Page 26 of 131
Posted: Mon Jul 25, 2011 12:59 pm
by SWRT
Installed side marker turn signals on my 90 from the 92-94's.
Pain...what a pain.
Posted: Tue Jul 26, 2011 3:37 am
kimokalihi wrote:Yours is a car I would love to have. The attention to detail and care that you've put into your legacy is astounding Josh. Props to you!
Thanks Kimo! I appreciate it
Posted: Tue Jul 26, 2011 8:41 pm
by CAV3MAN227
-Made a quick video of my car with out me in it!
http://www.youtube.com/watch?v=Jl2QV63NATI
-And that's the sound of sanding in the back ground!
-Joe
Posted: Tue Jul 26, 2011 10:06 pm
by SWRT
Holy crap! Your car is like freakin Kit...I wish mine could drive itself.
Makes me want a turbo again...
Posted: Wed Jul 27, 2011 4:11 pm
by silver03
Timing belt and water pump install...and replace the rattiest radiator with a fresh one! 92 L FWD. than replaced upper rad hose. Now, need to replace steering knuckle and ball joint. It never really ends, does it. Funny short story, I started the car after timing belt install for the first time before complete reassembly. Flipped the key, car starts, 2 seconds later hear BAM! I'm thinking OHNOES! LOL, I had pushed a long bolt into the tranny line going to the cooler and the pressure blew it out into the firewall. A mess...yes, but not a valve crashing into a piston!
Posted: Wed Jul 27, 2011 6:56 pm
by SWRT
Did you replace the lower too? The upper usually stays good forever, but the lower sees all the crap.
Haha, well at least it's all good now. Sucks when stuff like that happens.
I was doing timing with my friend on my Legacy one time about 4 am and
we were both half asleep and we had timed it wrong and got it all put back
together only to find out one of the pulleys was 90 degrees off and it wouldnt
crank at all haha
Posted: Fri Jul 29, 2011 6:07 am
by Danny-G
Cleaned bird crap off the roof. What a pain to do in the sun, especially cause the roof is black.
Posted: Fri Jul 29, 2011 12:24 pm
by SWRT
Man...funny bird crap story.
So a few months ago I used to park in the spot right in front of the building every day at a work. Well there was this guy that used to work here and he was disgusting in more ways than I could explain. Well anyway, they hired him back and he started taking my front spot right around the time that these birds showed up. Well I had my spot one day and got my car covered in bird crap. I had washed it off two nights later and found that it removed my clear coat. They must have been eating some pretty potent stuff. Either way I let him have that front spot for a week in his new Altima and started parking about 20' away from the building. He thought he won til he tried to wash the, no lie, at least 50 spots of bird crap off his car at the end of the week.
Posted: Fri Jul 29, 2011 8:20 pm
by Redlined
Finally got my big invenstment for the manual swap. Bought a rebuild 5speed out of an 06 2.5rs. Should have the flywheel and clutch within the month (found a lightweight flywheel for $250)
Posted: Fri Jul 29, 2011 8:43 pm
by Falken-18c
SWRT wrote:Man...funny bird crap story.
birdie birdie in the sky left a poopy in my eye me no mad me no sad me just happy a cow cant fly LOL i read it some where
Posted: Fri Jul 29, 2011 10:05 pm
by SWRT
Does the 5spd have the same gear ratio as your rear diff? I think that makes a difference.
And man..that'd be awesome. I would have put sod all on his roof
Posted: Fri Jul 29, 2011 11:30 pm
by Redlined
According to the guy I purchased the trans from, who seemed remarkably knowledgable, the trans has a 3.90 final drive which is the same as what I have. also, I have a 3.90 VLSD prepped and ready to go in.
Posted: Sat Jul 30, 2011 6:00 pm
by SWRT
Wow, lucky! I wish mine has a LSD.
Posted: Sun Jul 31, 2011 12:18 am
Got a mega update.....I've been lazy updating my build thread.....and I'm going to be lazy now and just link to my update post
http://bbs.legacycentral.org/viewtopic. ... 63#p363763
Posted: Mon Aug 01, 2011 11:58 pm
by TBFK
Replaced the FWD fuse box with a switch and mounted it where my non-working Cigarette lighter is... I don't really have a good reason for doing this. I was just bored and happened to have some extra wire and a switch lying around, so I grabbed and went to work:) lol.
Posted: Tue Aug 02, 2011 3:24 am
by Falken-18c
put new spark plugs in.. then i replaced a fuel pump 255 walbro car woudnt start with original one then next morning car wouldnt start again couldnt hear the fuel pump so re-instaled the original one it worked then cut out then finally realized the conecter that pluged into the fuel pump was all coroded with green crap got electrical spray clened it all up runs good so far. next will to install my sti fmic hopfully this weekend coming
Posted: Tue Aug 02, 2011 8:20 am
by Danny-G
TBFK wrote:Replaced the FWD fuse box with a switch and mounted it where my non-working Cigarette lighter is... I don't really have a good reason for doing this. I was just bored and happened to have some extra wire and a switch lying around, so I grabbed and went to work:) lol.
I did almost exactly that lol. But I put the switch on top of the triple 12v outlet that replaced my ash tray. FWD is fun when you're tires are getting old and you wanna make some smoke
and if you have the habit of shifting you're auto all the time, to the point of driving in parking lots in first, FWD will get rid of any torque bind from the 50/50 and tight turning.
Posted: Tue Aug 02, 2011 12:44 pm
by SWRT
Gonna need some pics Falken
I'm not sure how that fuse even works. Does it disengage the drive shaft from the rear diff?
Posted: Tue Aug 02, 2011 1:17 pm
by kimokalihi
It disables the Duty C solenoid I think which sends 100% of the power to the front wheels via the center diff. How I don't know. lol Clutch pack?
Posted: Tue Aug 02, 2011 6:56 pm
by SWRT
Weird. It seems like it would be bad for it to keep it in FWD mode for long periods of time.
Posted: Tue Aug 02, 2011 9:00 pm
by TBFK
Danny-G wrote:TBFK wrote:Replaced the FWD fuse box with a switch and mounted it where my non-working Cigarette lighter is... I don't really have a good reason for doing this. I was just bored and happened to have some extra wire and a switch lying around, so I grabbed and went to work:) lol.
Lol. FWD is a lot of fun. I don't manually shift my AT though, mostly just leave in in "D" or "3" when drivin around. I use AWD when drivin on dirt or gravel because when you have FWD engaged, it's got to much torque and spins to easily when your not on paved roads.
SWRT wrote:Weird. It seems like it would be bad for it to keep it in FWD mode for long periods of time.
I've been driving it in FWD for about 2 months solid now, and I haven't noticed anything funky happening. I thought it might help me get better gas mileage, but it doesn't help much. maybe like .7 MPG difference...
Posted: Wed Aug 03, 2011 12:27 am
by Danny-G
100% more mud guards! Stock ones front and aftermarket rear. Pictures will come later.
Posted: Wed Aug 03, 2011 1:44 am
Running in FWD mode all the time leaves the Duty C solenoid energized at 100% duty cycle all the time. It is not meant to run that way for extended periods of time. Doing so can possibly reduce its life.
Posted: Wed Aug 03, 2011 1:52 am
by TBFK
Legacy777 wrote:Running in FWD mode all the time leaves the Duty C solenoid energized at 100% duty cycle all the time. It is not meant to run that way for extended periods of time. Doing so can possibly reduce its life.
Thanks for letting me know. I'm gonna keep it set to AWD from now on anyways.
Posted: Wed Aug 03, 2011 2:59 am
by Falken-18c
[quote="SWRT"]Gonna need some pics Falken
yea maybe this weekend ill get some pics up. some day pics nights pics and some gravel dust behind my car pic that gos for a mile lol probly not that last one but will see LMAO also one in the ditch LMAO LETS HOPE NOT
