What are you running for a header?
magicmike
Post by magicmike »
I'm looking to buy a header, I dont know if the HKS is worth the money. I'm thinking of buying the borla one because I dont think there would be that big a difference. What are you guys running????
Thanks,
Mike
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
the stock header is going to retain heat the best, which is what you want. If you want to do anything, get the stock one jet-coated. It will help reduce under hood temps and and retain heat in the exhaust.
DLC
Post by DLC »
If you can get a coated, Stainless Steel one you will both retain the heat, get better flow and drop a lot of weight off the front of the car.
Then again, it's not cheap either.
Legacy Central
JasonGrahn
Post by JasonGrahn »
You get what you pay for, thats why the HKS products are so expensive.
8) :D
-Jason Grahn
legacy32656
Post by legacy32656 »
how much is a borla header??? how much is that jet coating and where can i get it done????
thanks
Header will be about 300 bucks or so
http://www.isrperformance.com/scripts/d ... Item=17183
Only real issue I guess is that this borla will only work with the n/a's & will probably require some replumping of the rest of the setup.
If you had an aftermarket turbo setup, you could probably get it to fit pretty easier.
boostjunkie
Post by boostjunkie »
There was a borla header made for the wrxs. Limited sale price of >$400 but that sale is over. I'm not sure how much they're charging now. I know I posted something on this board about the header. Do a search for Borla header and it should come up.
subiecar
Headers...Borla`s the best!
Post by subiecar »
:D I have thermo-coated Borlas on my custom turbo set-up now. I put them on an NA motor and when the turbo was added the up/down pipes were a customized fit. I had looked at STI and other JDM stainless headers that were offered for our Subies--WAY too expensive and not much different than mine (try $1700+ w/o up/down pipes, etc!!!) I personally think they work great and am very pleased with their warranty. You can expect to pay approx $400+ for the headers and coating. I`ve never had the thermo coating on any car before so after I`m up and running, I`ll let you know the temp reduction. 8) . Talk at you soon--Rod
Age and treachery will overcome youth and skill!
magicmike
Post by magicmike »
Thanks for all your input everyone! I actually ordered the set that Nate has for sale.. I should get them in next week, I'll post photos of it on the motor.
Mike
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
