A vacuum hose reference for EJ22Ts
mexicanzero
oooooohhhhhhh the MBC goes in place of the boost control solenoid i get it now!!!!!! wow i feel so stupid THANK YOU!!@
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
Re: A vacuum hose reference for EJ22Ts
vrg3 wrote:I've been meaning to do this for a while... Today I drew up a diagram of EJ22T vacuum hoses:
http://www.graphics.cornell.edu/~v/vacuum/
I left off the IAC hose and the big BOV hoses since they're simple. I left off the PCV stuff since it's complicated.
Hopefully this will be useful for people doing swaps and/or replacing their hoses.
Please send me corrections if I got any of it wrong.
ahhhhhhhhhh
94SS_Canada
I sent Vikash an email. It wasn't too long ago, maybe a few weeks about his Cornell site going down. More then likely the university took away access, which sucks. I don't know if he had everything backed up. I sure hope so.
My recommendation would be search on google, and see if you can access a cached page. Other option would be to use the internet archive to see if we can suck down those pages.
94SS_Canada
I worked yesterday sucking down what I could from the internet archive. I've got most of the first gen legacy stuff sucked down. Some of it wasn't d/l'd.
When I get it converted I'll host it on my server.
94SS_Canada
http://www.main.experiencetherave.com
I haven't had a chance to add Vikash's stuff yet, but it will have its own folder under the subaru directory.
I think the server is down. It just says"Nothing to see here, contact the webmaster."
So I could just go to the auto parts store and buy the correct size hoses and cut them to length?
This is just what I need!
It appears that the link is broken. Is this information still available?
look up 7 posts from yours. Scuzzy is hosting it somewhere else.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
You're welcome!
Added this to the new Intake forum sticky thread, so I will unsticky this thread unless anyone has any major issues with that.
station2stattion
Oh man! THANK YOU SOOOO MUCH!
I am about to restore my engine bay and You even posted part numbers.. you are my HEROES!!!
Please consider updating the picture to note that hose J has a pill inside, part number 22326AA090 I think?
I used that diagram to replace my hoses and only found out accidentally that J was special. Luckily I had not thrown it away yet.
Are you sure J has a pill in it?
Yep absolutely certain. Keeps it from overboosting in fifth gear.
I am not 100% sure on the part number though.
Why, did you already throw away your pill?
I've been running a GM 3-port boost control solenoid since I put in my stand alone. I'll have to look at that hose and see if I can find the pill in it.
I guess without the pill you may have more boost exiting/venting back to the manifold vs. going to the wastegate solenoid. That makes sense. I think you could probably retune the BCS operation to not use the pill if you went with an aftermarket EBC, but that's probably not a big desire.
I'm thinking to replace my lower hose again, this time cutting the factory hose in half to get the pill out. If I do I'll try different drill bits until I find the right size and post it here in case anyone wants to make their own pill.
Yeah I don't know why they used such a big hose just to put a TINY restriction in it. Maybe the pill was an afterthought because it only really makes a difference in 4-5 while going uphill at lower rpm (in my experience)
It's possible you could use a smaller diameter hose with a step up adapter and small length of larger dia. hose to connect to the resonator box.
