intercooler pump
Locked
Doug Hancock
intercooler pump
Post by Doug Hancock »
How much does a standard RS liberty intercooler pump flow. I wish to up
grade to a higher flowing pump.
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA ... /XoTolB/TM
Ian Shastko
intercooler pump
Post by Ian Shastko »
the biger the better in this case. look for a Surflo RV type pump. but make
sure its designed for contiual use. I had a water/air intercooler setup and
there is alot of info in the achives if you look under water /air inter
cooler orwater pump.
>From: "Doug Hancock" <Doug_hancock@optusnet.com.au>
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>To: <BC-BFLegacyWorks@yahoogroups.com>
>Subject: [BC-BFLegacyWorks] intercooler pump
>Date: Wed, 1 May 2002 22:50:12 +1000
zQz:
http://photos.msn.com/support/worldwide.aspx
Buy Stock for $4
and no minimums.
FREE Money 2002.
rodeddy
intercooler pump
Post by rodeddy »
make sure you get as folw rate that will not be too much. Otherwise
you will not get the full heat exchange from the front radiator.
Not enough flow is bad as is too much.
I have an mrt larger front intercooler radiator and std pump, this
works excellent. Contact MRT and they may be able to help, i know
they sell a high flow pump if this si what you want.
The RS pump is a 2 speed unit, when the throttle gets to 80% open it
goes into high flow mode. Unless your doing track work the std pump
will flow enough, to help this better disperce heat go the larger
intercooler radiator.... also the water/coolant ratio will make a
difference as water obsorbs heat better than coolant.
cheers, Rod
--- In BC-BFLegacyWorks@y..., "Doug Hancock" <Doug_hancock@o...>
to up
Buy Stock for $4
and no minimums.
FREE Money 2002.
Doug Hancock
intercooler pump
I wish to get into track work later on. So If I'm upgrading it may as well
be for that. I will get MRT's radiator but I think that $400 AUD is a bit to
excessive. I was thinking of an irrigation pump but this may be the same
price. Is the standard pmup 2 speed or is there a control unit that does
this.
-----Original Message-----
Sent: Thursday, 2 May 2002 4:48 PM
Subject: [BC-BFLegacyWorks] Re: intercooler pump
cheers, Rod
to up
Buy Stock for $4
and no minimums.
FREE Money 2002.
rodeddy
intercooler pump
Post by rodeddy »
if you are going the trackwork you may need both, the larger
intercooler radiator also. It's nice to be able to flow more cooling
water but if the heat exchager is not big enough it won't work.
the pump speed is controlled by the ecu and solenoid/relays (affixed
to the rear of the o/s/f suspension tower in the engine bay)
The pump operates normally at 28watts, 15l /min, and at 50watts when
on high speed (throttle open 80% or more).
Maybe there is someway to overide the ecu and rig up a switch to have
the pump go into high mode when you want. You would need to speak to
an auto electrician. At least with the switch you could run normal
when not racing, will probably make your pump last longer.
The whole system only holds 1.9 litres of water that's why the larger
radiator helps also, i think it increase it to 2.2 litres.. cannot
remember.
cheers, Rod
as well
a bit to
same
does
> this.
> From: rodeddy [mailto:melrod@o...]
> To: BC-BFLegacyWorks@y...
> cheers, Rod
> to up
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Buy Stock for $4
and no minimums.
FREE Money 2002.
Doug Hancock
intercooler pump
I was going to update the radiator but thought of this idea. I would like to
here som sugestions. Every body knows that the Air to water unit is good
when at the lights because it is always being cooled but not the best at the
track. I was thincking of adding an Air to Air unit at the front but retain
the Air to water unit as well. What does every body think of this idea. Yes
it will be a complex task. What I really want to know is it going to work.
Sent: Friday, 3 May 2002 3:19 PM
remember.
cheers, Rod
as well
a bit to
same
does
> this.
> cheers, Rod
> to up
Buy Stock for $4
and no minimums.
FREE Money 2002.
rodeddy
intercooler pump
Post by rodeddy »
Doug,
i would send an email to Ben at MRT about this topic. I'm sure he
used to do trackwork with his RS, sold it ages ago, and remember him
telling me that with the larger front intercooler he never suffered
from heatsoak during any racing....
having 2 intercooler systems sounds too involved.. and costly.
Upgrade the std one and never have a problem, looks std and will be
more reliable..
cheers, Rod.. in oz.
would like to
good
best at the
but retain
idea. Yes
to work.
cooling
have
to
larger
> remember.
> cheers, Rod
> as well
is
> a bit to
the
> same
that
> does
> > this.
Otherwise
it
pump
> > cheers, Rod
wish
> > to up
Buy Stock for $4
and no minimums.
FREE Money 2002.
Locked
