the Trizact pad and compound.
Picking up some wheels for it tomorrow. I ended up liking the Rota's too much so they stayed on my Impreza. Just gotta get an alignment, make a grill, and clean a few things up and it will be ready to sell.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Done.Grayguy wrote:Hurry! Finish this car so you can sell it and go offroading with Chux and I !
Traded it today for this:
I'll take pics of what the key is for tomorrow.
Sad to see it go, but its going to a good home.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
O.O I love it! Four liter?
Danny
SUBYLUV871
Nice jeep deride. It's snow season, now you can go in deep snow. I bet you get alot in MN.
1998 legacy l wagon
1988 ford ranger prerunner (my baby)
1998 legacy l wagon
Yep, 4.0 auto. I can't wait to run stuff over with it. Hopefully not the Impreza, lol.Danny-G wrote:O.O I love it! Four liter?
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Hells yeah! Time to go tur it up! Now my jeep is gonna look like a little bitch
92' SS: SOLD
SUBYLUV871
My buddy's are jeep xj guys, like big ones. Nice ones with the toughest run ing gear. I'm a more of a ford guy. I just traded my 6th ranger for my subaru. But still have another for the snow. But those jeeps are made for offroad.
Gray: let's see yours
1998 legacy l wagon
1998 legacy l wagon
Well his car is sold, so I might as well thread jack a bit and I love pic whoring my jeep, and riding with me is the main reason deride had to get one
haha
Mine is the little jeep that could. I've only got about $1500-2000 into it (with buying it)
-5" in front
-7" rear lift
-relocated/raised fuel tank
-31's (until I feel like dropping the $ on 285's)
- lots of other little things(cutting here, welding there)
- appreciation for body damage (most important mod
-5" in front
-7" rear lift
92' SS: SOLD
Jeeps. What can't they do? I'm a fan of the xj myself, all it took was driving a postal one and I was hooked. Someday, I'll get one myself and use it for the hard core offroading.
Danny
SUBYLUV871
nice nice. looke like fun. bout do for some meat on those tires.
we did a cantilever rear suspension on mine. we got 14' out of a 9.5 shock.
shes alot of fun.
we did a cantilever rear suspension on mine. we got 14' out of a 9.5 shock. shes alot of fun.
1998 legacy l wagon
1998 legacy l wagon
I really gotta get working on the Jeep sometime soon. Since I've got it I've swapped on a hood I got from Grayguy without huge holes in it, replaced the upper radiator hose, and fixed an issue with the drivers door lock. Guess I'm kind of burnt out from all the projects I've done lately I don't even have any ambition to work on my Impreza, let alone the Jeep.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
