Intercooling a Sport Sedan
c150cglzp
What size and type of intercooler do you guys use on your sedans or
wagons. Is there a preferred manufacturer?
Mark
Will You Find True Love?
Will You Meet the One?
Free Love Reading by phone!
http://us.click.yahoo.com/Deo18C/zDLEAA ... /XoTolB/TM
Mark
adam@mymindseye.ca
I used an IC off a 95 WRX EURO Spec. If i knew what i know now i would
have used a Water/Air IC as mine heats up alot. Either that or get a
bigger hood scoop, but i haven't figured out how to get one installed on
the car without spending 600 dollars on it.
> Mark
> ---------------------~--> Will You Find True Love?
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
> Mark
legacycentral
Any intercooler is better than none in 98% of circumstances.
A bigger hood scoop would be nice, so would a fiberglass hood with RS
vents and scoop...
would
a
installed on
or
> > Mark
vents and scoop...
would
a
installed on
or
> > Mark
John
Dave-
What kind of car did your intercooler come off of? How
is it working for you? was there A LOT of custom work
to make it fit?
> circumstances.
> vents and scoop...
> Dave
> what i know now i
> would
> Either that or get
> a
> to get one
> installed on
> use on your sedans
> or
> > > Mark
__________________________________________________
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
to make it fit?
> circumstances.
> vents and scoop...
> Dave
> what i know now i
> would
> Either that or get
> a
> to get one
> installed on
> use on your sedans
> or
> > > Mark
Do You Yahoo!?
legacycentral
I was lucky to find an intercooler from a 2.5RS intercooler project
on eBay. The guy was running in the 13s with it, but wanted more, so
i ended up with it.
It's relatively small, but 3.5" thick and uses a Spearco core. I was
concerned about the turbo-IC connection, but i found a lower radiator
hose that fit 98% perfect. Getting the IAC and BOV routing done
right took another few days, but it's all sorted out now.
So...not terribly hard.
--- In BC-BFLegacyWorks@y..., John <nissans14@y...> wrote:
> Dave-
> to make it fit?
i ended up with it.
> Dave-
> to make it fit?
Matthew Reese
_____
Send and receive Hotmail on your mobile device: Click Here <http://g.msn.com/1HM501601/40>
Matthew Reese
I'll try again... my posts are getting screwed up!
I have just installed a Saab 900 intercooler. Fit well. My dissapointment is that the max sustained boost at WOT is 9 psi. If I use the manual mode of my auto tranny, the boost will maintain 15-17 psi. This is OK except I don't like launching the car in 2nd - hard on the tranny and it's slow! What kind of boost can you maintain in the 1/4 mile run? Have I maxed out my turbo? BTW - I'm running my turbo to the max - wastegate control line is disconnected giving me full potential.
_____
Get your FREE download of MSN Explorer at http://explorer.msn.com <http://g.msn.com/1HM501601/39> .
_____
Matthew Reese
_____
Join the world’s largest e-mail service with MSN Hotmail. Click Here <http://g.msn.com/1HM501601/42>
_____
legacycentral
I can't seem to boost over 11PSI after the intercooler installation,
but i think it might be because of the restrictive nature of the
intercooler, stock downpipe, and perhaps a mis-tuned AVC-R.
I'm getting a 2.5" catless DP made today, so we'll see if that helps.
Adam Archibald
I'm curious on something.....
Have you upgraded your fuel delivery system (pump, injectors, etc.)? As
far as I have been told the current fuel system can't handle any more than
13psi, hence why the fuel cut-off is there.
-Adam
> potential.
> zZz.
-Adam
> potential.
> zZz.
Josh Colombo
You're goin to blow your engine with that wastegate control line disconnected! It is there for a reason. There's no reason to disconnect that. Hook it back up, buy yourself a good MBC set it to whatever boost pressure you want, and then go from there to see how things go and such.
Number one thing you should have done is get a boost controller, whether it be manual, or electronic. It will bypass the ECU's measely boost level cuts.
-----Original Message-----
Sent: Thu 6/13/2002 7:13 AM
Cc:
Subject: Re: [BC-BFLegacyWorks] Re: Intercooling a Sport Sedan
_____
Cc:
_____
c150cglzp
Hey Adam,
Why is it that a larger hoodscoop costs that much? I've seen nice
fiberglass ones for 150 bucks. Couldn't you chop a hole and glue it
down with some glass and resin? Also How many pounds are you getting
with that IC?
Thanks,
Mark
with that IC?
Thanks,
Mark
Matthew Reese
Thanks for the reply. I am only diconnecting the wastegate vaccum to prove to myself that I have exceeded the capabilities of my turbo. If it won't push more than 10 psi through my intercooler I am not going to keep this intercooler installed. I will not be running the car with the disconnected line - infact the intercooler and all is out and I'm back to my previous setup. I have 2 different manual boost controllers that I have tried and am now using an electronic setup. I have also advanced my timing considerably and this alone has proven to be the most potent mod on my turbo. I can see from my testing I could use a bigger turbo!
Matt
>From: "Josh Colombo"
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>To:
>Subject: RE: [BC-BFLegacyWorks] Re: Intercooling a Sport Sedan
>Date: Thu, 13 Jun 2002 10:30:53 -0500
>Josh
> From: Matthew Reese [mailto:carmat76@hotmail.com]
> Cc:
> _____
> Get your FREE download of MSN Explorer at http://explorer.msn.com .
> zZz .
><< winmail.dat >>
_____
ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.35 ... 000239/R=1>
<http://us.adserver.yahoo.com/l?M=226014 ... =340342541>
Matt
>To:
>Josh
> Cc:
> _____
> zZz .
><< winmail.dat >>
_____
ADVERTISEMENT
Josh Colombo
Just curious......how are you advancing your timing? Do you have an aftermarket ECU or some other ECU tuning software/hardware?
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com
of beats and rhythm" - ME
Sent: Thursday, June 13, 2002 81 PM
Matt
>To:
>Josh
> Cc:
> _____
> zZz .
><< winmail.dat >>
_____
Josh Colombo
Matt
>To:
>Josh
> Cc:
> _____
> zZz .
><< winmail.dat >>
_____
Matthew Reese
Here's the idea. After an ECU reset, the timing is advanced. The knock senosr is then monitored and the appropriate amount of retard is applied. I have removed my knock senosr (15,000 miles now - hard running at that!) and I have replaced it with a 22K ohm grounded resistor. This fools the ECU - it never hears knock and it prevents the CEL. The catch - take it easy unless I'm running a ~96 or 97 octane mix ( I usually do cause I can't take it easy...). I have had amazing success with this setup. My boost sits in around 12psi and I fly! (for an old car with an auto)
>To:
>Date: Thu, 13 Jun 2002 214:22 -0500
>Josh Colombo
>Matt
> >To:
> >Josh
> > Cc:
> > _____
> > zZz .
> ><< winmail.dat >>
> _____
>ADVERTISEMENT
>zZz .
_____
>To:
>Josh Colombo
>Matt
> >To:
> >Josh
> > Cc:
> > _____
> > zZz .
> ><< winmail.dat >>
> _____
>ADVERTISEMENT
>zZz .
_____
Josh Colombo
Interesting......however I don't know if I can get......or should I say want to pay for 96/97 octane mix for every day traffic driving.....
Sent: Thu 6/13/2002 10:18 PM
Cc:
>To:
>Josh Colombo
>Matt
> >To:
> >Josh
> > Cc:
> > _____
> > zZz .
> ><< winmail.dat >>
> _____
>ADVERTISEMENT
>zZz .
_____
Cc:
>To:
>Josh Colombo
>Matt
> >To:
> >Josh
> > Cc:
> > _____
> > zZz .
> ><< winmail.dat >>
> _____
>ADVERTISEMENT
>zZz .
_____
Matthew Reese
The power is an addiction - I could have a worse habit. Nothing like blowing away Mustangs from light to light every Friday night - actually I'm beginning to forget the feeling - they won't race me anymore : )
Here's the math...
15 gal would be my max fill up. 15 gal of 93 octane @ 1.55/gal = $23.25 or for the good stuff at a 2:1 mix (98.5 octane - more than enough) 10 gal of 93octane @ $1.55/gal and 5 gal of 110 octane @ $3.60/gal = $33.00.
This will last me a week and I am not really concerned about $10 bucks a week!
Time to Turbo the Sube Josh : )
>To:
>Date: Fri, 14 Jun 2002 07:13:58 -0500
> Cc:
> >To:
> >Josh Colombo
> >Matt
> > >To:
> > >Josh
> > > Cc:
> > > _____
> > > zZz .
> > ><< winmail.dat >>
> > _____
> >ADVERTISEMENT
> >zZz .
> _____
> zZz .
><< winmail.dat >>
_____
zQz: Click Here <http://g.msn.com/1HM501601/41>
Here's the math...
>To:
> Cc:
> >To:
> >Josh Colombo
> >Matt
> > >To:
> > >Josh
> > > Cc:
> > > _____
> > > zZz .
> > ><< winmail.dat >>
> > _____
> >ADVERTISEMENT
> >zZz .
> _____
> zZz .
><< winmail.dat >>
_____
Josh Colombo
It's in the plan book
Maybe a year or so away.....gotta see how job & living arrangements play out......
Sent: Fri 6/14/2002 7:46 AM
Cc:
Here's the math...
>To:
> Cc:
> >To:
> >Josh Colombo
> >Matt
> > >To:
> > >Josh
> > > Cc:
> > > _____
> > > zZz .
> > ><< winmail.dat >>
> > _____
> >ADVERTISEMENT
> >zZz .
> _____
> zZz .
><< winmail.dat >>
_____
Cc:
Here's the math...
>To:
> Cc:
> >To:
> >Josh Colombo
> >Matt
> > >To:
> > >Josh
> > > Cc:
> > > _____
> > > zZz .
> > ><< winmail.dat >>
> > _____
> >ADVERTISEMENT
> >zZz .
> _____
> zZz .
><< winmail.dat >>
_____
Adam Archibald
yes i am curious too as i have to replace my water pump next week and have
to take the timing belt off.
-Adam
> Josh Colombo
> Matt
>>To:
>>such.
>>boost level cuts.
>>Josh
>> Cc:
>> potential.
>> _____
>> zZz .
>><< winmail.dat >>
> _____
> ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.35 ... S=17050649
83:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1024016481%
3eM=226014.2032696.3508022.1829184/D=egroupweb/S=1705064983:HM/A=1000239/R=1
M=226014.2032696.3508022.1829184/D=egroupmail/S=1705064983:HM/A=1000239/rand
=340342541>
> zZz
-Adam
> Josh Colombo
> Matt
>>To:
>>such.
>>boost level cuts.
>>Josh
>> Cc:
>> potential.
>> _____
>> zZz .
>><< winmail.dat >>
> _____
> ADVERTISEMENT
=340342541>
> zZz
Matthew Reese
Hey Adam, do you live in Ottawa, ON? I'll be there July 4th to 8th. It would be nice to meet a fellow Turbo owner!
For all Turbo owners - What are your best 1/4 mile times. I cannot break 15 seconds and it's killing me. I am not to happy with the shift points of the auto above 60 mph. I have seen the need for the old intercooler after some runs - I'm working on a solid instalation of the Saab intercooler. Post you times and mods!
The reason I'm pumped on the 1/4 - an abondoned track, which has been closed for years has just been opened up. The gate is gone and there are no signs prohibiting use. The owner must be crazy but I'm going to keep running it to something happens or someone bites the dust : )
>From: "Adam Archibald"
>To:
>Date: Fri, 14 Jun 2002 09:39:32 -0400 (EDT)
>-Adam
> > Josh Colombo
> > Matt
> >>To:
> >>such.
> >>boost level cuts.
> >>Josh
> >> Cc:
> >> potential.
> >> _____
> >> zZz .
> >><< winmail.dat >>
> > _____
> > ADVERTISEMENT
>=340342541>
> > zZz
_____
>To:
>-Adam
> > Josh Colombo
> > Matt
> >>To:
> >>such.
> >>boost level cuts.
> >>Josh
> >> Cc:
> >> potential.
> >> _____
> >> zZz .
> >><< winmail.dat >>
> > _____
> > ADVERTISEMENT
>=340342541>
> > zZz
_____
Adam Archibald
Yes I do live in Ottawa. There is one other owner that is new to the list
that also lives in Ottawa, i have yet to meet him but July 4th to 8th would
be a good time
Would love to see you car. email my address and i will
give you my home and cell numbers, just don't want to post them here as
there is a buch of crazy legacy owner out there ;P
As for my 1/4 i have no idea, never ran it. After my mods this summer i'm
sure i will go down and see how i do. As for mods.
intercooler form 95 WRX EURO spec
2.5 exhaust with high flow cat and up pipe, reative muf.
STI engine mounts, spark plugs & wires
Slotted Roaters, Carbon F pads
17' Primax rims
Falcon GB-R tires 7' wide
shitty little K&N air filter
(that must add atleast 20 hp hahaha!)
> would be nice to meet a fellow Turbo owner! For all Turbo owners - What
> times and mods! The reason I'm pumped on the 1/4 - an abondoned track,
> the dust : )
> >To:
> and have >to take the timing belt off.
> >-Adam
> have an > > aftermarket ECU or some other ECU tuning
> software/hardware? > >
> > > Josh Colombo
be a good time
17' Primax rims
> the dust : )
> >To:
> >-Adam
> > > Josh Colombo
c150cglzp
Hey Adam and Matt,
That would be sweet if the three of us could meet up when your in
Ottawa. We should head over to luskville Dragway (10 miles west of
Hull). 15 bucks buys you a whole night of racing. Last weeks a new WRX
was running mid 14's stock, manual. Blowing away every car there,
except for the really fancy pro mods. If all goes well I should be the
owner of a 91 BC Turbo in a few days. However it'll be a project car
which'll take me a few months to get running. Untill then I'm running
a 93 BC auto.
Later,
Mark
a 93 BC auto.
Later,
Mark
