Page 33 of 131
Posted: Thu Sep 22, 2011 9:10 pm
by originalcyn
Gotcha. are the horns on a 12v already? I asked a couple friends who had used super tones in the past, and they said that was as loud as they get, but i should probably try the relay myself and see what i get. it was really easy to just use the existing wires though since i had already extended them to behind the grille.
Here's the mats i picked up:
https://www.subarugenuineparts.com/prod ... cts_id=555
if you do a search for mats there's several different sets for the same price though. I'll try and get you pictures tonight.
also, one of the forester and one of the impreza cargo trays is 20 bucks right now, i got it just to try:
https://www.subarugenuineparts.com/prod ... cts_id=754
https://www.subarugenuineparts.com/prod ... cts_id=264
Need to wash my car, but it's been raining off and on....
Posted: Fri Sep 23, 2011 12:50 am
by originalcyn
Alright, here's the mats:
Driver's Side Front:
Passenger Side Front:
Rear:
I put the tray in too. It says forester instead of subaru, so that was a bummer. It's about 3 inches too short in the back, and the contour is not exactly right, but it's relatively close:
Driver's Side
Passenger Side
Posted: Fri Sep 23, 2011 1:37 am
by kimokalihi
Oh snaps im buying that trunk mat for sure. Thank you so muh for the link!
Just got my car aligned today and it handles great. it was way out of wack.
Posted: Fri Sep 23, 2011 3:10 am
by originalcyn
Yeah no problem. I stole the idea from SiCkSTi04, but I wasn't sure if that cargo tray would fit in the sedan or not. So at 20 bucks...why not.
Posted: Fri Sep 23, 2011 6:40 pm
originalcyn wrote:Gotcha. are the horns on a 12v already? I asked a couple friends who had used super tones in the past, and they said that was as loud as they get, but i should probably try the relay myself and see what i get. it was really easy to just use the existing wires though since i had already extended them to behind the grille.
Are you asking whether the existing horns are on a 12v relay? If so, yes they are. However the stock wiring is not as large and runs longer, so you won't get quite as much juice out of them. If they sound fine now, they should be good. The wiring in my car may have just been older...who knows.
Thanks for the links and pictures of the floor mats.
Posted: Sat Sep 24, 2011 11:05 am
by originalcyn
Josh, my pleasure. It's the least i can do for someone who is constantly helping me and everyone else on the forums. Let me know if you want any other specific pictures of the mats.
Posted: Sat Sep 24, 2011 11:56 am
by silver03
flushed heater core, new OEM t-stat and lower rad hose in 92L.
Posted: Sun Sep 25, 2011 3:36 am
by originalcyn
stereo install...
Posted: Sun Sep 25, 2011 7:28 am
by SILINC3R
finally got serious and installed an aux fuse panel for my guages and then wired up my Hellas to the factory wiring.
Posted: Sun Sep 25, 2011 7:45 am
by kimokalihi
I need to do that too and install my adjustable intermittent wiper multiswitch. Was gonna buy a really cool dual readout device that goes in the vent for my afr and boost but im saving the money instead so i might as well install the gauges for the time being. Hate ghetto stuff like gauges hanging by wires.
Posted: Sun Sep 25, 2011 2:17 pm
by silver03
Replaced an inner torn boot on right side cv axle on 01 RS. What did I learn?
-A magnetic punch made life so much better putting that roll pin back in.
-One of the holes on the green cup is counterbored...use that side to push the roll pin back in
-there is really no practical substiute for C-clip pliers (home depot $20 for a good pair)
-I hate those clamps, have 2 "normal" screw type clamps on hand to replace them with
-remember to mark your camber bolt position (I did)
Posted: Thu Sep 29, 2011 7:05 am
by originalcyn
Finished up stereo finally.
Posted: Thu Sep 29, 2011 8:21 am
by Falken-18c
striped parts off a spare 22t block gunna take heads off and split it this weekend
Posted: Fri Sep 30, 2011 1:26 am
by 91legacyawdturbo
Well more what I did last night got a 15.42 1/4 @ 82mph, had issues dialing in my desired boost, with out hitting fuel cut lol.
Posted: Fri Sep 30, 2011 8:19 pm
by Mattheww044
Be careful with that tranny!!! Just blew mine at the drag strip and I'm on revtronics stage 2 chip setup an a few other goodies. That tranny is not meant to br launched hard
Posted: Fri Sep 30, 2011 8:53 pm
by 91legacyawdturbo
^ haven't had any issues with this trans, I do happen to have a spare tranny, might go get another one, I will need a 6spd soon though.
Posted: Sat Oct 01, 2011 6:49 am
by CAV3MAN227
-I need a tranny!
-Joe
Posted: Sat Oct 01, 2011 7:19 pm
by 91legacyawdturbo
^ Joe I know of a tleg trany in town call me.
Posted: Mon Oct 03, 2011 5:59 am
by Mattheww044
CAV3MAN227 wrote:-I need a tranny!
-Joe
I second that!! haha. I can't find a stock replacement for crap, can't find a JDM tranny for crap, might just get a WRX tranny until i can afford straight cut gears or 6mt whatever I decide doing later on down the road.
Today: Started re-locating my coolant tank to the "ABS mount" location, and working on getting all new studs/bolts/nuts for my JDM TD05 I got for $100, no shaftplay. I sold my TD04 for $100 as well so i basically got a JDM Td05 for free
Posted: Mon Oct 03, 2011 6:09 am
by Falken-18c
i have a 93 turbo 5speed tranny siting nice in cozy in the garage its nice to have spare parts lol.
Posted: Mon Oct 03, 2011 6:22 am
by 91legacyawdturbo
Yes it is even if the tranny doesn't have a reverse it still good to go forward, (wrx case, tleg gears)
Posted: Mon Oct 03, 2011 10:23 pm
by SILINC3R
Replaced some of the gray interior with black interior from a TW. Door cards, dash and front seats swapped.
Posted: Tue Oct 04, 2011 4:59 am
by Danny-G
Been building a new light bar. Its all bolt together since I don't have access to a welder. I'm almost finished with it, gotta add a vertical brace from the old bar the the new upper bar then paint it black and be done with it. Currently, it shakes like crazy and looks pretty bad since the top angle iron bar is red and white while the two bars that come out from under the hood are rusty, lower bar is still orange. Pictures to come once its finished whice should be tomorrow. Oh yeah, I just remembered. Today, marked 260,000 on the entire car. What a great car, I love it. Edit, mileage picture.
Posted: Wed Oct 05, 2011 7:34 am
by Danny-G
Didn't finish the light bar but I did paint it black so it looks a ton better. And installed a '98 Outback maplight/sunglass holder, that was quite the project. Had to pull the headliner, cut out the map light hole a whole lot, switch the plugs between the map light units, re-install the headliner, and put the Outback maplight/ sunglass holder in. Theres a few gaps and the colors don't match but I don't really care. Its a sweet addition. No pictures though as I finished at 10:45 pm.
Posted: Wed Oct 05, 2011 12:16 pm
by SWRT
Dang. I was hoping to see pictures of that light bar
