WRX Wagon Suspension -> onto a 1994 Legacy Wagon
bignose
Post by bignose »
Will it work ? A friend told me that the AGX's are only marginally better than the stock wrx struts. Not enough different to justify the cost diff.
Will the struts/springs from a Stock WRX wagon fit a 1994 Legacy Turbo Wagon ?
Are these a suitable upgrade for a tired old legacy ?
http://www.bignose.ca/legacy/pics/
The fronts may fit, however the rears may be a little more difficult. I think the wagons had the same design as the previous years.....
Even if everything is a direct bolt on, spring rates & damping rates may not be ideal.
May want to check nasioc and see what the spring & damping rates are for the wagon, and then compare them to the stock numbers, and aftermarket.
Nate S
Post by Nate S »
I have put the stock stuff from a WRX onto a legacy wagon, although mine had a "coilover" kit on them so it wasnt an issue. The struts bolt up though.
hope that helps.
Nate
S-Squared Motorsports
Looking for aftermarket parts? Email me
nate@ss-ms.com - www.ss-ms.com
shop # 916 631 7440
92 turbo wagon / 02 wrx sedan
mgjs1
COuld you define coilover...
Post by mgjs1 »
Could you define "coilover" for me. And explain why that solved problems porting over from a WRX to your Legacy Wagon.
I have a 93 Legacy Wagon that I would love to replace suspension parts on and want to do it right. WRX stuff seems attractive. I have WRX springs, but they are from a sedan, so I don't wanna use them.
Anyway, I really just would like to know what a "coilover" is and does.
http://www.circlestickers.com
mTk
no title
Post by mTk »
A coilover would be something like this:
They are height adjustable, allowing you to make up some differences in spring height between wrx->legacy
MK
1992 BC672 AWD 5MT
