So i think i Cracked my turbo, Videos
WEll a responsible owner myself was cleaning my car today, its ran like a top ever since i got it, so i clean off the engine bay and finish with the car, i drive away and all i can feel is shaking i pull oer inspect my engine and see nothing out of the ordinary except for the fact the moter was shaking alot more than it should be, i thought maybe i got water onto a sensor so i left it overnight and the same tings the exhaust is shuddering but the moter seems to be running fine, the restriction seems to be in the exhaust, it not possible i clogged up a cat that quick or did somehow water get into the exhaust it would of evaporated anyways?
please help! Videos too!
http://www.youtube.com/watch?v=xHqSUKnWFko
http://www.youtube.com/watch?v=0-XaDHgReT8
http://www.youtube.com/watch?v=5xGNP87Ox-M
While its idling, start either pulling plug wires or unclipping injector clips. You will find the "dead" cylinder this way because all but one(two) will kill the engine, but the dead one will not make a difference.
Probably a plug wire, or bad plug.
Used a low pressure wash, and it was short but didnt cover any electrical connections, ive removed the turbo and its fine were swapping a TD04 in there right now, i have to modify some stuff and i have a huge question, Is this important to have or can my car be fine without it?
ALso if the coil pack is bad, can i grab one from a NA legacy sitting at pick n pull?
FastRust
The td04... has a 90* outlet, so you need to intercool or rig up some charge pipe.
I think you have things confused. You need to modify the charge pipe because of the 90* outlet.
The TD04 doesn't have a 90* inlet.
I think you meant what I'm saying, just had it worded backwards. Let us know if you need any help!
you may have even developed a miss, that what it sounds like to me. but hard to say through that video.
if you have a temp gauge, check each cylinder when its running, if one is colder then the rest you have a miss, which could be caused by a bad injector or bad spark plug and other stuff but I'd check the 1st two first.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
94SS_Canada wrote:How exactly do i test for a miss, using the temp guage method, guide me in the right direction and i can figure this out, a wrx intercooler will fit around my resoirvoir right?
with these engines, it might be hard, but check the temp of each cylinder on the exterior of the engine. If one is way colder then the rest then that would be the one thats not firing.
