I tried searching, but came up short of a definitive answer.
I have a 93 2.2L Legacy L 5 Speed Manual AWD.
The clutch is not fully engaging when I shift at higher RPMs, like at 3.5K rpms I shift up to the next gear and it will not always catch. It will just continue to rev up more unless they go down low again and I can give it gas again and it will engage.
The shifter some times pops out of second, but rarely.
So my thoughts are pretty clear that I need to replace the clutch.
Reading over some other threads it appears that any of the 98-01 RS clutches and fly wheels should work.
I wanted to confirm this.
This is the clutch I plan on buying and hopefully a Lightweight flywheel.
http://www.fastflat4.com/index.cfm/page ... prd706.htm
I also was looking at this one:
http://www.amazon.com/EXEDY-15802HD-Rac ... roduct_top
I know the engine does not put out much power, but I plan to do some Autocross racing in the future.
Are there any lightwheight flywheels you guys would suggest to match it?
I am open to suggestions on any other clutch kits and OEM parts I might need too.
Thanks again!
P.S. There should probably be a sticky that says what clutches and flywheels work with what model of legacy.
