93 Legacy GT-S2 Wagon
Locked
paul.travers@vodafone.co.
Post by paul.travers@vodafone.co. »
Hello
I recently saw the light, and traded in my 1992 Honda for a 1993 Japanese
Spec. GT-S2 Wagon, AWD 2.0L Turbo, 4-Speed Auto. It is completely factory
standard, and while I am (extremely) happy with the engine performance, I
am looking to slightly modify the suspension and/or wheels/tyres setup to
improve the handling. Wheels are standard -- 205/60/R15.
Does anyone have any advice on tightening the handling for wagons? Not
wanting to race or anything, just reduce the body roll (which can be
alarming on tight/windy roads, compared to my honda hatchback which took
corners nicely at speed).
Also - will I get any discernable increase in power from fitting a sports
air filter (K & N, Apexi, etc), or is a fatter exhaust the only way to go?
cheers
Paul
Auckland, New Zealand
Have you seen our website?.... http://www.vodafone.co.nz
CAUTION: This correspondence is confidential and intended for the named recipient(s) only.
If you are not the named recipient and receive this correspondence in error, you must not copy,
distribute or take any action in reliance on it and you should delete it from your system and
notify the sender immediately. Thank you.
Unless otherwise stated, any views or opinions expressed are solely those of the author and do
not represent those of Vodafone New Zealand Limited.
21 Pitt Street, Private Bag 92161, Auckland, 1020, New Zealand
Telephone + 64 9 357 5100
Facsimile + 64 9 377 0962
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA ... /XoTolB/TM
Sam & Beth Barrett
Post by Sam & Beth Barrett »
Paul,
Firstly, congradulations on the purchase and welcome to the group!
Sounds to me like the best bang for your buck would be new rubber to start.
Then maybe replace your shocks and struts with something a little sportier.
In doing so, you would get the response you were looking for with minimal $$
commitment. I Don't recommend the upgrade to 17" unless you intend to
upgrade the brakes and rotors, although that may be adviseable later...
Fatter exhaust is advisible for your application, however the performance
increase/$$ spent ratio is not very impressive. If I had to choose between
the two, I'd say you would get more bang for your buck from the intake, be
forwarned: the MAF sensor is an expensive item to replace if you fuxor it up
with the wrong intake. Search the archives for more info on that.
By the sounds of it, you are still in the honeymoon period of Subaru
ownership. After a while you might want to start adding and changing more
and more on the car. I would advise you to keep your purchases and changes
fairly straight forward to start. Later when you have a goal in mind
(rallycross, rally, autocross, sprints, horsepower, etc.) set your sights on
what will get you there and work your way through the proper upgrade path.
Or you can do whatever the hell you want and tell me to screw off because
you are having so much fun with your car and you aren't as serious about
what you do with it as some of the rest of us. That's fine too!
01=my two bits,
-Sambo
-----Original Message-----
From: paul.travers@vodafone.co.nz [mailto:paul.travers@vodafone.co.nz]
Sent: Wednesday, May 01, 2002 4:17 PM
Subject: [BC-BFLegacyWorks] 93 Legacy GT-S2 Wagon
Hello
cheers
Paul
recipient(s) only.
you must not copy,
the author and do
Buy Stock for $4
and no minimums.
FREE Money 2002.
Ian Shastko
Post by Ian Shastko »
If thats the twin turbo be very carefull when considering a larger exhaust.
I have a friend outside of melborn who had one with a 3" exhaust from the
turbo back and the first turbo would always fail and have to be rebuilt.
Everyone I've herd from says don't go bigger than 2 1/2" all the way back.
Ian
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>Date: Thu, 2 May 2002 11:16:58 +1200
>Hello
>cheers
>Paul
>recipient(s) only.
zQz:
http://photos.msn.com/support/worldwide.aspx
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
Post by Josh Colombo »
Good things being mentioned here.....I'm mainly going to comment on the
cautions. If you do have the Twin Turbo, do not do anything or much to
it. The small turbo is a roller bearing turbo, and is easily over
spooled, and can cause like Ian said, need to be rebuilt.
As for intake....I'd really and highly recommend you just get a K&N drop
in panel filter, and remove the snorkel stuff in the fender.
I have replaced a MAF sensor $300 US. NOT CHEAP....worst thing is it
slowly went out...intermittently I would loose power....I chased this
problem for over a year. Second reason to leave the intake
alone.....you will be sucking hot air from the engine bay....plus you
will get more turbulent air, and MAF doesn't like that as much.
Check out this thread
http://pub1.ezboard.com/fultimatesubaru ... rationofsu
barus.showMessage?topicID=4495.topic
I just wrote this up like 10 minutes ago. It talks about me putting my
stock box back on and how much of a drastic improvement in engine idle
and smoothness there is. I also mention what I am going to do to
hopefully increase air flow for the stock box.
Instructions on how to remove the snorkel and such from the fender well
can be found here
http://www.remarcable.net/misc/legacy_o ... kusectomy/
Hope that helps.
If you have any questions, just holler.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
Sent: Wednesday, May 01, 2002 8:51 PM
Subject: Re: [BC-BFLegacyWorks] 93 Legacy GT-S2 Wagon
exhaust.
the
back.
Ian
>Hello
Japanese
factory
I
to
took
sports
go?
>cheers
>Paul
>recipient(s) only.
it
those
zQz:
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Buy Stock for $4
and no minimums.
FREE Money 2002.
John Gillon
Post by John Gillon »
Hi Paul and fellow Kiwi,
For local sources... King springs, KYB or Bilstein struts. Do the exhaust
and cone/pod type filter at the same time.... a 2.5 inch diameter complete
system from Autobend in Christchurch is good quality and if you get it trade
price through a friend / bonafide channel they are cheap!
For future posting, refer to your GT-S2 as a BC-BF with the EJ20 turbo
motor. The USA have a locally unique low-boost turbo EJ22 variant, and did
not get the EJ20 turbo.
For the USA crowd, the GT-S2 is a BBS wheeled, all leather interior, all
bells & whistles version of the GT (turbo EJ20 of course)
John Gillon
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Thursday, May 02, 2002 11:16 AM
> Hello
> cheers
> Paul
recipient(s) only.
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Post by milehial2000 »
(long) On the air filter where I saw the most improvement was
when I managed to get the K&N under the front fender the combination
of a better flowing filter and the cooler air really improved
matters.
(5-10hp??)I measured the underhood temperature vs underfender on a
fairly hot day in medium traffic and came up with 177 degrees under
hood and 94 under the fender I then added some ventilation to the
under the fender location. There was a picture of it in the files
section titled "oil separator" but that may have been archived or
removed as it was old news. e-mail me if interested. I intend on
making the setup better now that I have a lead on some flex silicon
hose.
AL(CO)
--- In BC-BFLegacyWorks@y..., paul.travers@v... wrote:
> Hello
Japanese
factory
performance, I
setup to
Not
took
sports
to go?
> cheers
> Paul
Buy Stock for $4
and no minimums.
FREE Money 2002.
Locked
