Here's a trick I learned in detox......
I recently went through a hellish situation where I hired a highly regarded mechanic's shop to sniff my exhaust prior to my having to drive my modified car through the mandatory emissions check. They said I would flunk and that my O2 sensor was bad. They treplaced it and then started monkeying with everything until they gave me four separate CHECK ENGINE codes, my car ran like crap and after nine weeks of screwing around, they gave up. I fixed everything they screwed up, but I got tired of playing with the two ECU code checker plugs stuck way up under the dash. I bought a tiny project box and two tiny slide switches at Radio Shack. I glued the tiny switches into the tiny project box, soldered the wires to the switches, then embedded the whole works in Outdoor Goop to make it "solid state" I then glued the tiny project box to the dash door above and to the left of the cig lighter. Now when I get a CHECK ENGINE light, I just flip a couple of switches. I can reset my ECU in one minute without disconnecting the battery. If I had it to do over again I would have skipped the project box and just set the switches into the recess on the back side of the little dash door.
Bill Robinson
92 Legacy Turbo
ECU Checker Switch
georgerbyrne
ECU Checker Switch
Sounds good!
which wires did you hook up to reset the ECU??
Thanks, George, Australia.
--- In BC-BFLegacyWorks@y..., "William D. Robinson" <vultureboy@m...>
> Bill Robinson
> 92 Legacy Turbo
Will You Find True Love?
Will You Meet the One?
Free Love Reading by phone!
http://us.click.yahoo.com/Deo18C/zDLEAA ... /XoTolB/TM
> Bill Robinson
> 92 Legacy Turbo
legacycentral
ECU Checker Switch
You know...some people might be interested in a kit
> Bill Robinson
> 92 Legacy Turbo
> Bill Robinson
> 92 Legacy Turbo
Josh Colombo
ECU Checker Switch
There's two sets of connectors under the dash. One with black plugged connectors and one with green T shapped connectors.
I have some pics of the black connectors, and how to use the plugs, sequence and such to pull the codes, and clear stored codes from the ECU. www.surrealmirage.com/subaru go to notes and tips, engine related.
There's also instructions on how to pull the TCU codes as well under trans related.
-----Original Message-----
Sent: Thu 6/13/2002 2:17 AM
Cc:
Subject: [BC-BFLegacyWorks] Re: ECU Checker Switch
Sounds good!
> Bill Robinson
> 92 Legacy Turbo
Cc:
Sounds good!
> Bill Robinson
> 92 Legacy Turbo
