Shifter bushings for '92 turbo
2.2Turbo
Post by 2.2Turbo »
I am going to replace my shifter bushings and was wondering where to purchase hardned shifter bushings? I was told that some of the local import part houses offer these bushings. I will check this on Monday.
Thanks,
CT
'92 Silver Legacy Sedan 5 speed
'86 Buick Grand National
'87 Silver Buick T Type
'87 Light Yellow T Type
'88 Chevy 1/2 ton twd
JasonGrahn
Post by JasonGrahn »
oooooo.. I wanna see pics of your GNs!!
If you're going to replace your shifter bushings, you may also want to put in a short shifter at the same time. good times w/ that!
http://legacycentral.org/library/shifter.htm
-Jason Grahn
Post by entirelyturbo »
I know Cusco makes harder shifter bushings for our cars, but I wouldn't know where to get them...
I'm probably going to replace mine with OEM soon if I get motivated enough... My shifter is worse than any other MT car I've ever driven :cry:
*Formerly DerFahrer*
2.2Turbo
Post by 2.2Turbo »
Do I need the full shifter assembley or will a shifter and bushings be a big improvment?
JasonGrahn
Get the full assembly. Since you have it apart, you might as well put in a a short throw.
(again, picks of the t-types and GN please :D )
-Jason Grahn
2.2Turbo
Post by 2.2Turbo »
How can I post the pics?
you need them hosted on a web server, and then you put the url in the thread.
