I've got a 1990 legacy wagon GT, with a EJ20 2.0 turbo motor, it runs
really well when cold on a hot/warm day, and runs ok when the motor
is warm on a warm day also.
But when the weather is wet and raining, then the car runs sick as.
It feels like it is runing on only 3 cylinders, it back fires, and
runs really sick, if you manage to get the revs up - it jumps into
power mode and runs alot better, and once the temp gauge comes up the
cars runs not too bad, but still has a small surge occasionally.
No errors are in the log.
I've checked to see if any electrical connections are wet, and can't
find anything wrong or wet.
Could this be the intake air sensor playing up???
Any suggestions would be appreciated, as my wife is pregnant, and I
need a reliable car for her to drive.
Thanks in advance.
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA ... /XoTolB/TM
wet weather and poor motor running
alan butler
If it's quad cam with 4 coils(I'm assuming it is if you are from NZ), pull out the coils and check the rubber boots around the end where it meets the spark plug. These used to tear in Oz RSs and cause wet weather misses. If it isn't perfect, replace it.
Cheers. Al.
92 RS Turbo
ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.35 ... 000239/R=1>
<http://us.adserver.yahoo.com/l?M=226014 ... =159838974>
Cheers. Al.
92 RS Turbo
ADVERTISEMENT
southcitygroupnz
> Cheers. Al.
> 92 RS Turbo
Sorry i forgot to add, i've replaced all four coil packs and spark
plugs in the process of tracing this fault.
it doesn't have to be raining for this fault to occur.
just cold weather if enough eg today it was 5 deg C, and the fault
had no problems showing itself.
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/DlIU9C/4m7CAA ... /XoTolB/TM
> Cheers. Al.
> 92 RS Turbo
FREE COLLEGE MONEY
