How To: 440cc Injectors in Legacy Turbo Rails
n2x4
Post by n2x4 »
[quote="asc_upThat's a stupid rumor that someone who was misinformed spread around around.[/quote]
+1
SUBARUEHS Racing
91legacyawdturbo
Post by 91legacyawdturbo »
If that's the case then ihave 440s aswell I have the grays aswell
2002 wrx sport wagon
pirategmunger
440cc injectors... EJ22t
Post by pirategmunger »
What injectors are those? I'm looking for 440cc or 480cc injectors but do not know part numbers... any suggestions? :?
isleymerl
Post by isleymerl »
Would someone point me in the direction of where to purchase these 440 cc injectors.
isleymerl wrote:Would someone point me in the direction of where to purchase these 440 cc injectors.
Post a WTB ad in the parts shed, and also on the other Subaru forums.
BSOD2600
Post by BSOD2600 »
Lots of us have gotten them from this ebay user. It comes with most of the orings/spacers needed.
'11 WRX Limited
'94 TW | R.I.P.
CAV3MAN227
Post by CAV3MAN227 »
ericem wrote:lol all you need is those 440cc injectors for 125 shipped and $20 for 4 of the rubber spacers and thats it they just drop in. Takes less then a hour.
are u talking about n/a rails or turbo rails?
BSOD2600
Post by BSOD2600 »
440cc 'grey top' injectors pictured earlier in this thread drop into turbo fuel rails with zero modifications.
'11 WRX Limited
'94 TW | R.I.P.
CAV3MAN227
so then anything higher than 440's u would need to go to the n/a fuel rails? what exactly is the benefit of the n/a fuel rails? size? and do the 440's match up with the td04 on our t-legs as it does on the wrx's? better or worse?
socalwb wrote:so then anything higher than 440's u would need to go to the n/a fuel rails? what exactly is the benefit of the n/a fuel rails? size? and do the 440's match up with the td04 on our t-legs as it does on the wrx's? better or worse?
Pretty sure those questions have been asked before...
CAV3MAN227
sorry if they have been asked before...
No Prob. If you'd asked if the EE20 fuel rails fit and why/why not, that's a different story. :D
Mattheww044
Post by Mattheww044 »
just found these on ebay:
http://cgi.ebay.com/ebaymotors/Subaru-W ... 35a6325c0d
for whoever is needing injectors from an 05 wrx
race_to_live
Post by race_to_live »
I got the 440's from that guy on ebay. and it came with all the o-rings except the 16696aa000 and then the big fat one that goes on the bottom of the rail. I went the Subaruparts.com to see if they had them for $7 I think.
and just to make sure the giant spacer is only needed if i take the rails off the car right?
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
Mattheww044
Re: How To: 440cc Injectors in Legacy Turbo Rails
OK, so got my injectors from Kleinkid, and just sent them off to WitchHunter, I was going to get them cleaned and tested at the community college for free but decided to go with WitchHunter since they replace the o-rings, seals, and pentils as well. I will post what all is needed after they are sent to WitchHunter to go into the EJ22T rails. Thanks for the info everyone!
Mattheww044
Just an FYI to all of those who buy 440's, and want to send them in to Witch Hunter for cleaning/flow testing:
I Highly recommend these guys, I got my injectors back within about 3 days of sending them in. Total cost was 93.48
This included return shipping, testing (with before and after results), the cleaning itself, and new o-rings and pentils.
I specified on the order sheet that these were going into my 91 SS. For those who send their injectors in to these guys, and want to put them into your turbo legacy rails, the only part you will need is 4X 16608AA020 (Fuel Injector Seal), all others were included.
I will be ordering my 4x 16608AA020 (Fuel Injector Seal) from www.subaruonlineparts.com and they are $5.09 each.
kleinkid
Post by kleinkid »
What were your flow test results? Also, glad these are in the process of working out for you.
Mattheww044
They were pretty good actually. Static flow the worse one was off by 3.5 and the same for pulsed flow @ 2500 RPMS. Still nice to know that they are safe to put on my motor, and the cost of replacing all of those o-rings and stuff probably would have cost well over $50 alone so I am satisfied. Just out of curiousity, will these injectors on my stock EM make me get worse gas milage or anything like that? Run rich?
BSOD2600
Post by BSOD2600 »
Mattheww044 wrote:Just out of curiousity, will these injectors on my stock EM make me get worse gas milage or anything like that? Run rich?
Yes and yes. It will take the ECU hundreds of miles to relearn the fuel trims to get it somewhat close back to spec.
'11 WRX Limited
'94 TW | R.I.P.
Mattheww044
damn. Well I am pretty sure one of my stock injectors is leaking, so I am only getting like 14mpg haha. So do I need to stay out of boost and off the throttle for those couple hundred miles? Not a problem if so, I just want to take everything as safely as possible. Thanks
BSOD2600
Post by BSOD2600 »
When I was on stock ecu + 440cc setup, I seem to recall the wideband just going really rich (like ~10 AFR) any time I got into boost.
Oh yea, you'll likely have a bouncing idle too since the stock fuel trims only can handle like -/+ 14% trims and the ECU needs more than that to control it -- at least the latest Revtronix chip upgrade raised the fuel trim limits to fix a bouncing idle issue I pointed out to him on the forum...
'11 WRX Limited
'94 TW | R.I.P.
Mattheww044
hmmmm.... do you think I should even install the injectors then? Or is it kinda risky on stock EM?
kleinkid
Post by kleinkid »
Install the freakin injectors, already. I had 440's in my car on the stock ECU, yes was a little rich. Made a little soot on the end of the muffler, no big deal. No idle issues. Every car is different, mostly. Don't be a fraidy cat!
Mattheww044
Haha, I'm still waiting on the seals, once those are here I will install them. Bit I'm just curious do I need to stay out of boost and such while the ecu is learning the new fuel trims?
kleinkid
Post by kleinkid »
It certainly wouldn't hurt to drive sanely for a while. You driving this out to Olympus Rally? If so, you'll be fine.. I will be there in my SS also, not my Outback.
