I took my car to a mechanic to have the exhaust sniffed prior to mandatory vehicle inspecvtion and they somehow triggered a bunch of error codes. I switched ECUs, but I still have 22 knock sensor, 31 throttle position sensor and 32 O2 sensor. Last night I disconnected the negative battery cable for about 30 minutes, but as soon as I turned the key on, (did not start car), I had the same three codes.
I am looking for ECU clearing procedures, O2 sensor checking procedures and the complex ECU reset start-up procedures. Does anypone have these?
Thanks Bill Robinson
92 USA turbo 5speed sedan
ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.35 ... 000239/R=1>
<http://us.adserver.yahoo.com/l?M=226014 ... =644670781>
Need ECU Code Clearing and Reset Instructions
Josh Colombo
Bill,
Check out my site, www.surrealmirage.com/subaru I have all the ECU info there. It's under notes & tips and engine related. You can clear the ECU using the battery dance method. However you can use the two connectors, and in your case, i would use the connectors, because if you follow the procedure you will be able to tell if you still are getting those problems and such.
-----Original Message-----
From: William D. Robinson [mailto:vultureboy@mindspring.com]
Sent: Mon 5/20/2002 10:39 AM
Cc:
Subject: [BC-BFLegacyWorks] Need ECU Code Clearing and Reset Instructions
ADVERTISEMENT
Cc:
ADVERTISEMENT
Rod
To reset ecu,
> http://www.mrtrally.com.au/performance/howresetecu.htm
cheers, Rod
----- Original Message -----
From: William D. Robinson <mailto:vultureboy@mindspring.com>
Sent: Tuesday, May 21, 2002 1:39 AM
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=226014 ... =239233490>
cheers, Rod
ADVERTISEMENT
