N/A 2.2L Legacy L Clutch Replacement Options?
Re: N/A 2.2L Legacy L Clutch Replacement Options?
Just an FYI, the 2.5 RS pressure plate is stiffer and may be a little stiff with the cable clutch setup. I'm assuming you were going to swap to the 2.5 RS clutch & pressure plate.
I was originally going to, but have since decided to stick with a stock spec setup for the 2.2 NA. Its finding a quality kit locally that is perplexing. NAPA sells a "Proven" brand kit for about $180 that I may end up with.
I'd go with the exedy OEM kit, part number 15010. One of my distributors even has a couple in stock.
I need the part by thursday...thats been my dilemma.
