idle probs
Locked
b4b42000
idle probs
Post by b4b42000 »
I would be seeing if you can borrow a idle speed control unit(under
the inlet man).....I have seen heaps of libertys with idle problems
and this has been the cause 9 times out of 10......on a select
monitor this is recorded as a %.....it normally falls in the
40/42%..........have you done a basic check on the a/f meter and tps
switch???
Take the Yahoo! Groups survey for a chance to win $1,000.
Your opinion is very important to us!
http://us.click.yahoo.com/NOFBfD/uAJEAA ... /XoTolB/TM
Josh Colombo
idle probs
Post by Josh Colombo »
I have swapped out the MAF sensor with an older one i have, same goes with TPS sensor, and IAC valve. The IAC & TPS were off a used vehicle, not new....but I can't see it acting the same with two different parts. The TPS was set and adjusted according to the FSM's. Electric portion of the IAC valve was marked and put back to where it was supposed to be.
I'm hopefully going to get my coolant temp sensor today....HOPEFULLY, and will try that.
Other thought someone mentioned was fuel pressure regulator. I guess it's possible.....I'll have to get a gauge and do some testing if the coolant temp sensor doesn't fix it.
All this started after I ran some cleaner through the throttle plate and such. I had thought it was a vacuum leak....but it doesn't act like a vacuum leak.....the idle will sometimes shoot up all of a sudden.....I'm really quite baffled.......unless I have two bad IAC valves.
If I can't figure it out......I'll have to break down and take it to the dealer to let them use the select monitor to see what some of the readings are.
Any input would be greatly appreciated.
-----Original Message-----
From: b4b42000 [mailto:abcdefg.abcdefg@optushome.com.au]
Sent: Fri 5/17/2002 92 AM
Cc:
Subject: [BC-BFLegacyWorks] idle probs
switch???
milehial2000
idle probs
Post by milehial2000 »
I have a spare IAC valve and like I said that is next mainly because
there are very few parts left that can cause this problem. I replaced
the temp sensor first and thought that was it but the problem
reappeared.
AL(CO)
> switch???
milehial2000
idle probs
Hey Josh, I have my idle problem fixed. You mentioned you had set the
idle air control valve to factory settings. Do you have an intake kit
on the car? If so factory settings on this valve do not count as far
as I can tell. These valves are hard to set the problem on my car was
that I had a dirty injector that cut the idle down. I wrongly
corrected this temporarily by turning the idle air control valve
slightly. Then when the injector was cleaned the idle problem
started. When you cleaned the throttle body you may have had the same
effect as opening the idle setting of the idle screw on the TB. What I
ended up with is that the idle screw has almost one turn after
contacting the lever. I then turned the IAC down until I hit 800rpm
and it works.
You may have to play with the settings a bit as it is a bit critical I
had to before I hit the setting.
AL(CO)
was supposed to be.
valves.
readings are.
> Thanks
> Josh
> From: b4b42000 [mailto:abcdefg.abcdefg@o...]
> To: BC-BFLegacyWorks@y...
> Cc:
unit(under
problems
and tps
> switch???
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Josh Colombo
idle probs
Hmmm....
Well I did have an open style intake on the car.....but it is no longer on there. I have the stock intake box back on.
I did not mess with the IAC or any of the idle stop screws before I cleaned everything. So I doubt they are out of adjustment.....or what they were supposed to be.
I have played with the IAC valve and turned it....but that really didn't help.
I've got some other problem, some place else.
A buddy mentioned the fuel pressure regulator. Seeing how it is routed and such. It could be possible some cleaner or dirt got in there and messed up the diaphragm. I've checked vacuum to the regulator. It is correct, around 20 in-Hg. I've gotta pick up a vacuum pump, and will hook it up to the regulator, see if it holds a vacuum. If not.....I would say that is my problem.
The FSM's state the fuel pump puts out about 36 psi of fuel pressure, and vacuum from in the intake is supposed to balance everything out so it has the correct fuel pressure. So at idle....if everything is working correctly.....that would leave about 16 psi of fuel pressure.....correct?
I'll let ya know what I find out. If the regulator is not the problem I am serious stumped. I have either replaced or swapped out another part to test of the following: TPS, IAC, MAF, and coolant temp sensor. If anyone has any other ideas.....I'm all ears.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Sunday, May 19, 2002 12:55 PM
Subject: [BC-BFLegacyWorks] Re: idle probs
and it works.
AL(CO)
was supposed to be.
valves.
readings are.
> Thanks
> Josh
> Cc:
unit(under
problems
and tps
> switch???
milehial2000
idle probs
I was thinking that when you cleaned the TB you might have cleaned
some dirt-film off the interior and that allowed more air to get by
the throttle plate. What is the idle speed? I tried to set mine a
little fast as that is what I prefer and the idle started wandering
around again. I think the IAC was trying to correct for the fast idle
and couldn't quite do it.
One way to prove this is to take a pair of pliers and sqeeze the hose
to the IAC. I did one conversion where I had to take a piece of hose
and make a restriction inside the IAC hose, that was about 7 years ago
and the car still runs ok.
AL(CO)
> Hmmm....
didn't help.
> Josh
> Josh Colombo
> Josh@s... <mailto:Josh@s...>
> From: milehial2000 [mailto:acroxford@h...]
the
kit
was
same
I
> and it works.
I
> AL(CO)
FSM's.
it
> was supposed to be.
plate
> valves.
to
the
> readings are.
> > Thanks
> > Josh
> > Cc:
> unit(under
> problems
> and tps
> > switch???
Josh Colombo
idle probs
Well....that's what I contemplated too. Somehow that, that dirt helped seal things.....however i don't think that was the case. My idle speed is about 1250 rpm. Whenever I start the car....no matter "cold" or "hot" the rpms shoot up real high...like 2500 rpm.....stay there for a little bit and very slowly settle down. It's like the car thinks it's cold or something......something is messed up. IAC valve isn't goin to bring the idle back down to where it should be.
Before I swapped out to the current IAC valve I took the hose off of the intake, and plugged it completely. It still idled high.
I'm going to check the fuel pressure tonight. After that......I'm truly out of ideas.
Unless my ECU got screwed....but have no idea how that would happen......
josh
Sent: Sun 5/19/2002 11:23 PM
Cc:
AL(CO)
> Hmmm....
didn't help.
> Josh
> Josh Colombo
the
kit
was
same
I
> and it works.
I
> AL(CO)
FSM's.
it
> was supposed to be.
plate
> valves.
to
the
> readings are.
> > Thanks
> > Josh
> > Cc:
> unit(under
> problems
> and tps
> > switch???
milehial2000
idle probs
OK if the engine still idled at all with the hose to the IAC plugged
you have got a very bad vacuum leak somewheres my engine will stop
running when I pinch the IAC hose off. There should be no air going
to the engine under such conditions, all the air is provided by thr
IAC and the throttle body and the throttle body is closed off at idle.
AL(CO)
truly out of ideas.
happen......
> josh
> Cc:
cleaned
get by
mine a
wandering
fast idle
the hose
of hose
years ago
> AL(CO)
wrote:
> > Hmmm....
is no
before I
really
> didn't help.
it is
got in
up a
holds a
idle....if
psi of
the
swapped out
coolant temp
> > Josh
> > Josh Colombo
had set
> the
intake
> kit
count as far
my car
> was
wrongly
valve
problem
the
> same
TB. What
> I
after
800rpm
> > and it works.
critical
> I
> > AL(CO)
have, same
a used
two
the
> FSM's.
to where
> it
> > was supposed to be.
regulator. I
testing
throttle
> plate
doesn't act
of a
bad IAC
> > valves.
take it
> to
some of
> the
> > readings are.
> > > Thanks
> > > Josh
> > > Cc:
control
> > unit(under
idle
> > problems
a select
in the
meter
> > and tps
> > > switch???
$1,000.
to:
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA ... /XoTolB/TM
Josh Colombo
idle probs
I can't find a vacuum leak anywhere. I've tried the old spraying starter fluid around the engine....to see if rpm rises......rpm does not rise.....car does nothing. Plus the car idles too smooth to be a vacuum leak. It may idle around 1250.....but it idles pretty damn smooth.
I bought a fuel pressure test gauge. I'm goin to check fuel pressure, see what it is. If it is normal......the only thing I can think of is a fubared throttle body.....or ECU......I've run out of ideas.....and short to replacing every piece......which I'm not going to do.....I'm out of ideas.
I'll double check tonight with the new IAC valve to see if pinching the air stalls the car.
Josh Colombo
Sent: Monday, May 20, 2002 5:53 PM
AL(CO)
truly out of ideas.
happen......
> josh
> Cc:
cleaned
get by
mine a
wandering
fast idle
the hose
of hose
years ago
> AL(CO)
wrote:
> > Hmmm....
is no
before I
really
> didn't help.
it is
got in
up a
holds a
idle....if
psi of
the
swapped out
coolant temp
> > Josh
> > Josh Colombo
had set
> the
intake
> kit
count as far
my car
> was
wrongly
valve
problem
the
> same
TB. What
> I
after
800rpm
> > and it works.
critical
> I
> > AL(CO)
have, same
a used
two
the
> FSM's.
to where
> it
> > was supposed to be.
regulator. I
testing
throttle
> plate
doesn't act
of a
bad IAC
> > valves.
take it
> to
some of
> the
> > readings are.
> > > Thanks
> > > Josh
> > > Cc:
control
> > unit(under
idle
> > problems
a select
in the
meter
> > and tps
> > > switch???
$1,000.
to:
Josh Colombo
idle probs
ok....well I've checked the fuel pressure. It's right on par with what it should be. 27-28 psi at idle (1100 rpm is idle for me at the moment) When I take the vacuum line off the FPR fuel pressure goes up to 38 psi.
So according to what I saw and those numbers, both the pump and the FPR are working properly.
I pinched the IAC hose......nothing....it did nothing to idle. I pulled the plug off the IAC valve, idle went up and was rough. Pinched the hose and idle went down a little bit. So that tells me IAC valve and hose are pretty much functioning correctly.
So....where does that leave us.....I've pretty exhausted all I can think of....everything is in spec.
I'm really wondering if the throttle body or the throttle body gasket is fubared. I suppose some of that cleaner could have gone through the gasket.....however I would think I would hear some air going by, or during my tests for vacuum leak, the idle should've rose.
So that leaves the throttle body/plate.......could it have gotten out of whack? Is there any way to tell?
I know Subaru says not to mess with the stop screws....they are set on a bench and should not be touched.
Ideas......suggestions.....is my car possessed....should I call an exorcist?
Josh Colombo
AL(CO)
truly out of ideas.
happen......
> josh
> Cc:
cleaned
get by
mine a
wandering
fast idle
the hose
of hose
years ago
> AL(CO)
wrote:
> > Hmmm....
is no
before I
really
> didn't help.
it is
got in
up a
holds a
idle....if
psi of
the
swapped out
coolant temp
> > Josh
> > Josh Colombo
had set
> the
intake
> kit
count as far
my car
> was
wrongly
valve
problem
the
> same
TB. What
> I
after
800rpm
> > and it works.
critical
> I
> > AL(CO)
have, same
a used
two
the
> FSM's.
to where
> it
> > was supposed to be.
regulator. I
testing
throttle
> plate
doesn't act
of a
bad IAC
> > valves.
take it
> to
some of
> the
> > readings are.
> > > Thanks
> > > Josh
> > > Cc:
control
> > unit(under
idle
> > problems
a select
in the
meter
> > and tps
> > > switch???
$1,000.
to:
milehial2000
idle probs
I would pull the intake off from it and check the throttle plate it
must be partially open for the thing to run it has to have air. The
power brake line on at both ends? what happens if you pinch it? did
the cleaner run down and make the pwr. brake valve stick? Right at the
end of the throttle and cruise cables where they leave the sheath
there are supposed to be small rubber guides one of them didn't get
loose and get in the throttle mechanism did it? It just has to be
getting air somehow. you are getting me interested now if it doesn't
use air it can't use fuel maybe it is an alternate fuel car. You can
turn the top throttle screw just mark it so that when we find the
problem you can put it back if you have to.
to 38 psi.
exorcist?
> Thanks
> Josh
> Josh Colombo
idle.
> AL(CO)
car
valve
of
> truly out of ideas.
> happen......
> > josh
> > Cc:
> cleaned
> get by
> mine a
> wandering
> fast idle
> the hose
> of hose
> years ago
> > AL(CO)
> wrote:
> > > Hmmm....
> is no
> before I
> really
> > didn't help.
> it is
> got in
> up a
> holds a
> idle....if
> psi of
> the
> swapped out
> coolant temp
> > > Josh
> > > Josh Colombo
> had set
> > the
> intake
> > kit
> count as far
> my car
> > was
> wrongly
> valve
> problem
> the
> > same
> TB. What
> > I
> after
> 800rpm
> > > and it works.
> critical
> > I
> > > AL(CO)
> have, same
> a used
> two
> the
> > FSM's.
> to where
> > it
> > > was supposed to be.
> regulator. I
> testing
> throttle
> > plate
> doesn't act
> of a
> bad IAC
> > > valves.
> take it
> > to
> some of
> > the
> > > readings are.
> > > > Thanks
> > > > Josh
> > > > Cc:
> control
> > > unit(under
> idle
> > > problems
> a select
> in the
> meter
> > > and tps
> > > > switch???
> $1,000.
> to:
Josh Colombo
idle probs
I've had the brake booster hose off......and plugged it.....no real
change. I'll double check tomorrow.
I've pulled the intake off and looked.....it is closed as far as I can
see...I've even tapped it slightly to make sure it's closed. I'll
double check though tomorrow.
I can try slippin something between the throttle body and intake and
close it off to see if that cuts the idle down, and then the IAC valve
will take over with the idle.....in theory of course.
All the cables are loose around the throttle area, again I will double
check tomorrow.
I'd rather not mess with those throttle screws if at all possible....but
lemme see what I find tomorrow.
josh
Josh Colombo
Sent: Monday, May 20, 2002 9:50 PM
to 38 psi.
exorcist?
> Thanks
> Josh
> Josh Colombo
idle.
> AL(CO)
car
valve
of
> truly out of ideas.
> happen......
> > josh
> > Cc:
> cleaned
> get by
> mine a
> wandering
> fast idle
> the hose
> of hose
> years ago
> > AL(CO)
> wrote:
> > > Hmmm....
> is no
> before I
> really
> > didn't help.
> it is
> got in
> up a
> holds a
> idle....if
> psi of
> the
> swapped out
> coolant temp
> > > Josh
> > > Josh Colombo
> had set
> > the
> intake
> > kit
> count as far
> my car
> > was
> wrongly
> valve
> problem
> the
> > same
> TB. What
> > I
> after
> 800rpm
> > > and it works.
> critical
> > I
> > > AL(CO)
> have, same
> a used
> two
> the
> > FSM's.
> to where
> > it
> > > was supposed to be.
> regulator. I
> testing
> throttle
> > plate
> doesn't act
> of a
> bad IAC
> > > valves.
> take it
> > to
> some of
> > the
> > > readings are.
> > > > Thanks
> > > > Josh
> > > > Cc:
> control
> > > unit(under
> idle
> > > problems
> a select
> in the
> meter
> > > and tps
> > > > switch???
> $1,000.
> to:
Josh Colombo
idle probs
the one thing I didn't mention is when I swapped IAC valves, it was off another 90 legacy.....I cleaned it up. The idle got a little bit higher went from around 1100 rpm normally to 1250 or somewhere in there....and it's pretty rock solid idle around there....no real jitteryness and such.
Not sure if the IAC valves are set for a specific throttlebody....I sorta doubt it...but ya never know....in my case....it wouldn't fix anything....because I have pinched the IAC valve hose completely off....
Josh Colombo
Sent: Monday, May 20, 2002 108 PM
Subject: RE: [BC-BFLegacyWorks] Re: idle probs
check tomorrow.
josh
Josh Colombo
to 38 psi.
exorcist?
> Thanks
> Josh
> Josh Colombo
idle.
> AL(CO)
car
valve
of
> truly out of ideas.
> happen......
> > josh
> > Cc:
> cleaned
> get by
> mine a
> wandering
> fast idle
> the hose
> of hose
> years ago
> > AL(CO)
> wrote:
> > > Hmmm....
> is no
> before I
> really
> > didn't help.
> it is
> got in
> up a
> holds a
> idle....if
> psi of
> the
> swapped out
> coolant temp
> > > Josh
> > > Josh Colombo
> had set
> > the
> intake
> > kit
> count as far
> my car
> > was
> wrongly
> valve
> problem
> the
> > same
> TB. What
> > I
> after
> 800rpm
> > > and it works.
> critical
> > I
> > > AL(CO)
> have, same
> a used
> two
> the
> > FSM's.
> to where
> > it
> > > was supposed to be.
> regulator. I
> testing
> throttle
> > plate
> doesn't act
> of a
> bad IAC
> > > valves.
> take it
> > to
> some of
> > the
> > > readings are.
> > > > Thanks
> > > > Josh
> > > > Cc:
> control
> > > unit(under
> idle
> > > problems
> a select
> in the
> meter
> > > and tps
> > > > switch???
> $1,000.
> to:
milehial2000
idle probs
I would almost bet that you will find that the TB is letting to much
air in to the engine. I noticed that when I had the plate open to far
and the idle was above 1000 the IAC really didn't make very much
difference. The opening made inside the TB isn't very linear and if it
is off it will mess up the idle because the IAC just can't correct for
such a large opening. If you block off the TB opening and it makes
a large difference that will just about prove that the plate is open
to much. I would block off the TB opening twice with the IAC
adjustment at both ends as if it is wide open it could make the test
invalid.
AL(CO)
off....
> Josh
> Josh Colombo
> From: Josh Colombo
can
valve
double
> check tomorrow.
possible....but
> josh
> Josh Colombo
the
the
up
> to 38 psi.
the
rose.
set
> exorcist?
> > Thanks
> > Josh
> > Josh Colombo
plugged
going
thr
> idle.
> > AL(CO)
My
matter
rpm.....stay
> car
> valve
off
> of
that......I'm
> > truly out of ideas.
> > happen......
> > > josh
> > > Cc:
> > cleaned
> > get by
> > mine a
> > wandering
> > fast idle
> > the hose
> > of hose
> > years ago
> > > AL(CO)
> > wrote:
> > > > Hmmm....
> > is no
> > before I
> > really
> > > didn't help.
> > it is
> > got in
> > up a
> > holds a
> > idle....if
> > psi of
> > the
> > swapped out
> > coolant temp
> > > > Josh
> > > > Josh Colombo
> > had set
> > > the
> > intake
> > > kit
> > count as far
> > my car
> > > was
> > wrongly
> > valve
> > problem
> > the
> > > same
> > TB. What
> > > I
> > after
> > 800rpm
> > > > and it works.
> > critical
> > > I
> > > > AL(CO)
> > have, same
> > a used
> > two
> > the
> > > FSM's.
> > to where
> > > it
> > > > was supposed to be.
> > regulator. I
> > testing
> > throttle
> > > plate
> > doesn't act
> > of a
> > bad IAC
> > > > valves.
> > take it
> > > to
> > some of
> > > the
> > > > readings are.
> > > > > Thanks
> > > > > Josh
> > > > > Cc:
> > control
> > > > unit(under
> > idle
> > > > problems
> > a select
> > in the
> > meter
> > > > and tps
> > > > > switch???
> > $1,000.
> > to:
milehial2000
idle probs
The factory says it is ok to turn the top screw but never turn the
bottom one. There has to be an adjustment like this to compensate for
throttle plate shaft and supporting bearing wear and when you cleaned
the thing you may have disturbed the bearing surface when you cleaned
it.
AL(CO)
off....
> Josh
> Josh Colombo
> From: Josh Colombo
can
valve
double
> check tomorrow.
possible....but
> josh
> Josh Colombo
the
the
up
> to 38 psi.
the
rose.
set
> exorcist?
> > Thanks
> > Josh
> > Josh Colombo
plugged
going
thr
> idle.
> > AL(CO)
My
matter
rpm.....stay
> car
> valve
off
> of
that......I'm
> > truly out of ideas.
> > happen......
> > > josh
> > > Cc:
> > cleaned
> > get by
> > mine a
> > wandering
> > fast idle
> > the hose
> > of hose
> > years ago
> > > AL(CO)
> > wrote:
> > > > Hmmm....
> > is no
> > before I
> > really
> > > didn't help.
> > it is
> > got in
> > up a
> > holds a
> > idle....if
> > psi of
> > the
> > swapped out
> > coolant temp
> > > > Josh
> > > > Josh Colombo
> > had set
> > > the
> > intake
> > > kit
> > count as far
> > my car
> > > was
> > wrongly
> > valve
> > problem
> > the
> > > same
> > TB. What
> > > I
> > after
> > 800rpm
> > > > and it works.
> > critical
> > > I
> > > > AL(CO)
> > have, same
> > a used
> > two
> > the
> > > FSM's.
> > to where
> > > it
> > > > was supposed to be.
> > regulator. I
> > testing
> > throttle
> > > plate
> > doesn't act
> > of a
> > bad IAC
> > > > valves.
> > take it
> > > to
> > some of
> > > the
> > > > readings are.
> > > > > Thanks
> > > > > Josh
> > > > > Cc:
> > control
> > > > unit(under
> > idle
> > > > problems
> > a select
> > in the
> > meter
> > > > and tps
> > > > > switch???
> > $1,000.
> > to:
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
idle probs
I'll plug up the TB.....and see what happens.
I didn't quite follow you when you said to block off the TB opening twice...?
If you could explain more, that would be great.
One would assume a certain amount of air should go through the TB....but how much is how much?
I will take a look at the stop screws and such and see what's goin on
The IAC valve is set to a mid-way point....so I'm not sure if that should be adjusted any......
Sent: Mon 5/20/2002 11:11 PM
Cc:
invalid.
AL(CO)
off....
> Josh
> Josh Colombo
> From: Josh Colombo
can
valve
double
> check tomorrow.
possible....but
> josh
> Josh Colombo
the
the
up
> to 38 psi.
the
rose.
set
> exorcist?
> > Thanks
> > Josh
> > Josh Colombo
plugged
going
thr
> idle.
> > AL(CO)
My
matter
rpm.....stay
> car
> valve
off
> of
that......I'm
> > truly out of ideas.
> > happen......
> > > josh
> > > Cc:
> > cleaned
> > get by
> > mine a
> > wandering
> > fast idle
> > the hose
> > of hose
> > years ago
> > > AL(CO)
> > wrote:
> > > > Hmmm....
> > is no
> > before I
> > really
> > > didn't help.
> > it is
> > got in
> > up a
> > holds a
> > idle....if
> > psi of
> > the
> > swapped out
> > coolant temp
> > > > Josh
> > > > Josh Colombo
> > had set
> > > the
> > intake
> > > kit
> > count as far
> > my car
> > > was
> > wrongly
> > valve
> > problem
> > the
> > > same
> > TB. What
> > > I
> > after
> > 800rpm
> > > > and it works.
> > critical
> > > I
> > > > AL(CO)
> > have, same
> > a used
> > two
> > the
> > > FSM's.
> > to where
> > > it
> > > > was supposed to be.
> > regulator. I
> > testing
> > throttle
> > > plate
> > doesn't act
> > of a
> > bad IAC
> > > > valves.
> > take it
> > > to
> > some of
> > > the
> > > > readings are.
> > > > > Thanks
> > > > > Josh
> > > > > Cc:
> > control
> > > > unit(under
> > idle
> > > > problems
> > a select
> > in the
> > meter
> > > > and tps
> > > > > switch???
> > $1,000.
> > to:
milehial2000
idle probs
What I meant was that you might try plugging up the throttle body with
the IAC all the way one direction and then plug it up again with the
IAC all the way in the other direction. If it would idle in only one
position that might give you an idea where the extra air is coming
from. I looked at 3 or 4 throttle bodys today and they seem to be set
up so that the stops contact both screws at almost the same time and
it is that way on my car also and when you look at the plate you would
think it was closed. There is a small passage in the top of the TB and
it looks like it is a bypass of sorts and the throttle plate crosses
very close to the center of the hole for the passage. It's going to be
interesting to find out what you discover.
AL(CO)
twice...?
on
> Josh
> Cc:
to much
to far
much
and if it
correct for
makes
is open
the test
> invalid.
> AL(CO)
it was
little bit
in
real
throttlebody....I
wouldn't fix
completely
> off....
> > Josh
> > Josh Colombo
> > From: Josh Colombo
it.....no real
far as I
> can
I'll
intake and
IAC
> valve
will
> double
> > check tomorrow.
> possible....but
> > josh
> > Josh Colombo
plate it
air. The
it? did
Right at
> the
sheath
didn't get
to be
doesn't
You can
find the
par with
me at
> the
pressure goes
> up
> > to 38 psi.
pump and
> the
idle. I
rough.
tells me
all I can
body
have gone
some air
should've
> rose.
gotten
screws....they are
> set
call an
> > exorcist?
> > > Thanks
> > > Josh
> > > Josh Colombo
IAC
> plugged
will stop
air
> going
provided by
> thr
off at
> > idle.
> > > AL(CO)
that dirt
case.
> My
car....no
> matter
> rpm.....stay
like the
> > car
IAC
> > valve
be.
hose
> off
> > of
high.
> that......I'm
> > > truly out of ideas.
would
> > > happen......
> > > > josh
> > > > Cc:
have
> > > cleaned
air to
> > > get by
set
> > > mine a
started
> > > wandering
for the
> > > fast idle
sqeeze
> > > the hose
piece
> > > of hose
about 7
> > > years ago
> > > > AL(CO)
<josh@s...>
> > > wrote:
> > > > > Hmmm....
car.....but it
> > > is no
screws
> > > before I
it....but that
> > > really
> > > > didn't help.
Seeing how
> > > it is
dirt
> > > got in
vacuum to the
gotta pick
> > > up a
if it
> > > holds a
of fuel
balance
So at
> > > idle....if
about 16
> > > psi of
is not
> > > the
or
> > > swapped out
and
> > > coolant temp
ears.
> > > > > Josh
> > > > > Josh Colombo
mentioned you
> > > had set
> > > > the
have an
> > > intake
> > > > kit
not
> > > count as far
problem on
> > > my car
> > > > was
I
> > > wrongly
control
> > > valve
idle
> > > problem
have had
> > > the
> > > > same
on the
> > > TB. What
> > > > I
turn
> > > after
until I hit
> > > 800rpm
> > > > > and it works.
is a bit
> > > critical
> > > > I
> > > > > AL(CO)
<josh@s...>
one i
> > > have, same
were off
> > > a used
same with
> > > two
according to
> > > the
> > > > FSM's.
put back
> > > to where
> > > > it
> > > > > was supposed to be.
> > > regulator. I
do some
> > > testing
the
> > > throttle
> > > > plate
it
> > > doesn't act
up all
> > > of a
have two
> > > bad IAC
> > > > > valves.
down and
> > > take it
> > > > to
what
> > > some of
> > > > the
> > > > > readings are.
> > > > > > Thanks
> > > > > > Josh
> > > > > > Cc:
speed
> > > control
> > > > > unit(under
libertys with
> > > idle
> > > > > problems
10......on
> > > a select
normally falls
> > > in the
the a/f
> > > meter
> > > > > and tps
> > > > > > switch???
win
> > > $1,000.
email
> > > to:
to:
$1,000.
to:
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
idle probs
well....I'm back from my escapades......
Unfortunately.....I don't have any real definitive answers.
I slowly closed off the air passage to the throttle body while it was running.....which I might add is quite difficult to keep everything situated. Did this a couple times. I did get the engine to stall once or twice when I put the cardboard piece in front of the entire throttle body. It was hard trying to seal off both sides.....the intake and the TB side.....
When I finally stopped was when I had pretty much the entire thing plugged....maybe a 1/8-1/4" was left....and all of a sudden I hear a big "POP" The strong vacuum from the intake had blown a hole through the cardboard piece. I've attached two pics of the plug thing I was usin and the nice hole.
So like I said.....I really wouldn't say any of this info is conclusive in any way....unless you can see something I can't. It is very difficult to slowly seal off the air inlet, and not let air back feed through the intake, or around the throttle body.
I saw both those screws, and they look like they work in unison.....I really wouldn't want to mess with them. I can't even reach the top screw to adjust.
I think the next step should be to try another throttle body. The cleaner could've eaten through the seals around the throttle plate shaft or messed something up. I really don't know.
Larry....you sure you don't mind lending me that TB......how much did it cost you? How much do these things run new/used? and is the turbo legacy TB larger then the N/A engine.....you think I'd benefit from a swap.....i.e. more airflow...more power.
Al, you said you had some you looked at today.....are those for sale.....if so....how much?
Thanks everybody for helpin me out.
Larry & Al feel free to email me privately if you want.
Josh Colombo
Sent: Tuesday, May 21, 2002 80 PM
AL(CO)
twice...?
on
> Josh
> Cc:
to much
to far
much
and if it
correct for
makes
is open
the test
> invalid.
> AL(CO)
it was
little bit
in
real
throttlebody....I
wouldn't fix
completely
> off....
> > Josh
> > Josh Colombo
> > From: Josh Colombo
it.....no real
far as I
> can
I'll
intake and
IAC
> valve
will
> double
> > check tomorrow.
> possible....but
> > josh
> > Josh Colombo
plate it
air. The
it? did
Right at
> the
sheath
didn't get
to be
doesn't
You can
find the
par with
me at
> the
pressure goes
> up
> > to 38 psi.
pump and
> the
idle. I
rough.
tells me
all I can
body
have gone
some air
should've
> rose.
gotten
screws....they are
> set
call an
> > exorcist?
> > > Thanks
> > > Josh
> > > Josh Colombo
IAC
> plugged
will stop
air
> going
provided by
> thr
off at
> > idle.
> > > AL(CO)
that dirt
case.
> My
car....no
> matter
> rpm.....stay
like the
> > car
IAC
> > valve
be.
hose
> off
> > of
high.
> that......I'm
> > > truly out of ideas.
would
> > > happen......
> > > > josh
> > > > Cc:
have
> > > cleaned
air to
> > > get by
set
> > > mine a
started
> > > wandering
for the
> > > fast idle
sqeeze
> > > the hose
piece
> > > of hose
about 7
> > > years ago
> > > > AL(CO)
<josh@s...>
> > > wrote:
> > > > > Hmmm....
car.....but it
> > > is no
screws
> > > before I
it....but that
> > > really
> > > > didn't help.
Seeing how
> > > it is
dirt
> > > got in
vacuum to the
gotta pick
> > > up a
if it
> > > holds a
of fuel
balance
So at
> > > idle....if
about 16
> > > psi of
is not
> > > the
or
> > > swapped out
and
> > > coolant temp
ears.
> > > > > Josh
> > > > > Josh Colombo
mentioned you
> > > had set
> > > > the
have an
> > > intake
> > > > kit
not
> > > count as far
problem on
> > > my car
> > > > was
I
> > > wrongly
control
> > > valve
idle
> > > problem
have had
> > > the
> > > > same
on the
> > > TB. What
> > > > I
turn
> > > after
until I hit
> > > 800rpm
> > > > > and it works.
is a bit
> > > critical
> > > > I
> > > > > AL(CO)
<josh@s...>
one i
> > > have, same
were off
> > > a used
same with
> > > two
according to
> > > the
> > > > FSM's.
put back
> > > to where
> > > > it
> > > > > was supposed to be.
> > > regulator. I
do some
> > > testing
the
> > > throttle
> > > > plate
it
> > > doesn't act
up all
> > > of a
have two
> > > bad IAC
> > > > > valves.
down and
> > > take it
> > > > to
what
> > > some of
> > > > the
> > > > > readings are.
> > > > > > Thanks
> > > > > > Josh
> > > > > > Cc:
speed
> > > control
> > > > > unit(under
libertys with
> > > idle
> > > > > problems
10......on
> > > a select
normally falls
> > > in the
the a/f
> > > meter
> > > > > and tps
> > > > > > switch???
win
> > > $1,000.
email
> > > to:
to:
$1,000.
to:
milehial2000
idle probs
I will check in the morning on any that we may have. Most of the ones
that I was looking at today were on customer cars, shop cars, and my
car but I think that there are a few around. This does pretty well
eliminate any vacuum leaks and narrows it down to the TB and that the
"extra air " is coming in the intake of the TB. One thing I did notice
is that there is a black grease smeared around the inside of the TB
about where the plate is??? I think that it is just moly lube for the
plate. Mine went bonkers again today I found that there is no 12 Volts
to the plug for the IAC the wire probably broke during my work on it.
AL(CO)
> Thanks
> Josh
> Josh Colombo
with
set
would
and
be
> AL(CO)
opening
> twice...?
> on
> > Josh
> > Cc:
> to much
> to far
> much
> and if it
> correct for
> makes
> is open
> the test
> > invalid.
> > AL(CO)
> it was
> little bit
> in
> real
> throttlebody....I
> wouldn't fix
> completely
> > off....
> > > Josh
> > > Josh Colombo
> > > From: Josh Colombo
> it.....no real
> far as I
> > can
> I'll
> intake and
> IAC
> > valve
> will
> > double
> > > check tomorrow.
> > possible....but
> > > josh
> > > Josh Colombo
> plate it
> air. The
> it? did
> Right at
> > the
> sheath
> didn't get
> to be
> doesn't
> You can
> find the
> par with
> me at
> > the
> pressure goes
> > up
> > > to 38 psi.
> pump and
> > the
> idle. I
> rough.
> tells me
> all I can
> body
> have gone
> some air
> should've
> > rose.
> gotten
> screws....they are
> > set
> call an
> > > exorcist?
> > > > Thanks
> > > > Josh
> > > > Josh Colombo
> IAC
> > plugged
> will stop
> air
> > going
> provided by
> > thr
> off at
> > > idle.
> > > > AL(CO)
> that dirt
> case.
> > My
> car....no
> > matter
> > rpm.....stay
> like the
> > > car
> IAC
> > > valve
> be.
> hose
> > off
> > > of
> high.
> > that......I'm
> > > > truly out of ideas.
> would
> > > > happen......
> > > > > josh
> > > > > Cc:
> have
> > > > cleaned
> air to
> > > > get by
> set
> > > > mine a
> started
> > > > wandering
> for the
> > > > fast idle
> sqeeze
> > > > the hose
> piece
> > > > of hose
> about 7
> > > > years ago
> > > > > AL(CO)
> <josh@s...>
> > > > wrote:
> > > > > > Hmmm....
> car.....but it
> > > > is no
> screws
> > > > before I
> it....but that
> > > > really
> > > > > didn't help.
> Seeing how
> > > > it is
> dirt
> > > > got in
> vacuum to the
> gotta pick
> > > > up a
> if it
> > > > holds a
> of fuel
> balance
> So at
> > > > idle....if
> about 16
> > > > psi of
> is not
> > > > the
> or
> > > > swapped out
> and
> > > > coolant temp
> ears.
> > > > > > Josh
> > > > > > Josh Colombo
> mentioned you
> > > > had set
> > > > > the
> have an
> > > > intake
> > > > > kit
> not
> > > > count as far
> problem on
> > > > my car
> > > > > was
> I
> > > > wrongly
> control
> > > > valve
> idle
> > > > problem
> have had
> > > > the
> > > > > same
> on the
> > > > TB. What
> > > > > I
> turn
> > > > after
> until I hit
> > > > 800rpm
> > > > > > and it works.
> is a bit
> > > > critical
> > > > > I
> > > > > > AL(CO)
> <josh@s...>
> one i
> > > > have, same
> were off
> > > > a used
> same with
> > > > two
> according to
> > > > the
> > > > > FSM's.
> put back
> > > > to where
> > > > > it
> > > > > > was supposed to be.
> > > > regulator. I
> do some
> > > > testing
> the
> > > > throttle
> > > > > plate
> it
> > > > doesn't act
> up all
> > > > of a
> have two
> > > > bad IAC
> > > > > > valves.
> down and
> > > > take it
> > > > > to
> what
> > > > some of
> > > > > the
> > > > > > readings are.
> > > > > > > Thanks
> > > > > > > Josh
> > > > > > > Cc:
> speed
> > > > control
> > > > > > unit(under
> libertys with
> > > > idle
> > > > > > problems
> 10......on
> > > > a select
> normally falls
> > > > in the
> the a/f
> > > > meter
> > > > > > and tps
> > > > > > > switch???
> win
> > > > $1,000.
> email
> > > > to:
> to:
> $1,000.
> to:
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
idle probs
ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
On some GM cars there is a clay or sealing compound that is around the throttle plate.....it's put there to help seal everything off and what not.....I wonder if this molly lube stuff is similar.....
I was told my the subaru mechanics that the subaru TB's don't have anything like this......can you confirm the greese was on all the TB's you looked at.....any clue on the type of grease and where it was smeared and the likes......
Thanks Al.....good luck with your IAC valve issues.....
Josh Colombo
Sent: Tuesday, May 21, 2002 10:38 PM
AL(CO)
> Thanks
> Josh
> Josh Colombo
with
set
would
and
be
> AL(CO)
opening
> twice...?
> on
> > Josh
> > Cc:
> to much
> to far
> much
> and if it
> correct for
> makes
> is open
> the test
> > invalid.
> > AL(CO)
> it was
> little bit
> in
> real
> throttlebody....I
> wouldn't fix
> completely
> > off....
> > > Josh
> > > Josh Colombo
> > > From: Josh Colombo
> it.....no real
> far as I
> > can
> I'll
> intake and
> IAC
> > valve
> will
> > double
> > > check tomorrow.
> > possible....but
> > > josh
> > > Josh Colombo
> plate it
> air. The
> it? did
> Right at
> > the
> sheath
> didn't get
> to be
> doesn't
> You can
> find the
> par with
> me at
> > the
> pressure goes
> > up
> > > to 38 psi.
> pump and
> > the
> idle. I
> rough.
> tells me
> all I can
> body
> have gone
> some air
> should've
> > rose.
> gotten
> screws....they are
> > set
> call an
> > > exorcist?
> > > > Thanks
> > > > Josh
> > > > Josh Colombo
> IAC
> > plugged
> will stop
> air
> > going
> provided by
> > thr
> off at
> > > idle.
> > > > AL(CO)
> that dirt
> case.
> > My
> car....no
> > matter
> > rpm.....stay
> like the
> > > car
> IAC
> > > valve
> be.
> hose
> > off
> > > of
> high.
> > that......I'm
> > > > truly out of ideas.
> would
> > > > happen......
> > > > > josh
> > > > > Cc:
> have
> > > > cleaned
> air to
> > > > get by
> set
> > > > mine a
> started
> > > > wandering
> for the
> > > > fast idle
> sqeeze
> > > > the hose
> piece
> > > > of hose
> about 7
> > > > years ago
> > > > > AL(CO)
> <josh@s...>
> > > > wrote:
> > > > > > Hmmm....
> car.....but it
> > > > is no
> screws
> > > > before I
> it....but that
> > > > really
> > > > > didn't help.
> Seeing how
> > > > it is
> dirt
> > > > got in
> vacuum to the
> gotta pick
> > > > up a
> if it
> > > > holds a
> of fuel
> balance
> So at
> > > > idle....if
> about 16
> > > > psi of
> is not
> > > > the
> or
> > > > swapped out
> and
> > > > coolant temp
> ears.
> > > > > > Josh
> > > > > > Josh Colombo
> mentioned you
> > > > had set
> > > > > the
> have an
> > > > intake
> > > > > kit
> not
> > > > count as far
> problem on
> > > > my car
> > > > > was
> I
> > > > wrongly
> control
> > > > valve
> idle
> > > > problem
> have had
> > > > the
> > > > > same
> on the
> > > > TB. What
> > > > > I
> turn
> > > > after
> until I hit
> > > > 800rpm
> > > > > > and it works.
> is a bit
> > > > critical
> > > > > I
> > > > > > AL(CO)
> <josh@s...>
> one i
> > > > have, same
> were off
> > > > a used
> same with
> > > > two
> according to
> > > > the
> > > > > FSM's.
> put back
> > > > to where
> > > > > it
> > > > > > was supposed to be.
> > > > regulator. I
> do some
> > > > testing
> the
> > > > throttle
> > > > > plate
> it
> > > > doesn't act
> up all
> > > > of a
> have two
> > > > bad IAC
> > > > > > valves.
> down and
> > > > take it
> > > > > to
> what
> > > > some of
> > > > > the
> > > > > > readings are.
> > > > > > > Thanks
> > > > > > > Josh
> > > > > > > Cc:
> speed
> > > > control
> > > > > > unit(under
> libertys with
> > > > idle
> > > > > > problems
> 10......on
> > > > a select
> normally falls
> > > > in the
> the a/f
> > > > meter
> > > > > > and tps
> > > > > > > switch???
> win
> > > > $1,000.
> email
> > > > to:
> to:
> $1,000.
> to:
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/DlIU9C/4m7CAA ... /XoTolB/TM
milehial2000
idle probs
I have seen this stuff before so the factory did use it on some of the
tb assys that they made. I think it is a Moly type grease and I can
see that is was applied with some sort of a brush before things were
assembled. But it probably is nothing real important they couldn't
expect the stuff to really be a sealer and have a service life. I
didn't find any good TB's today only the late model type but I will
look more tommorow.
AL(CO)
> Josh
> Josh Colombo
ones
the
notice
the
Volts
it.
> AL(CO)
the
through
is
back
the
> > Thanks
> > Josh
> > Josh Colombo
> with
the
one
> set
and
> would
> and
crosses
to
> be
> > AL(CO)
> opening
> > twice...?
goin
> > on
that
> > > Josh
> > > Cc:
> > to much
> > to far
> > much
> > and if it
> > correct for
> > makes
> > is open
> > the test
> > > invalid.
> > > AL(CO)
> > it was
> > little bit
> > in
> > real
> > throttlebody....I
> > wouldn't fix
> > completely
> > > off....
> > > > Josh
> > > > Josh Colombo
> > > > From: Josh Colombo
> > it.....no real
> > far as I
> > > can
> > I'll
> > intake and
> > IAC
> > > valve
> > will
> > > double
> > > > check tomorrow.
> > > possible....but
> > > > josh
> > > > Josh Colombo
> > plate it
> > air. The
> > it? did
> > Right at
> > > the
> > sheath
> > didn't get
> > to be
> > doesn't
> > You can
> > find the
> > par with
> > me at
> > > the
> > pressure goes
> > > up
> > > > to 38 psi.
> > pump and
> > > the
> > idle. I
> > rough.
> > tells me
> > all I can
> > body
> > have gone
> > some air
> > should've
> > > rose.
> > gotten
> > screws....they are
> > > set
> > call an
> > > > exorcist?
> > > > > Thanks
> > > > > Josh
> > > > > Josh Colombo
> > IAC
> > > plugged
> > will stop
> > air
> > > going
> > provided by
> > > thr
> > off at
> > > > idle.
> > > > > AL(CO)
> > that dirt
> > case.
> > > My
> > car....no
> > > matter
> > > rpm.....stay
> > like the
> > > > car
> > IAC
> > > > valve
> > be.
> > hose
> > > off
> > > > of
> > high.
> > > that......I'm
> > > > > truly out of ideas.
> > would
> > > > > happen......
> > > > > > josh
> > > > > > Cc:
> > have
> > > > > cleaned
> > air to
> > > > > get by
> > set
> > > > > mine a
> > started
> > > > > wandering
> > for the
> > > > > fast idle
> > sqeeze
> > > > > the hose
> > piece
> > > > > of hose
> > about 7
> > > > > years ago
> > > > > > AL(CO)
> > <josh@s...>
> > > > > wrote:
> > > > > > > Hmmm....
> > car.....but it
> > > > > is no
> > screws
> > > > > before I
> > it....but that
> > > > > really
> > > > > > didn't help.
> > Seeing how
> > > > > it is
> > dirt
> > > > > got in
> > vacuum to the
> > gotta pick
> > > > > up a
> > if it
> > > > > holds a
> > of fuel
> > balance
> > So at
> > > > > idle....if
> > about 16
> > > > > psi of
> > is not
> > > > > the
> > or
> > > > > swapped out
> > and
> > > > > coolant temp
> > ears.
> > > > > > > Josh
> > > > > > > Josh Colombo
> > mentioned you
> > > > > had set
> > > > > > the
> > have an
> > > > > intake
> > > > > > kit
> > not
> > > > > count as far
> > problem on
> > > > > my car
> > > > > > was
> > I
> > > > > wrongly
> > control
> > > > > valve
> > idle
> > > > > problem
> > have had
> > > > > the
> > > > > > same
> > on the
> > > > > TB. What
> > > > > > I
> > turn
> > > > > after
> > until I hit
> > > > > 800rpm
> > > > > > > and it works.
> > is a bit
> > > > > critical
> > > > > > I
> > > > > > > AL(CO)
> > <josh@s...>
> > one i
> > > > > have, same
> > were off
> > > > > a used
> > same with
> > > > > two
> > according to
> > > > > the
> > > > > > FSM's.
> > put back
> > > > > to where
> > > > > > it
> > > > > > > was supposed to be.
> > > > > regulator. I
> > do some
> > > > > testing
> > the
> > > > > throttle
> > > > > > plate
> > it
> > > > > doesn't act
> > up all
> > > > > of a
> > have two
> > > > > bad IAC
> > > > > > > valves.
> > down and
> > > > > take it
> > > > > > to
> > what
> > > > > some of
> > > > > > the
> > > > > > > readings are.
> > > > > > > > Thanks
> > > > > > > > Josh
> > > > > > > > Cc:
> > speed
> > > > > control
> > > > > > > unit(under
> > libertys with
> > > > > idle
> > > > > > > problems
> > 10......on
> > > > > a select
> > normally falls
> > > > > in the
> > the a/f
> > > > > meter
> > > > > > > and tps
> > > > > > > > switch???
> > win
> > > > > $1,000.
> > email
> > > > > to:
> > to:
> > $1,000.
> > to:
FREE COLLEGE MONEY
Josh Colombo
idle probs
ok......let me know......I'll try and call tomorrow to see if the TB for
the turbo legacy is the same as the N/A. I'm still goin to probably
need a TB.....so if you can see if you have any extra to sell me
Al....I'd appreciate any help.
Talked to a buddy who owns a shop.....he said the bushings go away over
time, and you can rebuild them.....at least that's what he did on one of
his cars......I'd probably just get a new TB........or new to me TB.
Thanks for checkin the stuff out Al.
Josh Colombo
Sent: Wednesday, May 22, 2002 9:33 PM
look more tommorow.
AL(CO)
> Josh
> Josh Colombo
ones
the
notice
the
Volts
it.
> AL(CO)
the
through
is
back
the
> > Thanks
> > Josh
> > Josh Colombo
> with
the
one
> set
and
> would
> and
crosses
to
> be
> > AL(CO)
> opening
> > twice...?
goin
> > on
that
> > > Josh
> > > Cc:
> > to much
> > to far
> > much
> > and if it
> > correct for
> > makes
> > is open
> > the test
> > > invalid.
> > > AL(CO)
> > it was
> > little bit
> > in
> > real
> > throttlebody....I
> > wouldn't fix
> > completely
> > > off....
> > > > Josh
> > > > Josh Colombo
> > > > From: Josh Colombo
> > it.....no real
> > far as I
> > > can
> > I'll
> > intake and
> > IAC
> > > valve
> > will
> > > double
> > > > check tomorrow.
> > > possible....but
> > > > josh
> > > > Josh Colombo
> > plate it
> > air. The
> > it? did
> > Right at
> > > the
> > sheath
> > didn't get
> > to be
> > doesn't
> > You can
> > find the
> > par with
> > me at
> > > the
> > pressure goes
> > > up
> > > > to 38 psi.
> > pump and
> > > the
> > idle. I
> > rough.
> > tells me
> > all I can
> > body
> > have gone
> > some air
> > should've
> > > rose.
> > gotten
> > screws....they are
> > > set
> > call an
> > > > exorcist?
> > > > > Thanks
> > > > > Josh
> > > > > Josh Colombo
> > IAC
> > > plugged
> > will stop
> > air
> > > going
> > provided by
> > > thr
> > off at
> > > > idle.
> > > > > AL(CO)
> > that dirt
> > case.
> > > My
> > car....no
> > > matter
> > > rpm.....stay
> > like the
> > > > car
> > IAC
> > > > valve
> > be.
> > hose
> > > off
> > > > of
> > high.
> > > that......I'm
> > > > > truly out of ideas.
> > would
> > > > > happen......
> > > > > > josh
> > > > > > Cc:
> > have
> > > > > cleaned
> > air to
> > > > > get by
> > set
> > > > > mine a
> > started
> > > > > wandering
> > for the
> > > > > fast idle
> > sqeeze
> > > > > the hose
> > piece
> > > > > of hose
> > about 7
> > > > > years ago
> > > > > > AL(CO)
> > <josh@s...>
> > > > > wrote:
> > > > > > > Hmmm....
> > car.....but it
> > > > > is no
> > screws
> > > > > before I
> > it....but that
> > > > > really
> > > > > > didn't help.
> > Seeing how
> > > > > it is
> > dirt
> > > > > got in
> > vacuum to the
> > gotta pick
> > > > > up a
> > if it
> > > > > holds a
> > of fuel
> > balance
> > So at
> > > > > idle....if
> > about 16
> > > > > psi of
> > is not
> > > > > the
> > or
> > > > > swapped out
> > and
> > > > > coolant temp
> > ears.
> > > > > > > Josh
> > > > > > > Josh Colombo
> > mentioned you
> > > > > had set
> > > > > > the
> > have an
> > > > > intake
> > > > > > kit
> > not
> > > > > count as far
> > problem on
> > > > > my car
> > > > > > was
> > I
> > > > > wrongly
> > control
> > > > > valve
> > idle
> > > > > problem
> > have had
> > > > > the
> > > > > > same
> > on the
> > > > > TB. What
> > > > > > I
> > turn
> > > > > after
> > until I hit
> > > > > 800rpm
> > > > > > > and it works.
> > is a bit
> > > > > critical
> > > > > > I
> > > > > > > AL(CO)
> > <josh@s...>
> > one i
> > > > > have, same
> > were off
> > > > > a used
> > same with
> > > > > two
> > according to
> > > > > the
> > > > > > FSM's.
> > put back
> > > > > to where
> > > > > > it
> > > > > > > was supposed to be.
> > > > > regulator. I
> > do some
> > > > > testing
> > the
> > > > > throttle
> > > > > > plate
> > it
> > > > > doesn't act
> > up all
> > > > > of a
> > have two
> > > > > bad IAC
> > > > > > > valves.
> > down and
> > > > > take it
> > > > > > to
> > what
> > > > > some of
> > > > > > the
> > > > > > > readings are.
> > > > > > > > Thanks
> > > > > > > > Josh
> > > > > > > > Cc:
> > speed
> > > > > control
> > > > > > > unit(under
> > libertys with
> > > > > idle
> > > > > > > problems
> > 10......on
> > > > > a select
> > normally falls
> > > > > in the
> > the a/f
> > > > > meter
> > > > > > > and tps
> > > > > > > > switch???
> > win
> > > > > $1,000.
> > email
> > > > > to:
> > to:
> > $1,000.
> > to:
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
idle probs
Called and checked on some things. The turbo legacy and N/A legacy have the same TB, that's for 90-94. 95+ have a different TB. So larry your spare one would work as a test TB. I'm 90% sure that it is the TB that is causing my problems. I'll do some snooping on e-bay, but Al if you have any extras that are good and could sell me.....I'd be interested.
Thanks guys.
Sent: Wed 5/22/2002 9:32 PM
Cc:
look more tommorow.
AL(CO)
> Josh
> Josh Colombo
ones
the
notice
the
Volts
it.
> AL(CO)
the
through
is
back
the
> > Thanks
> > Josh
> > Josh Colombo
> with
the
one
> set
and
> would
> and
crosses
to
> be
> > AL(CO)
> opening
> > twice...?
goin
> > on
that
> > > Josh
> > > Cc:
> > to much
> > to far
> > much
> > and if it
> > correct for
> > makes
> > is open
> > the test
> > > invalid.
> > > AL(CO)
> > it was
> > little bit
> > in
> > real
> > throttlebody....I
> > wouldn't fix
> > completely
> > > off....
> > > > Josh
> > > > Josh Colombo
> > > > From: Josh Colombo
> > it.....no real
> > far as I
> > > can
> > I'll
> > intake and
> > IAC
> > > valve
> > will
> > > double
> > > > check tomorrow.
> > > possible....but
> > > > josh
> > > > Josh Colombo
> > plate it
> > air. The
> > it? did
> > Right at
> > > the
> > sheath
> > didn't get
> > to be
> > doesn't
> > You can
> > find the
> > par with
> > me at
> > > the
> > pressure goes
> > > up
> > > > to 38 psi.
> > pump and
> > > the
> > idle. I
> > rough.
> > tells me
> > all I can
> > body
> > have gone
> > some air
> > should've
> > > rose.
> > gotten
> > screws....they are
> > > set
> > call an
> > > > exorcist?
> > > > > Thanks
> > > > > Josh
> > > > > Josh Colombo
> > IAC
> > > plugged
> > will stop
> > air
> > > going
> > provided by
> > > thr
> > off at
> > > > idle.
> > > > > AL(CO)
> > that dirt
> > case.
> > > My
> > car....no
> > > matter
> > > rpm.....stay
> > like the
> > > > car
> > IAC
> > > > valve
> > be.
> > hose
> > > off
> > > > of
> > high.
> > > that......I'm
> > > > > truly out of ideas.
> > would
> > > > > happen......
> > > > > > josh
> > > > > > Cc:
> > have
> > > > > cleaned
> > air to
> > > > > get by
> > set
> > > > > mine a
> > started
> > > > > wandering
> > for the
> > > > > fast idle
> > sqeeze
> > > > > the hose
> > piece
> > > > > of hose
> > about 7
> > > > > years ago
> > > > > > AL(CO)
> > <josh@s...>
> > > > > wrote:
> > > > > > > Hmmm....
> > car.....but it
> > > > > is no
> > screws
> > > > > before I
> > it....but that
> > > > > really
> > > > > > didn't help.
> > Seeing how
> > > > > it is
> > dirt
> > > > > got in
> > vacuum to the
> > gotta pick
> > > > > up a
> > if it
> > > > > holds a
> > of fuel
> > balance
> > So at
> > > > > idle....if
> > about 16
> > > > > psi of
> > is not
> > > > > the
> > or
> > > > > swapped out
> > and
> > > > > coolant temp
> > ears.
> > > > > > > Josh
> > > > > > > Josh Colombo
> > mentioned you
> > > > > had set
> > > > > > the
> > have an
> > > > > intake
> > > > > > kit
> > not
> > > > > count as far
> > problem on
> > > > > my car
> > > > > > was
> > I
> > > > > wrongly
> > control
> > > > > valve
> > idle
> > > > > problem
> > have had
> > > > > the
> > > > > > same
> > on the
> > > > > TB. What
> > > > > > I
> > turn
> > > > > after
> > until I hit
> > > > > 800rpm
> > > > > > > and it works.
> > is a bit
> > > > > critical
> > > > > > I
> > > > > > > AL(CO)
> > <josh@s...>
> > one i
> > > > > have, same
> > were off
> > > > > a used
> > same with
> > > > > two
> > according to
> > > > > the
> > > > > > FSM's.
> > put back
> > > > > to where
> > > > > > it
> > > > > > > was supposed to be.
> > > > > regulator. I
> > do some
> > > > > testing
> > the
> > > > > throttle
> > > > > > plate
> > it
> > > > > doesn't act
> > up all
> > > > > of a
> > have two
> > > > > bad IAC
> > > > > > > valves.
> > down and
> > > > > take it
> > > > > > to
> > what
> > > > > some of
> > > > > > the
> > > > > > > readings are.
> > > > > > > > Thanks
> > > > > > > > Josh
> > > > > > > > Cc:
> > speed
> > > > > control
> > > > > > > unit(under
> > libertys with
> > > > > idle
> > > > > > > problems
> > 10......on
> > > > > a select
> > normally falls
> > > > > in the
> > the a/f
> > > > > meter
> > > > > > > and tps
> > > > > > > > switch???
> > win
> > > > > $1,000.
> > email
> > > > > to:
> > to:
> > $1,000.
> > to:
FREE COLLEGE MONEY
Locked
