spark plug change hints and cautions
Locked
ssspoon@aol.com
Post by ssspoon@aol.com »
Well, I have changed plugs on a couple of cars over the four decades I have been fooling around playing backyard mechanic.
The US Turbo Legacy is not what I would consider an easy change, and sounds like the RS is even worse.
Here's some tips if you decide to tackle it. The fronts are a breeze but the rears can be murder.
Make sure your plug wires are distinctive or numbered or something so you don't mix them up.
Wait till the engines cooled off so you can touch any part without a reflexive jerk. If it's too hot, you'll get your skin onto something, snatch away, and rake your hand open on something sharp. The plugs stay hot longer than just about anything else on the outside of the engine so they can get you too.
Get some heavy gloves. You might be tugging at a wrench to untighten a plug, it will break free all of a sudden, and you'll smash your knuckles on something hard or sharp or both.
Do the front first. Just barely break them free with the wrench then feel how easy or hard they are to unscrew by hand. After you take one out, screw it back in by hand. You might need a little oil on the threads. Notice whether it goes in easily all the way or hangs up anywhere. Repeat the process with the rear.
The main reason for this exercise is to learn the "feel" and direction of each hole. You would like to screw by hand as much as possible because with the Aluminum heads, it's real easy to crossthread the hole without knowing it till it's too late, when you have the mechanical advantage of a wrench, and really jack up everything. You can't crossthread with finger pressure.
If you don't have the right tools to pull the plugs right out nice and easy without any side pressure, you run a good chance of crossthreading if you use that tool to install if they're not screwed way in by hand.
Try to get some rubber gizmo that will grip the plug. One time I let the sucker slip down under the intake manifold, and after two hours of trying everything I had to ask the little girl next door to help me out with her tiny hands.
Good Luck
Larry Witherspoon
4260 W 182nd St.
Torrance (Los Angeles), CA 90504
day/office phone 562-982-7720
larry.d.witherspoon@boeing.com
ssspoon@aol.com
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.1994012.34 ... ?code=3466> Click Here!
<http://us.adserver.yahoo.com/l?M=194081 ... =699073807>
INCEv@webtv.net
Post by INCEv@webtv.net »
"Small hands" A little trick that I learned is to get a piece of rubber
radiator hose that fits(tightly) over the porcelain,about 15" long will
be enough. Good luck! Dan
milehial2000
Post by milehial2000 »
Here is something that I came up with that might be of help. On the
turbo engine I been reading plugs and have settled on NGK BKR6E11 this
is a little hotter than stock and seem to work better but this
possibly could be due to the altitude here.
AL(CO)
rubber
will
I have
sounds
breeze but the
so you
> don't mix them up.
something, snatch
hot longer
can get
> you too.
untighten a plug,
on
then feel
out, screw
Notice
the
direction of
because with
knowing it
wrench, and
pressure.
and easy
if you use
let the
trying
with her
> tiny hands.
> Good Luck
> Larry Witherspoon
> 4260 W 182nd St.
> larry.d.witherspoon@b...
> ssspoon@a...
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
Josh Colombo
Post by Josh Colombo »
Al,
That's the stock plug for the 2.2 N/A motor. What is the benefit from running colder or hotter plugs....seen people do this....but don't fully understand the reasoning behind it.
thanks
josh
-----Original Message-----
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Thu 4/11/2002 119 AM
Cc:
Subject: Re: Fwd: [BC-BFLegacyWorks] spark plug change hints and cautions
AL(CO)
rubber
will
I have
sounds
breeze but the
so you
> don't mix them up.
something, snatch
hot longer
can get
> you too.
untighten a plug,
on
then feel
out, screw
Notice
the
direction of
because with
knowing it
wrench, and
pressure.
and easy
if you use
let the
trying
with her
> tiny hands.
> Good Luck
> Larry Witherspoon
> 4260 W 182nd St.
> ssspoon@a...
Buy Stock for $4
and no minimums.
FREE Money 2002.
DNA_Man
Post by DNA_Man »
"When the spark occurs, all the thermal energy (heat) is transferred
to the fuel/air mixture, where it initiates combustion. A hotter
spark will transfer more thermal energy and therefore accelerates
flame front propagation. The fuel is used more efficiently and engine
performance increases."
I don't personally believe that the slight increase in heat can make
that much difference... anyone have a better explanation? Anyone know
how much total energy increase there is? I don't think it makes that
much difference when you divide the relatively small amount of energy
in the spark by the relatively huge amount of air and fuel in the
chamber...
--- In BC-BFLegacyWorks@y..., "Josh Colombo" <josh@s...> wrote:
> Al,
> thanks
> josh
> From: milehial2000 [mailto:acroxford@h...]
> To: BC-BFLegacyWorks@y...
> Cc:
and cautions
On the
BKR6E11 this
> AL(CO)
piece of
> rubber
15" long
> will
four decades
> I have
change, and
> sounds
are a
> breeze but the
something
> so you
> > don't mix them up.
without a
> something, snatch
plugs stay
> hot longer
so they
> can get
> > you too.
> untighten a plug,
knuckles
> on
wrench
> then feel
take one
> out, screw
threads.
> Notice
anywhere. Repeat
> the
> direction of
possible
> because with
without
> knowing it
of a
> wrench, and
finger
> pressure.
out nice
> and easy
crossthreading
> if you use
time I
> let the
hours of
> trying
me out
> with her
> > tiny hands.
> > Good Luck
> > Larry Witherspoon
> > 4260 W 182nd St.
> > ssspoon@a...
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to
DNA_Man
Post by DNA_Man »
Altitude makes a difference... my car has noticeably more power when
I go to nebraska. Here in Boulder it's sucking less air, or less
dense air, so it makes sense. Al, are you part of the RallyCross
program out here? I'd love to see you run with us some time. We have
a race scheduled for the 28th if you're interested. Email me off-list
for details (dan@soobeerally.com or soobeerally@yahoo.com). I'm the
organizer of the events around here, so I can answer pretty much any
question you have...
BTW, I use an old piece of fuel line to grab the plugs when
installing them. Also I use anti-seizing compound instead of oil on
the threads. This seems to work well, and makes the job much easier
the next time (my mom let her SAAB rust for 2 years without driving
it... plugs I put in before came right out). I have to remove the
washer bottle on my 1990 L sedan to make the rear plug easier to get
at on that side, but the rest of them are relatively easily
accessible... if you have the exact right size extension for your
socket wrench :)
this
> AL(CO)
> rubber
long
> will
decades
> I have
and
> sounds
> breeze but the
something
> so you
> > don't mix them up.
without a
> something, snatch
> hot longer
they
> can get
> > you too.
> untighten a plug,
knuckles
> on
> then feel
> out, screw
> Notice
Repeat
> the
> direction of
> because with
without
> knowing it
> wrench, and
> pressure.
nice
> and easy
crossthreading
> if you use
> let the
of
> trying
> with her
> > tiny hands.
> > Good Luck
> > Larry Witherspoon
> > 4260 W 182nd St.
> > ssspoon@a...
Kwick Pick opens locked car doors,
front doors, drawers, briefcases,
padlocks, and more. On sale now!
http://us.click.yahoo.com/ehaLqB/Fg5DAA ... /XoTolB/TM
Josh Colombo
I can see putting a hotter plug in.....but what about a colder plug....I've heard a couple people do that.....only reasoning I can come up with is they're having issues with detonation.....but not sure.
I agree with you that a hotter plug is not really going to change the flame front velocity or anything like that. The spark plug is basically there to put enough energy (activation energy) into the air/fuel mix to ignite the mix and start it burning. In general, the faster your flame front velocity the more complete burn you recieve....you can also assume too, the air fuel are mixing more thoroughly in the cylinder if you have a faster flame front.....
I just got done with an engines class last week....some really interesting information in there. It was tailored more towards large industrial 2000+ hp engines....however an engine is an engine is an engine......
Sent: Thu 4/11/2002 14 PM
Cc:
chamber...
> Al,
> thanks
> josh
> Cc:
and cautions
On the
BKR6E11 this
> AL(CO)
piece of
> rubber
15" long
> will
four decades
> I have
change, and
> sounds
are a
> breeze but the
something
> so you
> > don't mix them up.
without a
> something, snatch
plugs stay
> hot longer
so they
> can get
> > you too.
> untighten a plug,
knuckles
> on
wrench
> then feel
take one
> out, screw
threads.
> Notice
anywhere. Repeat
> the
> direction of
possible
> because with
without
> knowing it
of a
> wrench, and
finger
> pressure.
out nice
> and easy
crossthreading
> if you use
time I
> let the
hours of
> trying
me out
> with her
> > tiny hands.
> > Good Luck
> > Larry Witherspoon
> > 4260 W 182nd St.
> > ssspoon@a...
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
milehial2000
I don't think that altitude would make very much difference the
mixture should be close because the ECU receives barometric pressure
info. I just threw that in because the stock turbo plug should work
and I can't see any other reason for them being dark when I pull them
and a few other people have also commented on this. As far as
detonation goes if that occurrs it's my opinion that what is wrong in
most cases is low quality gas or to much boost. I run 15 lbs most of
the time and have run 20 at times and have no problems with detonation
although you are right a too hot of a plug will cause preignition in a
heartbeat. I was just thinking that the plug should look "good" when
pulled.
AL(CO)
sure.
engine......
> Josh
> From: DNA_Man [mailto:dna_man@y...]
> Cc:
and cautions
transferred
hotter
accelerates
engine
can make
Anyone know
makes that
energy
the
> chamber...
wrote:
> > Al,
benefit
this....but
> > thanks
> > josh
> > Cc:
hints
> and cautions
help.
> On the
NGK
> BKR6E11 this
but this
> > AL(CO)
get a
> piece of
> > rubber
porcelain,about
> 15" long
> > will
the
> four decades
> > I have
easy
> change, and
> > sounds
fronts
> are a
> > breeze but the
numbered or
> something
> > so you
> > > don't mix them up.
any part
> without a
skin onto
> > something, snatch
The
> plugs stay
> > hot longer
engine
> so they
> > can get
> > > you too.
wrench to
> > untighten a plug,
your
> knuckles
> > on
with the
> wrench
> > then feel
you
> take one
> > out, screw
the
> threads.
> > Notice
> anywhere. Repeat
> > the
"feel" and
> > direction of
as
> possible
> > because with
the hole
> without
> > knowing it
advantage
> of a
> > wrench, and
with
> finger
> > pressure.
right
> out nice
> > and easy
> crossthreading
> > if you use
by hand.
plug. One
> time I
> > let the
after two
> hours of
> > trying
help
> me out
> > with her
> > > tiny hands.
> > > Good Luck
> > > Larry Witherspoon
> > > 4260 W 182nd St.
> > > ssspoon@a...
> > Buy Stock for $4
> > and no minimums.
> > FREE Money 2002.
to:
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Hi Josh, I did think that the dark plugs were from the chip we were
talking about but other people have mentioned this also besides the
chip tends to enrich the mixture during acceration by design to try
and retain good milage and this is a consistant dark plug syndrome
high speed low speed makes very little difference. It's just that they
should look good and it could have some effect on all around
performance.
AL(CO)
> Al,
> thanks
> josh
> Cc:
and cautions
On the
BKR6E11 this
> AL(CO)
piece of
> rubber
15" long
> will
decades
> I have
change, and
> sounds
a
> breeze but the
something
> so you
> > don't mix them up.
without a
> something, snatch
stay
> hot longer
so they
> can get
> > you too.
> untighten a plug,
knuckles
> on
wrench
> then feel
take one
> out, screw
threads.
> Notice
Repeat
> the
> direction of
possible
> because with
without
> knowing it
of a
> wrench, and
finger
> pressure.
out nice
> and easy
crossthreading
> if you use
time I
> let the
hours of
> trying
out
> with her
> > tiny hands.
> > Good Luck
> > Larry Witherspoon
> > 4260 W 182nd St.
> > ssspoon@a...
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
Buy Stock for $4
and no minimums.
FREE Money 2002.
Toby Corkindale
Post by Toby Corkindale »
Sounds like you need a colder plug.
The plug temperatures about about their ideal temperature for self cleaning.
If your plug is dirty, then your combustion isn't hot enough to clean the
plug, so get a colder plug. I think.
-Toby
> performance.
> AL(CO)
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
I don't quite understand why you would want a colder plug to make your combustion hotter? You're mix would ignite just a tad later....producing less peak firing pressure....which would produce lower temps......
I understand the hotter plug thing.....but I still don't understand why you want colder plugs unless you had a turbo running shitty high boost, or high compression engine that would have a tendency to pre ignite......
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
From: Toby Corkindale [mailto:tjcorkin@sa.pracom.com.au]
Sent: Thursday, April 11, 2002 7:16 PM
cautions
-Toby
> performance.
> AL(CO)
Buy Stock for $4
and no minimums.
FREE Money 2002.
Toby Corkindale
Hmm.. Yes and no.
My old mechanic told me that a colder plug means its self-cleaning
temperature is lower, and the idea is to match plug temperature to
combustion temperature. This would then keep the plug clean.
According to that theory, you want a colder-rated plug.
However, I read that post from ssspoon@aol.com about autolite plugs, and
that said the temperature rating actually varied the heat the plug generated
itself.
According to that theory, you want a hotter-plug.
So now i'm not sure if my old mechanic was right or wrong, or if i
misunderstood him. I reckon i'd go with the post from ssspoon being right.
sorry
Toby
> lower temps......
> ignite......
> Josh
> cautions
> -Toby
Buy Stock for $4
and no minimums.
FREE Money 2002.
Locked
