JDM Automatic Air controller could fits to US?
Does anyone knows that the JDM Automatic Air Controller could
directly replace to our OEM air controller??
Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA ... /XoTolB/TM
Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
If you mean the Idle Air Control valve I am sure that the two units
are identical with the exception of the air inlet. The EJ22t inlet
faces up and the EJ20t inlet faces down but this can be changed. The
air inlet is pressed into the housing and can be removed turned and
replaced with a small amount of a good epoxy such as JB weld.
AL(CO)
> Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
AL(CO)
> Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
The automatics and manual trans have different IAC valves. The autos have a temp dependant valve, as well as an electro magnetic rotary valve. The manuals just have a temp dependant valve.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
-----Original Message-----
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Saturday, April 20, 2002 9:21 PM
Subject: [BC-BFLegacyWorks] Re: JDM Automatic Air controller could fits
to US?
AL(CO)
> Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
to US?
AL(CO)
> Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
The only strange valve I can remember was the two terminal type on the
'90-91 and I think that was only the automatics but it had a rotary
valve if I remember correctly. I can check the parts book in the
morning and if there is a difference that may explain why I am having
problems with the idle on the EJ22t of mine as that came out of an
auto and has the rotary valve. What do the three wires connect to on
the manual cars?
AL(CO)
> Josh
> Josh Colombo
> Josh@s... <mailto:Josh@s...>
> From: milehial2000 [mailto:acroxford@h...]
> To: BC-BFLegacyWorks@y...
fits
> to US?
> AL(CO)
> > Ben
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
the manual cars?
AL(CO)
> Josh
> Josh Colombo
fits
> to US?
> AL(CO)
> > Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
Well....according to the FSM.....the manual trannies only have two wires goin to the IAC valve. If the connector has three wires goin to it, it could just be a dummy wire.....if you look inside the actual IAC valve, there "should" only be two pins in there.
If there's three, the outer ones, pins 1 & 3 are the only active ones.....or should be.
I did some more looking.....I guess there still is a coil, and duty valve on the IAC for the manuals.....however it is not a rotary valve.
Here's some diag tests you can run to see if the electronic portion of the valve is good.
No 1 - No 3 / 9.6 ohms [MT]
No 1 - No 2 / 9 ohms [AT]
No 2 - No 3 / 9 ohms [AT]
On the MT valve....both leads 1 & 3 go back to the ECU.
On the AT valve....leads 1 & 3 go to ecu, and 2 ties into the ignition relay......not exactly sure how, or what it's doin.......if you want I can try and scan in the diagram.
Not sure if that helps at all......
Josh Colombo
Sent: Sunday, April 21, 2002 8:42 AM
to US?
the manual cars?
AL(CO)
> Josh
> Josh Colombo
fits
> to US?
> AL(CO)
> > Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
to US?
the manual cars?
AL(CO)
> Josh
> Josh Colombo
fits
> to US?
> AL(CO)
> > Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
Sorry guys, but I mean the A/C or vant controller like the one on the
center part of your car under the cup holder!
I saw the JDM using the automatic air condition controller, I would
like to ask my frined to find me one in Japan but don't know will it
works or not!!
How about in AU or OZ? does your BC/BF car comes with it??
Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
works or not!!
Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
the Automatic Air Controller look is like below:
http://page4.auctions.yahoo.co.jp/jp/auction/d16206689
Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
Hmmm.....I know there was automatic climate control on the early
legacies......I'm just not sure what's involved in switching over.
There are several different sensors you would need. Ambient outside
temp sensor, sun load sensor, inside temp sensor....those would be the
bare necessities, as well as the controller. Not sure if you're
interested in getting all the components together or not.
Josh Colombo
Sent: Sunday, April 21, 2002 53 PM
to US?
Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
to US?
Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
I think they call it climate controll, and I know that they had them. I'll
see if I can find a picture.
>From: "ej22t" <b.lam@usa.net>
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>Subject: [BC-BFLegacyWorks] Re: JDM Automatic Air controller could fits to
>US?
>Date: Sun, 21 Apr 2002 21:59:43 -0000
>works or not!!
>Ben
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
Buy Stock for $4
and no minimums.
FREE Money 2002.
>US?
>works or not!!
>Ben
Buy Stock for $4
and no minimums.
FREE Money 2002.
erm... my 91 Legacy auto air con doesn't look like this...
----- Original Message -----
Sent: Sunday, April 21, 2002 112 PM
Subject: [BC-BFLegacyWorks] Re: JDM Automatic Air controller could fits to US?
Ben
Ben
