Discovered my left front fheel bearing is shot and I'm no where near home...
Danny
mesoslow6969
the other day i bought a complete motor swap for my car... let project "Go Faster" begin...
Anti-Seize is my best friend.
A/c removed, well almost. I took everything out from under the hood and taped the two lines from the cabin closed for now. There wasn't any charge in the system, the condenser was bent, the compresse made some rattling noises when it was engaged, and I never used the a/c. Its always been roll the rear windows down a little and turn the fan on to two and set to "vent". I also used Turtle Wax Color Magic Car Polish on the left rear door, quarter panel, and part of the rear bumper. All I can say about that stuff is WOW!! It makes 18 year old paint shine quite well and took ALOT of the small scratches out, it didn't help the over spray from me painting the door handles though but that was my own stupidity that caused that... Heres a picture of after being polished. Note the shine under the blinker area, thats treated along with the side of the car, the ret of the bumper hasn't been treated..... yet.
And heres the engine bay after the a/c junk was removed but before I taped the cabin holes.
Danny
New wheel bearing installed. No more grinding noise from the left front!
Danny
Mattheww044
that's always good, I was SO relieved when I fixed mine.Danny-G wrote:New wheel bearing installed. No more grinding noise from the left front!
I installed my red Rally Armor mud flaps yesterday! Expensive, but they look good!
I Replaced the Spark plugs and wires, and i also replaced the air filter
Jesse James
Nintendo Technical Support Representative
Link To Nintendo Technical Support Thread
1994 Impreza Wagon 5M/T
1997 Legacy LSi A/TRamsey Clark wrote:Who will protect the public when the police violate the law?
Washed, waxed, installed subaru stock mud flaps, and finally maned up and bought new tires. Today was a good day for the SS.
Cleaned all the ground points, installed the ground modifcation, and replaced my MAF Sensor. Little bit more to do after work today
Jesse James
Found out my o2 sensor is bad. So thats been the cause of my car almost dying after three different right turns, the first time that happened I didn't know what was going wrong but I finally got to pulling the code today. Sunday I plan on taking the sensor out to see if I can clean it and if not I'll price one from the junk yard and see if theres any >200k legacies there, if not its a new one.
Danny
I wouldn't bother cleaning it.
installed 04 WRX fog lights. still need to wire em up and make some sort of bracket so they dont fall out. kind of a pain in the ass to do but im sure ill be happy when its all said and done.
shark attack
then i decided to look at my awesome 21 year old 254XXX mile shifter bushings.
shark attack
I like it! Looks quite a bit better than I was picturing. One question, whats with the notch on the lip?
Danny
lol, oh that
. that was from one of the first CAI i designed. i had a intake funnel connected there to act as a air ram and then i got wiser. thanks for the commnt
on another note i tackeled the shifter linkage.
what a piece of cake. despite the age it was really easy but it mght be in part to it being a fwd and a rust free car. no i just need to figure out if i should go OEM or if it is really worth getting kartboy and that other stuff.
broken
think it's rust? nope dirt, yea
supprisingly the big bushing is intake but ill replace it regardless. i cant belive it took me 5 years to do this
broken
How do you let it get so bad that you can't drive on it...?Danny-G wrote:Discovered my left front fheel bearing is shot and I'm no where near home...
Ditch it for now, I haven't gotten around to putting in my O2 sensor after I put in my downpipe, and it runs perfectly fine. You can't really clean O2 sensors, just buy a new one.Danny-G wrote:Found out my o2 sensor is bad. So thats been the cause of my car almost dying after three different right turns, the first time that happened I didn't know what was going wrong but I finally got to pulling the code today. Sunday I plan on taking the sensor out to see if I can clean it and if not I'll price one from the junk yard and see if theres any >200k legacies there, if not its a new one.
The wheel bearing started making noise right after I took my snow tires off after the last snow storm, I mis took it as the brakes dragging, but it wasn't seized so I was able to get back home and get it fixed.Apex3 wrote:How do you let it get so bad that you can't drive on it...?Danny-G wrote:Discovered my left front fheel bearing is shot and I'm no where near home...
Danny
Gave it a wash, found one of those Intake Super Charger things at the junkyard. I decided to install it and see what happens, and nothing noticable. lol.
Looks like this one...
Jesse James
Any different noises at all?TBFK wrote:Gave it a wash, found one of those Intake Super Charger things at the junkyard. I decided to install it and see what happens, and nothing noticable. lol.
Danny
Well my intake already whistled whenever I get on it, so I didn't notice any difference.Danny-G wrote:Any different noises at all?
Jesse James
OMG, lol, really? ^^^ I hope you didnt pay to much for that thing. Iv seen dyno sheets say you actually loose horse power by having that restriction in your intake. Way to give it the old college try though. Got my exhaust cut again and pulled up closer to the chasis so i can get my ground clearence back. Installed my wideband (AEM) and got to driving around. It reasured me that things are running well throughout the powerband. Although i am running 10:1 at WOT which seems a bit rich, but at least its not lean. Phew. I wish i could turn up the boost a bit so i can ad more air to the equation. But at 15 psi im pretty sure im at the upper limit of what these stock 370cc injectors can flow, from what i read on here).
1990 NA 2.2 Open Light rally car
It was saturday but I finally pulled the core support back into place for the most part. Such a simple method too, pull up to a post/ tree, wrap either a chain or bike lock around post/ tree, wind bike lock/ chain around bent area of core support, put it in reverse, and give it a little bit of gas for a tug in the right direction. I gave it three mild tugs and its almost all the way back in place.
The method sounds complex but its really not complex at all, yes, if you give it too much gas you can screw it all up but as lon as you're careful its all good.
Danny
I didn't pay for it. lol. Turns out it was already in the intake when I bought it. Guess it came with it:)TurnNburn wrote:OMG, lol, really? ^^^ I hope you didnt pay to much for that thing. Iv seen dyno sheets say you actually loose horse power by having that restriction in your intake. Way to give it the old college try though.
Got my transmission flushed today, and it's feels a lot better:D
Jesse James
Completed on Tuesday, rear flood light. Using an existing harness for driving lights, I took my spare light and mounted it under the left back-up light and for power to the harness, I tapped into a liscense plate light while using the back-up light circut as the "switch" to turn the light on only when all the lights are on. Kinda a fail safe so I can't forget the light is on and take off on the highway. Ok enough with the words, onto the pictures.
Danny
Orange light bar!
Pictures will come later when I take them.
Danny
Mattheww044
Ordered a bunch of new stuff. Timing belt kit, wrx water pump, wrx shift linkage adapter, bushings, spring, etc.
Getting ready to do a weekend long project
Shopping cart found my right tail light. God I hate people that are too lazy to put the cart away.
Danny
