Page 3 of 3
Posted: Sun Jul 06, 2008 6:44 am
Some new pictures of hacking up the bumper beam.
http://www.main.experiencetherave.com/s ... adiator/02
I need to do some more trimming & fitting. I was going to work on it today, but haven't been feeling overly great. I will probably work on trying to finish things next weekend.....birthday present to myself ;)
Posted: Mon Jul 07, 2008 1:25 am
by yazmo
starting to look nice from here.
good job i am excite to see the next
good luck
Posted: Sat Jul 12, 2008 5:09 am
Mocked up the radiator today. Fits very well! Had to get a bolts welded on to fix a previous shop's screw up.
I'm going to try and finish the hose routing tomorrow. I'm going to have to cut the lower horizontal & vertical slats in the lower bumper. Hopefully I can finish everything tomorrow or Sunday.
Here's some pics
http://www.main.experiencetherave.com/s ... adiator/03
Posted: Mon Jul 14, 2008 2:42 am
Final mock up
http://www.main.experiencetherave.com/s ... adiator/04
I had to cut the lower slats on the bumper skin. I need to cut a hole in the bumper skin for the line going to the intercooler, but it should work really well. I'm very happy with how everything is going together. I think this setup will be much more effective/efficient then my previous setup, plus look better.
Posted: Mon Aug 04, 2008 3:49 am
Finally finished!!!! after four months....wow!
I pulled two bone head moves. First one I hooked up the inlet & outlet backwards on the intercooler. So I swapped that around. Other issue I realized I should have done is have the shop put a vent/bleed screw on the top of the exchanger header to help bleed off air. I ran my hoses so the inlet is at the top and outlet at the bottom. Good for thermal reasons, bad for venting air from the radiator.
http://www.main.experiencetherave.com/s ... diator/06/
all the pictures here
http://www.main.experiencetherave.com/s ... icradiator
Posted: Mon Aug 04, 2008 4:27 am
by scuzzy
that looks pretty damn excellent!
Posted: Mon Aug 04, 2008 4:30 am
Thanks!
This is how I originally wanted my AWIC setup to be like. The two smaller radiators really just didn't do it.
Posted: Mon Nov 03, 2008 12:33 am
by beatersubi
92 ra-r wrote:Ooh, I just noticed in one of your pictures that dandy Samco hose from the turbo to the IC. It has a molded BOV elbow on it. What's the number for that? I've been looking for that little bugger!
Bit of a revival:
I found some info on the turbo->I/C hose here.
Posted: Thu Nov 06, 2008 4:11 am
by i_c_the_light
Air to water is so damn awesome.
If it's good enough for a Veyron, then it's good enough for my car.
Posted: Sat Nov 08, 2008 2:48 pm
Every time I go drive, especially when the temps are colder and go feel the AWIC core.....it's cold to the touch and stays that way....
