Underneath the carpet under the driver's seat is a bracket with a relay and a plug going to a sensor. The sensor is screwed to the underside of said bracket. It was the plug wires going to that sensor that had degraded to the point where one fell out when i tugged on it. I just spliced in a good junkyard plug and wire.
When your sunroof is not working, do the windows still work? If they do, then i suspect its the computer module towards the back of the sunroof assembly. CJ and others have had good luck with reflowing all the solder on that board.
Regarding the left hand drive EDM lights, trust me, they're worth it. I bought my SS as a rolling shell for $400, so from a dollars and cents arguement it doesn't make sense. But i could outdrive my lights at night, and with modern headlights on oncoming cars i had a hard time seeing my lane markers. No longer.
Pntaste4evr99
Winestone Cowboy
Post by Pntaste4evr99 »
Yeah Windows always work fine, just sunroof doesn't. Funny thing is that sunroof works all the time on hot sunny days, cold cloudy days, never works. I guess could be a solder thing?
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
aredub2
Post by aredub2 »
Not actually today but close.
Swapped broken windshield wiper switch from parts wagon to ss... Didnt realize the rear wiper functionality. Oh well. Also had an issue with position 4 on the fan blower switch. Thought if i swapped it I could fix it. Nope. Must be wiring some where. Also charged the ac and swapped seat belt controls because the belts in the ss are all wonky. Still not fixed but better. I think the connections are corroded and could use a cleaning and some grease.
Pntaste4evr99
Winestone Cowboy
Pntaste4evr99
Winestone Cowboy
Blacked out the tail lights today, among other small things.
Looks nice and mean!
Pntaste4evr99
Winestone Cowboy
Thanks Mike, I also cleared the headlights and corner lights, in an attempt to stop the yellowing without spending a lot on glass headlights. I'll see how it goes....
dankberries
Post by dankberries »
I've taken my summer wheels off and put my winters on 5 times in the last two months, becoming NASCAR status at swapping wheels. 10 lugs per wheel w/ spacers, double time ;-).
Good thing I decided to swap out on Friday, got a little more snow than the street tires can handle:
Normally my impreza would be the dedicated winter car, but it needs a new diff & registration/tags. Aside from ground clearance the legacy is almost as capable as the impreza in snow, the legacy ate 3ft of snow for breakfast like it was nothing.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Damn Dank, thats some serious snow! I don't think it snowed once in the lowlands this season. Luckily that's what Stevens and Snoqualmie pass is for.
rallyak
Post by rallyak »
So much snow!! We never seen hardly any snow this year. Didn't even get the snowblower out because we never received more than 6 inches. My grass is already greening up and the leaves are starting to pop out and the lakes have no ice. I pretty much destroyed my studs this year.
Charles
I guess if you have more than STI power you gotta add a badge right?
Sent from my SM-N920T using Tapatalk
originalcyn
Post by originalcyn »
Badge is +5 hp.
Kijan
1993 Legacy LS | PBM 227
Pntaste4evr99
Winestone Cowboy
That's why I put mine on. Lol
originalcyn
Phil, nice job on the tint. I personally don't like the idea of tinting my tail lights, bit it definitely looks sharp. Did you split the rear garish to get inside and paint?
Kijan
Pntaste4evr99
Winestone Cowboy
I don't know what u mean about "split"? It unbolts like the tail lights. Take off the whole assembly, clean, scuff, mask, paint, and BAM!! All shiny lol
Put the sti badge on and my clutch went to shit.
CJ has a fast car.
CJ drives fast car daily.
CJ finds sti badge and Braggs about it.
Clutch goes out on CJ.
CJ regrets sti badge.
Don't be like CJ.
Pntaste4evr99
Winestone Cowboy
I put my badge on and car died. So Phill knows CJ's pain. Mine was just a ground wire though....still rock the badge though, so not completely crused
originalcyn
Pntaste4evr99 wrote:I don't know what u mean about "split"? It unbolts like the tail lights. Take off the whole assembly, clean, scuff, mask, paint, and BAM!! All shiny lol
Ah, no it's just been so long since i've taken one apart that i didn't realize that it was bolted or screwed together. I'm still in retrofit mode lol.
Kijan
aredub2
Post by aredub2 »
Not looking to good
Better
Still needs a deep clean
aredub2
Post by aredub2 »
This is what wasnt looking too good
aredub2
Post by aredub2 »
Hood installation was in bad shape. Been bugging me since I got her.
10wrxing
Post by 10wrxing »
I installed heated seats into the Legacy:
Total time was a little over 3 hours.
I also installed a backup camera on my WRX today:
I did it mostly because I got the camera for free, and it gave me something to do on a rainy Sunday.
I installed one in the Legacy back in November as well:
Still needed some adjustment here, as it's pointing way to high. Been fixed since:
Our '15 Lexus came with a backup camera, and it's surprising how much you miss it when you get into one of the other cars.
Pntaste4evr99
Winestone Cowboy
I got around to installing my "new" vsld rear diff (Thanks again Mike) and look what I finally found.Image
Pretty damn cool Phil! If only it fit my edm garnish.
I had swapped to an 03 WRX trans a week or two ago and hadn't quite put it together yet. Got driveshaft, exhaust, slave cylinder installed, and fixed the knock sensor which broke when I pulled the old tranny. Filled the tranns with some good 'ol extra s.
All thats left is to replace a coolant line going to stock overflow box, install turbo blanket, and tmic.
Got everything back together and trans made a terrible noise in 1st. Well, less than 50 miles later, 1st gear gave up the ghost!
