EJ 22t heads
They collect nice cars dont they? And doesnt that 22b have a broken tranny or it did or something?
Is it at a dealer ship or something? I want to stop by to see it.
In other news: got my cams installed and all the new seals installed in the heads. Any suggestions for getting the old head gasket material off? Will a brass brush for a drill score the surfaces too much.
I also installed my whiteline front diff support bushings and the rear diff mount bushings that I got from Turn in Concepts Hopefully hae pictures this weekend.
douglas vincent
bmx, did you have your heads cleaned, and the valve seats reground, and the valves cleaned and magnafluxed? Cause if you didnt, you should. Exspecially if you are going through all this work.
legacy92ej22t
I took these back before I got my good camera.
SOA's 22B
I should have a pic of the rear badges too but I have to try dig it up.
SOA's 22B
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
you no what kills me, look at the motor pic and the car is uesing our old school coil pack. what is the part number on that and is it better then the dimend one? i still think we have the orignal 22b.
aslo thats one sick car, cant wiat to show you guys my own ver of a 22b, got to paint the wheel center caps and front grill. this friday guys i hope you like it.
douglas vincent wrote:bmx, did you have your heads cleaned, and the valve seats reground, and the valves cleaned and magnafluxed? Cause if you didnt, you should. Exspecially if you are going through all this work.
ADVICE: If you have a car as a hobby/transportation and live on your own, do not work at a bike shop!!!
This hobby sucks
Went to the Hueberger Subaru in COlo springs. I got 5 blank stares when I asked where the 22B was hiding oh well.
Natoe is gonna post the pics of the 22b i found in my heads. why, casue I can pretend to port heads but I cant post frigging pics!!!!
2011 Mini Countryman S All4
1970 Honda Ct90
1970 Honda Ct90
napstermike
22B
The reason some part have 22b stamped in them is simple if you know subaru parts. subaru made the 2.2 and the 2.2T at the same time. to designate a turbo part from a n/a part of the same application, they use a "b" designation at the end. thats where the car name comes from.
22B = 2.2 Turbo
22B = 2.2 Turbo
So has anyone found out what the 22b heads are based on, 2.0 or 2.5 dohc heads? I have spent a week now read much more then i want to about imps on nasioc and they and don't know over there. I also had no luck on the bbs 22b board.
I want to do this build right.
and am willing to wait for the right parts
so anybody? matt? douglas? vrg3? nico?
ps I am sorry if the info is here... somewhere, i am just sick of searching
-Penguin
1978 DL+GL 4WD Wagon (only ever seen 4!!!)
1993 Turbo White Wagon (EJ22t DOHC FMIC, 4.11 5 speed swap with wrx LSD)
1996 Impeza Outback Sport (wifes car)
2002 Suzuki GSXR-1140 Bored and Stroked
(just to much to list... 202mph on radar @ Daytona)
if there was a part number i would go to my work and order the hole set up if new.
the way i see it is there 2.0l heads from the 90s, everywhere but north america had the 2.0l turbo motor in there subarus, we got the ej22t with out the crazy heads for what ever reason. + the 22b is like a 95 to 99 model that came out with the gc body style. i dont no about all this ver1 ver2 ver3 stuff i go bye motor codes and part numbers.
someone HAS to now on this board what heads, valves, springs, head gasket, that motor uses. part numbers would be perfect for me.
whos got the parts manul book on this car?
::cough:: ::cough:: PING! ::cough::
Cause now i have 91 jdm 2.0t heads and pass.side 02 us 2.0t(wrx) head that i can steal the pluming off of and have 2.5 dohc turbo heads ,...
From what i READ from SEARCHING there are people on this board who have used 2.0t and 2.5t heads on the 22t block, but if nobody wants to share....... i will just go sit in the corner and eat wet cigarettes (weeping)
-Penguin
Matt Monson
- quasi-mod-o
22B heads are no different than '98 Ej20K V4 STI heads. The USDM DOHC EJ25 heads are based upon the '97-98 Ej20K STANDARD WRX heads. The STI heads are cast with larger ports, and use solid lifters (versus shim under bucket) along with sodium filled exhaust valves.Penguin wrote:::cough:: ::cough:: PING! ::cough::
The '91 Ej20G heads that you have acquired do have larger ports than standard '98 WRX heads, and they are also larger than the usdm Ej25 DOHC heads (which would make sense). They are also larger than current USDM EJ205 heads. But they are nowhere near as large as the v4 STi ports. I have seen and measured them in person. They have HUGE ports...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
sorry bout the wait for a reply, turns out if you eat 3 packs of wet cigarettes you go to the hospital. j/k I took a GL-10 hood latch to the head and had to get 5 stapels in my head, but enough about me....
Thank you matt!
I knew somebody had the info i wanted.
I am gunna send my 91 ej20jdm heads out. need to search on what are the biggest valves i can get. (or mr. monson might know)
but i am sad so say i am really in no hurry to get this done now, I have been having brake problems lately ( the abs was fully ingageing and making the brakes be on all the time) and after replaceing the abs unit FOR THE SECOND TIME today( btw our abs {AA200}unit goes threw 95) i was backing my wagon into the yard having the e-brake as my only brake and a olddy high idol i scraped the rear driver side on the dumpseter! Man I felt DUMB. but there is no dent just a scratch..., i wanted to paint it anyway.
but thank you again matt (and nico for getting on my wagon)
Thank you matt!
-Penguin
