Page 4 of 4
Posted: Thu May 29, 2008 5:48 am
by stipro
94SS_Canada wrote:im 20mins south of calgary, who fabbed this for you?
Id trade a wrx bpv just for that piece or i could pay you to make me one!
I don't like to toot my own horn, but I made it for him. If you want one Im pretty sure I can build one for you. Let me know.
Posted: Thu May 29, 2008 6:45 am
by Dynamic Entry
Sorry for not responding right away. Yup it was the Pro. And it's very niiice.
If only I had more time/motivation.......
Posted: Thu May 29, 2008 7:56 pm
by 94SS_Canada
My friend fabed one up for me, its not as pretty but works just as well.
Turns out i had a miss, new plugs, And SHE PULLS
i put an 07 sti fuel pump on it and a perrin manual boost controller boosting at 10psi, IM still hitting some sort of cut in the higher rpms but man shes fast!
thanks for the help its been an overall sucess and it it so fun!
Posted: Fri May 30, 2008 6:31 am
by 94SS_Canada
Will WRX blues/ Top feeds fit on my car (440ccs) on stock ecu
Posted: Sat May 31, 2008 6:22 am
by 94SS_Canada
Posted: Sat May 31, 2008 6:25 am
by asc_up
I don't think so. Ours are side feed, I believe.
Posted: Sun Jun 01, 2008 12:39 am
by 94SS_Canada
Posted: Sun Jun 01, 2008 2:46 am
by 94SS_Canada
Whata ya guys think?
Posted: Sun Jun 01, 2008 10:28 pm
by asc_up
Looks good very good.
Two things though, I would put some solder around the straight metal pipe and the 90* pipe that you're using to route to your bypass valve. Just to make sure it isn't leaking at all.
Secondly, I'd try to find a way to put a 90* bend on the end of the rubber hose after the bypass valve. It looks like it's sort of folds over itself and I wouldn't be particularly keen on it dipping so low next to the turbo.
Other than that, it looks great man!
Posted: Mon Jun 02, 2008 6:03 am
by 94SS_Canada
thanks, yes there are still a few things to be moved but it works good!
